trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Stamoid?
JF
Jack Frost
Mon, Mar 29, 2010 5:44 PM
Local canvas guy is recommending Stamoid for my tuna tower tops.  There will
be a buggy top on the top of the tower & a full top over my helm area, all
over the aluminum pipe work.  The old was weblon & after 22 years has finally
fallen apart.  How good is Stamoid & what type of life can I expect from it?
Thanks,
Andy Becker
31' Rampage Express
HIGH LIFE II
Lindenhurst, NY
Hotmail: Trusted email with powerful SPAM protection.
http://clk.atdmt.com/GBL/go/210850553/direct/01/
Local canvas guy is recommending Stamoid for my tuna tower tops. There will be a buggy top on the top of the tower & a full top over my helm area, all over the aluminum pipe work. The old was weblon & after 22 years has finally fallen apart. How good is Stamoid & what type of life can I expect from it? Thanks, Andy Becker 31' Rampage Express HIGH LIFE II Lindenhurst, NY _________________________________________________________________ Hotmail: Trusted email with powerful SPAM protection. http://clk.atdmt.com/GBL/go/210850553/direct/01/
G
gsharell@comcast.net
Mon, Mar 29, 2010 6:58 PM
In Florida I have had to replace Stamoid on my fly bridge and lower deck bimani every 4 years. Also seams where sewed tend to stretch out and leak. Orther than that no complaints.
Gil Sharell "LOTUS"44' Island Gypsy Sarasota, FL
In Florida I have had to replace Stamoid on my fly bridge and lower deck bimani every 4 years. Also seams where sewed tend to stretch out and leak. Orther than that no complaints. Gil Sharell "LOTUS"44' Island Gypsy Sarasota, FL
RA
Rudy and Jill
Mon, Mar 29, 2010 7:49 PM
Andy, one thing about Weblon is that it is laminated on both sides with vinyl, whereas Stamoid is just pokyester fabric coated with vinyl.
The difference comes in fabrication. Weblon can be glued together, instead of sewn, using an adhesive like HH-66. HH-66 melts the two pieces of material together and results in a bond that is stronger than the material.
Eliminate the stitching eliminates a potential leaky seam. Even if the Weblon is oversewn after being glued, if it starts to leak, HH-66 can be applied and will probably seal the leaks. Kinda handy if the seam is over your head.
Stamoid, at least to my understanding, can also be glued together with HH-66, but the seam isn't as strong as with Weblon. I haven't worked much with Stamoid, so better discuss this with your canvas guy.
Rudy
Briney Bug, Panama City, Fl
Andy, one thing about Weblon is that it is laminated on both sides with vinyl, whereas Stamoid is just pokyester fabric coated with vinyl. The difference comes in fabrication. Weblon can be glued together, instead of sewn, using an adhesive like HH-66. HH-66 melts the two pieces of material together and results in a bond that is stronger than the material. Eliminate the stitching eliminates a potential leaky seam. Even if the Weblon is oversewn after being glued, if it starts to leak, HH-66 can be applied and will probably seal the leaks. Kinda handy if the seam is over your head. Stamoid, at least to my understanding, can also be glued together with HH-66, but the seam isn't as strong as with Weblon. I haven't worked much with Stamoid, so better discuss this with your canvas guy. Rudy Briney Bug, Panama City, Fl
TS
Ted Stehle
Mon, Mar 29, 2010 11:28 PM
Andy,
My bimini is white Stamoid, about 6 years old. The boat is on the southern
Chesapeake Bay. My experience has been that the material is difficult to
handle (doesn't fold easily when removed for cleaning) and the coating
cracks after a period of time. Working with it in cool weather is almost
impossible. Finally, it has never cleaned up to my satisfaction....the white
always looks dirty. I will not use the product in the future.
Ted Stehle
"Good Times"
45 Californian
Andy, My bimini is white Stamoid, about 6 years old. The boat is on the southern Chesapeake Bay. My experience has been that the material is difficult to handle (doesn't fold easily when removed for cleaning) and the coating cracks after a period of time. Working with it in cool weather is almost impossible. Finally, it has never cleaned up to my satisfaction....the white always looks dirty. I will not use the product in the future. Ted Stehle "Good Times" 45 Californian
LB
Leonard Brunotte
Wed, Mar 31, 2010 12:42 PM
For best results consider heat welded seams rather than sewing for Weblon or
Stamoid.
Kindest regards,
Leonard Brunotte
-----Original Message-----
From: trawlers-and-trawlering-bounces@lists.samurai.com
[mailto:trawlers-and-trawlering-bounces@lists.samurai.com]On Behalf Of
Jack Frost
Sent: Monday, March 29, 2010 1:45 PM
To: trawlers-and-trawlering@lists.samurai.com
Subject: T&T: Stamoid?
finally
Thanks,
Andy Becker
31' Rampage Express
HIGH LIFE II
Lindenhurst, NY
http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering
To unsubscribe or modify your subscription options (get password, change
email address, etc) go to:
http://lists.samurai.com/mailman/options/trawlers-and-trawlering
Trawlers & Trawlering and T&T are trademarks of Water World
Productions. Unauthorized use is prohibited.
For best results consider heat welded seams rather than sewing for Weblon or Stamoid. Kindest regards, Leonard Brunotte -----Original Message----- From: trawlers-and-trawlering-bounces@lists.samurai.com [mailto:trawlers-and-trawlering-bounces@lists.samurai.com]On Behalf Of Jack Frost Sent: Monday, March 29, 2010 1:45 PM To: trawlers-and-trawlering@lists.samurai.com Subject: T&T: Stamoid? Local canvas guy is recommending Stamoid for my tuna tower tops. There will be a buggy top on the top of the tower & a full top over my helm area, all over the aluminum pipe work. The old was weblon & after 22 years has finally fallen apart. How good is Stamoid & what type of life can I expect from it? Thanks, Andy Becker 31' Rampage Express HIGH LIFE II Lindenhurst, NY _________________________________________________________________ Hotmail: Trusted email with powerful SPAM protection. http://clk.atdmt.com/GBL/go/210850553/direct/01/ _______________________________________________ http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering To unsubscribe or modify your subscription options (get password, change email address, etc) go to: http://lists.samurai.com/mailman/options/trawlers-and-trawlering Trawlers & Trawlering and T&T are trademarks of Water World Productions. Unauthorized use is prohibited.
