Re: Replicas out of band in OFDM signal (N210+CBX)
RE
Ron Economos
Wed, Jul 17, 2024 3:58 PM
The trick would be to oversample. I'm not sure how you would do that
with just UHD, but with GNU Radio, you would just use a rational
resampler block. That is, setting the sample rate to 20 Msps and using a
2X resample ratio.
Ron
On 7/17/24 08:38, Brais Ares Fernández wrote:
I've just tested exactly the same setup but using a B210, and it
does *not *happen.
So it definitely seems to be what Ron pointed out.
@Marcus: yes, the signal used is sampled at 10e6 and I can see its
spectrum in Matlab and it's a clean OFDM. Actually we tried one OFDM
signal modulated by us, and other completely different one by 5GMAG
https://github.com/5G-MAG/rt-mbms-modem and that effect always appear.
Then... Using N210, is there no way that I can filter out that
aliasing stuff?
De: Ron Economos w6rz@comcast.net
Enviado: miércoles, 17 de julio de 2024 16:05
Para: Brais Ares Fernández bares@gradiant.org;
usrp-users@lists.ettus.com usrp-users@lists.ettus.com
Asunto: Re: [USRP-users] Re: Replicas out of band in OFDM signal
(N210+CBX)
Yeah, I think UHD sets it to some calculated value that can't be
overwritten.
BTW, here's what the spectrum looks like with a very wide analog
filter. So the default bandwidth setting on the N210/CBX is just a
little too wide to fully suppress that first alias.
Ron
On 7/17/24 06:39, Brais Ares Fernández wrote:
Hello, Ron. Thank you for the answer.
I've already tried but it seems to do nothing:
$ sudo /lib/uhd/examples/tx_samples_from_file --freq 1500e6 --rate
10e6 --gain 20 --bw 10e6 --type float --file ~/OFDMsignal.raw
--args="name=sdr1"
I even tried weird values like 100e3 or 100e6, but no apparent effect
over the spectrum at all.
De: Ron Economos via USRP-users usrp-users@lists.ettus.com
mailto:usrp-users@lists.ettus.com
Enviado: miércoles, 17 de julio de 2024 15:00
Para: usrp-users@lists.ettus.com
mailto:usrp-users@lists.ettus.com usrp-users@lists.ettus.com
Asunto: [USRP-users] Re: Replicas out of band in OFDM signal
(N210+CBX)
Those are aliases. Try setting the analog bandwidth with the --bw
parameter.
Ron
On 7/17/24 03:58, Brais Ares Fernández wrote:
Hello,
This might be a common effect but I don't comprehend why it happens
and if it is avoidable.
I'm using a N210+CBX to transmit a 10 MSPS OFDM signal, with Fc =
1.5 GHz. When transmitting, I can see some kind of "replicas" at
+-7.5 MHz from Fc, always with a 40 dBc difference.
10e6 --gain 20 --type float --file ~/OFDMsignal.raw --args="name=sdr1"
I've already tried changing lo_offset and executing the calibration
utilities for IQ imbalance, but none of that seems related to the
problem.
Could anyone provide any insight?
Regards.
The trick would be to oversample. I'm not sure how you would do that with just UHD, but with GNU Radio, you would just use a rational resampler block. That is, setting the sample rate to 20 Msps and using a 2X resample ratio. Ron On 7/17/24 08:38, Brais Ares Fernández wrote: > I've just tested exactly the same setup but using a *B210*, and it > does *not *happen. > > So it definitely seems to be what Ron pointed out. > > @Marcus: yes, the signal used is sampled at 10e6 and I can see its > spectrum in Matlab and it's a clean OFDM. Actually we tried one OFDM > signal modulated by us, and other completely different one by 5GMAG > <https://github.com/5G-MAG/rt-mbms-modem> and that effect always appear. > > Then... Using N210, is there no way that I can filter out that > aliasing stuff? > > > ------------------------------------------------------------------------ > *De:* Ron Economos <w6rz@comcast.net> > *Enviado:* miércoles, 17 de julio de 2024 16:05 > *Para:* Brais Ares Fernández <bares@gradiant.org>; > usrp-users@lists.ettus.com <usrp-users@lists.ettus.com> > *Asunto:* Re: [USRP-users] Re: Replicas out of band in OFDM signal > (N210+CBX) > > Yeah, I think UHD sets it to some calculated value that can't be > overwritten. > > > BTW, here's what the spectrum looks like with a very wide analog > filter. So the default bandwidth setting on the N210/CBX is just a > little too wide to fully suppress that first alias. > > > Ron > > > On 7/17/24 06:39, Brais Ares Fernández wrote: >> Hello, Ron. Thank you for the answer. >> >> I've already tried but it seems to do nothing: >> >> $ sudo /lib/uhd/examples/tx_samples_from_file --freq 1500e6 --rate >> 10e6 --gain 20 *--bw 10e6* --type float --file ~/OFDMsignal.raw >> --args="name=sdr1" >> >> I even tried weird values like 100e3 or 100e6, but no apparent effect >> over the spectrum at all. >> ------------------------------------------------------------------------ >> *De:* Ron Economos via USRP-users <usrp-users@lists.ettus.com> >> <mailto:usrp-users@lists.ettus.com> >> *Enviado:* miércoles, 17 de julio de 2024 15:00 >> *Para:* usrp-users@lists.ettus.com >> <mailto:usrp-users@lists.ettus.com> <usrp-users@lists.ettus.com> >> <mailto:usrp-users@lists.ettus.com> >> *Asunto:* [USRP-users] Re: Replicas out of band in OFDM signal >> (N210+CBX) >> >> Those are aliases. Try setting the analog bandwidth with the --bw >> parameter. >> >> >> Ron >> >> >> On 7/17/24 03:58, Brais Ares Fernández wrote: >>> Hello, >>> >>> This might be a common effect but I don't comprehend why it happens >>> and if it is avoidable. >>> >>> I'm using a N210+CBX to transmit a 10 MSPS *OFDM signal*, with Fc = >>> 1.5 GHz. When transmitting, I can see some kind of "replicas" at >>> +-7.5 MHz from Fc, always with a 40 dBc difference. >>> >>> $ sudo /lib/uhd/examples/tx_samples_from_file --freq 1500e6 --rate >>> 10e6 --gain 20 --type float --file ~/OFDMsignal.raw --args="name=sdr1" >>> >>> >>> I've already tried changing lo_offset and executing the calibration >>> utilities for IQ imbalance, but none of that seems related to the >>> problem. >>> >>> Could anyone provide any insight? >>> >>> Regards. >>>
