Re: [USRP-users] Read Only File System ?
JP
Joel Parker
Fri, May 11, 2012 4:06 PM
Well I guess I spoke early. In the middle of the OpenBTS download it started complaining again. When I look at dmesg its mad about i/o blocks :
mmcblk0: error -110 transferring data, sector 1179696, nr 8, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 1179697
Buffer I/O error on device mmcblk0p2, logical block 131078
lost page write due to I/O error on mmcblk0p2
mmcblk0: error -110 transferring data, sector 3818504, nr 48, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 3818505
end_request: I/O error, dev mmcblk0, sector 3818512
end_request: I/O error, dev mmcblk0, sector 3818520
end_request: I/O error, dev mmcblk0, sector 3818528
end_request: I/O error, dev mmcblk0, sector 3818536
end_request: I/O error, dev mmcblk0, sector 3818544
Aborting journal on device mmcblk0p2.
EXT3-fs (mmcblk0p2): error in ext3_new_inode: Journal has aborted
EXT3-fs (mmcblk0p2): error in ext3_create: Journal has aborted
EXT3-fs (mmcblk0p2): error: ext3_journal_start_sb: Detected aborted journal
EXT3-fs (mmcblk0p2): error: remounting filesystem read-only
Do I need to do an fdsk or something equivalent or is this a know issue ?
-- Joel Parker
To: Philip Balister philip@opensdr.com
Sent: Friday, May 11, 2012 11:00 AM
Subject: Re: [USRP-users] Read Only File System ?
I just rebooted from command line and it came up clean. Bizarre.
-- Joel
Sent: Friday, May 11, 2012 10:36 AM
Yeah, same thing I thought but svn also had errors when installing but seems to work ?
root@usrp-e1xx:~# opkg install subversion
Installing subversion (1.6.5-r1.9) to root...
Downloading http://feeds.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a/base/subversion_1.6.5-r1.9_armv7a.ipk.
Installing libaprutil-1-0 (1.3.10-r1.9) to root...
Downloading http://feeds.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a/base/libaprutil-1-0_1.3.10-r1.9_armv7a.ipk.
Installing libapr-1-0 (1.4.2-r0.9) to root...
Downloading http://feeds.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a/base/libapr-1-0_1.4.2-r0.9_armv7a.ipk.
Collected errors:
 * opkg_prep_intercepts: Failed to make temp dir
/var/lib/opkg/tmp/opkg-lK8a4R/opkg-intercept-2uyF1V: Invalid
argument.
I don't see timeout issues but do see many i/o errors with the mmc. This is the first time I ever powered this device up ... very strange.
Here is the output from dmesg:
Linux version 3.0.0 (balister@octopus) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #1 Tue Nov 15 14:07:23 EST 2011
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Gumstix Overo
Reserving 12582912 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP3630 ES1.2 (l2cache iva sgx neon isp 192mhz_clk )
SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x10000
On node 0 totalpages: 128000
free_area_init_node: node 0, pgdat c0599010, node_mem_map c05fe000
  Normal zone: 1024
pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 126976 pages, LIFO batch:31
Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
Reprogramming SDRC clock to 332000000 Hz
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 126976
Kernel command line: console=ttyO2,115200n8 mpurate=720 vram=12M omapfb.mode=dvi:1024x768MR-16@60 omapdss.def_disp=dvi root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 500MB = 500MB total
Memory: 501328k/501328k available, 22960k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4
kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xe0800000 - 0xf8000000   ( 376 MB)
    lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc0037000   ( 188 kB)
      .text : 0xc0037000 - 0xc0554f94   (5240 kB)
      .data : 0xc0556000 - 0xc05996c0   ( 270 kB)
       .bss : 0xc05996e4 - 0xc05fd684   ( 400 kB)
NR_IRQS:410
IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP clockevent source: GPTIMER1
at 32768 Hz
sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
Console: colour dummy device 80x30
Calibrating delay loop... 597.64 BogoMIPS (lpj=2334720)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_hwmod: gpt12_fck: missing clockdomain for gpt12_fck.
print_constraints: dummy:
NET: Registered protocol family 16
GPMC revision 5.0
OMAP GPIO hardware version 2.5
omap_mux_init: Add partition: #1: core, flags: 0
Found NAND on CS0
Registering NAND on CS0
Setup up gpmc timing.
GPMC_CONFIG1 reg: 28001002
GPMC_CONFIG2 reg: 30600
GPMC_CONFIG3 reg: 20201
GPMC_CONFIG4 reg: 3000501
GPMC_CONFIG5 reg:
1030306
GPMC_CONFIG6 reg: 83030000
GPMC_CONFIG1 reg: 1000
GPMC_CONFIG2 reg: 141f00
GPMC_CONFIG4 reg: 14001f00
GPMC_CONFIG5 reg: 11e151f
GPMC_CONFIG6 reg: f030f80
hw-breakpoint: debug architecture 0x4 unsupported.
omap_device: omap-mcbsp.2: alias fck already exists
omap_device: omap-mcbsp.3: alias fck already exists
Switched to new clocking rate (Crystal/Core/MPU): 26.0/332/720 MHz
OMAP DMA hardware revision 5.0
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600 kHz
twl4030: PIH (irq 7) chaining IRQs 368..375
twl4030: power (irq 373) chaining IRQs 376..383
twl4030: gpio (irq 368) chaining IRQs 384..401
machine_constraints_voltage: VUSB1V5: override min_uV, 1 ->
1500000
machine_constraints_voltage: VUSB1V5: override max_uV, 2147483647 -> 1500000
print_constraints: VUSB1V5: 1500 mV normal standby
machine_constraints_voltage: VUSB1V8: override min_uV, 1 -> 1800000
machine_constraints_voltage: VUSB1V8: override max_uV, 2147483647 -> 1800000
print_constraints: VUSB1V8: 1800 mV normal standby
machine_constraints_voltage: VUSB3V1: override min_uV, 1 -> 3100000
machine_constraints_voltage: VUSB3V1: override max_uV, 2147483647 -> 3100000
print_constraints: VUSB3V1: 3100 mV normal standby
twl4030_usb twl4030_usb: HW_CONDITIONS 0x10/16; link 0
twl4030_usb twl4030_usb: Initialized TWL4030 USB module
print_constraints: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby
print_constraints: VDAC: 1800 mV normal standby
print_constraints: VDVI: 1800 mV normal standby
omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz
Advanced Linux Sound Architecture Driver Version
1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
Switching to clocksource 32k_counter
Switched to NOHz mode on CPU #0
musb-hdrc: version 6.0, musb-dma, host
twl4030_usb twl4030_usb: twl4030_phy_resume
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 1.800
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
musb-hdrc musb-hdrc: MUSB HDRC host driver
drivers/usb/core/inode.c: creating file 'devices'
drivers/usb/core/inode.c: creating file '001'
musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 1
usb usb1: default language 0x0409
usb usb1: udev 1, busnum 1, minor = 0
usb usb1: New
USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 3.0.0 musb-hcd
usb usb1: SerialNumber: musb-hdrc
usb usb1: usb_probe_device
usb usb1: configuration #1 chosen from 1 choice
usb usb1: adding 1-0:1.0 (config #1, interface 0)
hub 1-0:1.0: usb_probe_interface
hub 1-0:1.0: usb_probe_interface - got id
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
hub 1-0:1.0: standalone hub
hub 1-0:1.0: individual port power switching
hub 1-0:1.0: no over-current protection
hub 1-0:1.0: Single TT
hub 1-0:1.0: TT requires at most 8 FS bit times (666 ns)
hub 1-0:1.0: power on to power good time: 10ms
hub 1-0:1.0: 100mA bus power budget for each child
hub 1-0:1.0: local power source is good
hub 1-0:1.0: enabling power on all ports
'001'
musb-hdrc musb-hdrc: USB Host mode controller at fa0ab000 using DMA, IRQ 92
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Registering unionfs 2.5.9.2 (for 3.0.0-rc4)
JFFS2 version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat,
Inc.
msgmni has been set to 979
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
OMAP DSS rev 2.0
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
console [ttyO2] enabled
hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a OMAP UART3
brd: module loaded
loop: module loaded
twl4030_usb twl4030_usb: HW_CONDITIONS 0x50/80; link 0
twl4030_usb twl4030_usb: twl4030_phy_suspend
omap2-nand driver initializing
ONFI flash detected
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xbc
(Micron NAND 512MiB 1,8V 16-bit)
Creating 5 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000080000 : "xloader"
0x000000080000-0x000000240000 : "uboot"
0x000000240000-0x000000280000 : "uboot environment"
0x000000280000-0x000000680000 : "linux"
0x000000680000-0x000020000000 : "rootfs"
smsc911x: Driver version 2008-10-21
smsc911x-mdio: probed
smsc911x smsc911x.0: eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, irq=-1)
smsc911x smsc911x.0: eth0: MAC Address: a0:36:fa:85:31:b7
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
cdc_ncm: 01-June-2011
usbcore: registered new interface driver cdc_ncm
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_hcd: block sizes: qh 60 qtd 96 itd 160 sitd 96
ehci-omap ehci-omap.0: failed to get ehci port1 regulator
ehci-omap ehci-omap.0: phy reset operation timed out
ehci-omap
ehci-omap.0: reset hcs_params 0x1313 dbg=0 cc=1 pcc=3 ordered ports=3
ehci-omap ehci-omap.0: reset hcc_params 0016 thresh 1 uframes 256/512/1024 park
ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
drivers/usb/core/inode.c: creating file '002'
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2
ehci-omap ehci-omap.0: park 0
ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
ehci-omap ehci-omap.0: reset command 0080b02  park=3 ithresh=8 period=1024 Reset HALT
ehci-omap ehci-omap.0: init command 0010005 (park)=0 ithresh=1 period=512 RUN
ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
usb usb2: default language 0x0409
usb usb2: udev 1, busnum 2, minor = 128
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: OMAP-EHCI Host Controller
usb usb2: Manufacturer: Linux 3.0.0 ehci_hcd
usb usb2:
SerialNumber: ehci-omap.0
usb usb2: usb_probe_device
usb usb2: configuration #1 chosen from 1 choice
usb usb2: adding 2-0:1.0 (config #1, interface 0)
hub 2-0:1.0: usb_probe_interface
hub 2-0:1.0: usb_probe_interface - got id
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 3 ports detected
hub 2-0:1.0: standalone hub
hub 2-0:1.0: individual port power switching
hub 2-0:1.0: individual port over-current protection
hub 2-0:1.0: power on to power good time: 20ms
hub 2-0:1.0: local power source is good
hub 2-0:1.0: enabling power on all ports
ehci-omap ehci-omap.0: ...powerup ports...
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
twl_rtc twl_rtc: Power up reset
detected.
i2c /dev entries driver
OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCI H4 protocol initialized
Bluetooth: HCI BCSP protocol initialized
Bluetooth: HCILL protocol initialized
cpuidle: using governor ladder
cpuidle: using governor menu
Registered led device: overo:blue:COM
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usbcore: registered new interface driver snd-usb-audio
overo SoC init
hub 2-0:1.0: state 7 ports 3 chg 0000 evt 0000
asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
ALSA device list:
  #0: overo
oprofile: hardware counters not available
oprofile: using timer interrupt.
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM
ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
ThumbEE CPU extension supported.
sr_init: No PMIC hook to init smartreflex
smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
clock: disabling unused clocks to save power
fbcvt: 1024x768@60: CVT Name - .786M3-R
Console: switching to colour frame buffer device 128x48
regulator_init_complete: VDAC: incomplete constraints, leaving on
twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:20 UTC (946684820)
Waiting for root device /dev/mmcblk0p2...
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new SDHC card at address
b368
mmcblk0: mmc0:b368 SDC   3.84 GiB
 mmcblk0: p1 p2
EXT3-fs: barriers not enabled
kjournald starting.  Commit interval 5 seconds
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): recovery complete
EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
devtmpfs: mounted
Freeing init memory: 188K
NET: Registered protocol family 10
usrp_e entering driver initialization
usrp_e data struct malloc'd.
usrp_e Data initialized..
usrp_e major number : 249
Getting Chip Select
Got CS4, address = 1000000
Got CS6, address = 2000000
usrp_e Driver Initialized.
udevd[102]: starting version 171
smsc911x smsc911x.0: eth0: SMSC911x/921x identified at 0xe086a000, IRQ: 336
eth0: no IPv6 routers present
usrp_e open called, use_count = 0
rx_dma->ch 4
tx_dma->ch 5
usrp: leaving open
usrp_e release called
Waiting for DMA to become inactive
Freeing gpio irq's
Freeing DMA channels
rx_dma->ch 5
tx_dma->ch 6
usrp: leaving open
Size = 2105344, expected sixe = 2105344
Freeing gpio irq's
mmcblk0: error -110 transferring data, sector 438648, nr 8, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 438649
Buffer I/O error on device mmcblk0p2, logical block 38447
mmcblk0: error -110 transferring data, sector 779688, nr 8, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 779689
block 81077
mmcblk0: error -110 transferring data, sector 788864, nr 8, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 788865
Buffer I/O error on device mmcblk0p2, logical block 82224
mmcblk0: error -110 transferring data, sector 1864744, nr 8, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 1864745
Buffer I/O error on device mmcblk0p2, logical block 216709
mmcblk0: error -110 sending read/write command, response 0x900, card status 0xe00
mmcblk0: error -110 transferring data, sector 1874144, nr 8, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 1874145
Buffer I/O error on device mmcblk0p2, logical block 217884
mmcblk0: error -110 transferring data, sector 1968272, nr 8, card status
0xc00
end_request: I/O error, dev mmcblk0, sector 1968273
Buffer I/O error on device mmcblk0p2, logical block 229650
mmcblk0: error -110 transferring data, sector 2293616, nr 8, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 2293617
Buffer I/O error on device mmcblk0p2, logical block 270318
mmcblk0: error -110 transferring data, sector 5113152, nr 624, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 5113153
Buffer I/O error on device mmcblk0p2, logical block 622760
end_request: I/O error, dev mmcblk0, sector 5113160
Buffer I/O error on device mmcblk0p2, logical block 622761
end_request: I/O error, dev mmcblk0, sector 5113168
Buffer I/O error on device mmcblk0p2, logical block 622762
lost page
end_request: I/O error, dev mmcblk0, sector 5113176
Buffer I/O error on device mmcblk0p2, logical block 622763
end_request: I/O error, dev mmcblk0, sector 5113184
Buffer I/O error on device mmcblk0p2, logical block 622764
end_request: I/O error, dev mmcblk0, sector 5113192
Buffer I/O error on device mmcblk0p2, logical block 622765
end_request: I/O error, dev mmcblk0, sector 5113200
Buffer I/O error on device mmcblk0p2, logical block 622766
end_request: I/O error, dev mmcblk0, sector 5113208
Buffer I/O error on device mmcblk0p2, logical block 622767
end_request: I/O error, dev mmcblk0, sector 5113216
logical block 622768
end_request: I/O error, dev mmcblk0, sector 5113224
end_request: I/O error, dev mmcblk0, sector 5113232
end_request: I/O error, dev mmcblk0, sector 5113240
end_request: I/O error, dev mmcblk0, sector 5113248
end_request: I/O error, dev mmcblk0, sector 5113256
end_request: I/O error, dev mmcblk0, sector 5113264
end_request: I/O error, dev mmcblk0, sector 5113272
end_request: I/O error, dev mmcblk0, sector 5113280
end_request: I/O error, dev mmcblk0, sector 5113288
end_request: I/O error, dev mmcblk0, sector 5113296
end_request: I/O error, dev mmcblk0, sector 5113304
end_request: I/O error, dev mmcblk0, sector 5113312
end_request: I/O error, dev mmcblk0, sector 5113320
end_request: I/O error, dev mmcblk0, sector 5113328
end_request: I/O error, dev mmcblk0, sector 5113336
end_request: I/O error, dev mmcblk0, sector 5113344
end_request:
I/O error, dev mmcblk0, sector 5113352
end_request: I/O error, dev mmcblk0, sector 5113360
end_request: I/O error, dev mmcblk0, sector 5113368
end_request: I/O error, dev mmcblk0, sector 5113376
end_request: I/O error, dev mmcblk0, sector 5113384
end_request: I/O error, dev mmcblk0, sector 5113392
end_request: I/O error, dev mmcblk0, sector 5113400
end_request: I/O error, dev mmcblk0, sector 5113408
end_request: I/O error, dev mmcblk0, sector 5113416
end_request: I/O error, dev mmcblk0, sector 5113424
end_request: I/O error, dev mmcblk0, sector 5113432
end_request: I/O error, dev mmcblk0, sector 5113440
end_request: I/O error, dev mmcblk0, sector 5113448
end_request: I/O error, dev mmcblk0, sector 5113456
end_request: I/O error, dev mmcblk0, sector 5113464
end_request: I/O error, dev mmcblk0, sector 5113472
end_request: I/O error, dev mmcblk0, sector 5113480
5113488
end_request: I/O error, dev mmcblk0, sector 5113496
end_request: I/O error, dev mmcblk0, sector 5113504
end_request: I/O error, dev mmcblk0, sector 5113512
end_request: I/O error, dev mmcblk0, sector 5113520
end_request: I/O error, dev mmcblk0, sector 5113528
end_request: I/O error, dev mmcblk0, sector 5113536
end_request: I/O error, dev mmcblk0, sector 5113544
end_request: I/O error, dev mmcblk0, sector 5113552
end_request: I/O error, dev mmcblk0, sector 5113560
end_request: I/O error, dev mmcblk0, sector 5113568
end_request: I/O error, dev mmcblk0, sector 5113576
end_request: I/O error, dev mmcblk0, sector 5113584
end_request: I/O error, dev mmcblk0, sector 5113592
end_request: I/O error, dev mmcblk0, sector 5113600
end_request: I/O error, dev mmcblk0, sector 5113608
end_request: I/O error, dev mmcblk0, sector 5113616
end_request: I/O error, dev mmcblk0, sector 5113624
end_request: I/O
error, dev mmcblk0, sector 5113632
end_request: I/O error, dev mmcblk0, sector 5113640
end_request: I/O error, dev mmcblk0, sector 5113648
end_request: I/O error, dev mmcblk0, sector 5113656
end_request: I/O error, dev mmcblk0, sector 5113664
end_request: I/O error, dev mmcblk0, sector 5113672
end_request: I/O error, dev mmcblk0, sector 5113680
end_request: I/O error, dev mmcblk0, sector 5113688
end_request: I/O error, dev mmcblk0, sector 5113696
end_request: I/O error, dev mmcblk0, sector 5113704
end_request: I/O error, dev mmcblk0, sector 5113712
end_request: I/O error, dev mmcblk0, sector 5113720
end_request: I/O error, dev mmcblk0, sector 5113728
end_request: I/O error, dev mmcblk0, sector 5113736
end_request: I/O error, dev mmcblk0, sector 5113744
end_request: I/O error, dev mmcblk0, sector 5113752
end_request: I/O error, dev mmcblk0, sector 5113760
5113768
mmcblk0: error -110 transferring data, sector 5155920, nr 72, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 5155921
end_request: I/O error, dev mmcblk0, sector 5155928
end_request: I/O error, dev mmcblk0, sector 5155936
end_request: I/O error, dev mmcblk0, sector 5155944
end_request: I/O error, dev mmcblk0, sector 5155952
end_request: I/O error, dev mmcblk0, sector 5155960
end_request: I/O error, dev mmcblk0, sector 5155968
end_request: I/O error, dev mmcblk0, sector 5155976
end_request: I/O error, dev mmcblk0, sector 5155984
mmcblk0: error -110 transferring data, sector 7210904, nr 16, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 7210905
quiet_error: 78 callbacks suppressed
Buffer I/O error on device mmcblk0p2, logical block 884979
mmcblk0p2
end_request: I/O error, dev mmcblk0, sector 7210912
Buffer I/O error on device mmcblk0p2, logical block 884980
mmcblk0: error -110 transferring data, sector 7241736, nr 16, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 7241737
Buffer I/O error on device mmcblk0p2, logical block 888833
end_request: I/O error, dev mmcblk0, sector 7241744
Buffer I/O error on device mmcblk0p2, logical block 888834
EXT3-fs error (device mmcblk0p2): ext3_find_entry: reading directory #216064 offset 0
------------[ cut here ]------------
WARNING: at fs/inode.c:901 unlock_new_inode+0x20/0x40()
Modules linked in: usrp_e ipv6
[<c0040c7c>] (unwind_backtrace+0x0/0xe0) from [<c0060654>] (warn_slowpath_common+0x4c/0x64)
[<c0060654>]
(warn_slowpath_common+0x4c/0x64) from [<c0060684>] (warn_slowpath_null+0x18/0x1c)
[<c0060684>] (warn_slowpath_null+0x18/0x1c) from [<c00d6ac0>] (unlock_new_inode+0x20/0x40)
[<c00d6ac0>] (unlock_new_inode+0x20/0x40) from [<c011138c>] (ext3_new_inode+0x868/0x89c)
[<c011138c>] (ext3_new_inode+0x868/0x89c) from [<c0117a74>] (ext3_mkdir+0xa8/0x2d0)
[<c0117a74>] (ext3_mkdir+0xa8/0x2d0) from [<c00cd6fc>] (vfs_mkdir+0x68/0x98)
[<c00cd6fc>] (vfs_mkdir+0x68/0x98) from [<c00d02c0>] (sys_mkdirat+0x80/0xcc)
[<c00d02c0>] (sys_mkdirat+0x80/0xcc) from [<c003c480>] (ret_fast_syscall+0x0/0x30)
---[ end trace 53e65c8e2ab3e159 ]---
mmcblk0: error -110 transferring data, sector 7258120, nr 16, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 7258121
Buffer I/O error on device mmcblk0p2, logical block 890881
mmcblk0p2
end_request: I/O error, dev mmcblk0, sector 7258128
Buffer I/O error on device mmcblk0p2, logical block 890882
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913496
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913497
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913498
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913499
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913502
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913592
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913593
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913596
mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913620
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913871
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913878
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913879
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913881
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913882
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913883
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913884
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913885
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913886
ext3_free_blocks_sb: bit already cleared for block 913887
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913880
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216210
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 892928
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 892929
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894333
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894334
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894335
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894336
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894337
bit already cleared for block 894338
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894339
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894340
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894341
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894342
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894344
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894345
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894346
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894347
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894348
cleared for block 894349
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894350
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894351
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894352
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894353
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894354
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894355
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894356
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894357
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894358
894359
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894360
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894361
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894362
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894363
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894364
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894365
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894366
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894367
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894368
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894369
EXT3-fs
error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894370
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894371
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894372
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894373
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894374
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894375
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894376
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894377
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894378
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894379
mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894380
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894381
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894382
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894383
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894384
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894385
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894386
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894387
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894388
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894389
ext3_free_blocks_sb: bit already cleared for block 894390
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894391
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894392
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894393
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894394
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894395
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894396
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894397
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894398
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894399
ext3_free_blocks_sb: bit already cleared for block 894400
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894401
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894402
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894403
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894404
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894405
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894406
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894407
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894408
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894409
ext3_free_blocks_sb: bit already cleared for block 894410
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894411
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894412
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894413
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894414
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894415
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894416
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894417
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894418
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894419
ext3_free_blocks_sb: bit already cleared for block 894420
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894421
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894422
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894423
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894424
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894425
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894426
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894427
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894428
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894429
ext3_free_blocks_sb: bit already cleared for block 894430
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894431
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894432
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894433
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894434
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894435
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894436
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894437
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894438
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894439
ext3_free_blocks_sb: bit already cleared for block 894440
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894441
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894442
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894443
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894444
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894445
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894446
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894447
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894448
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894449
ext3_free_blocks_sb: bit already cleared for block 894450
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894451
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894452
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894453
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894454
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894455
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894456
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894457
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894458
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894459
ext3_free_blocks_sb: bit already cleared for block 894460
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894461
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894462
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894463
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894464
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894465
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894466
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894467
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894468
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894469
ext3_free_blocks_sb: bit already cleared for block 894470
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894471
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894472
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894473
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894474
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894475
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894476
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894477
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894478
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894479
ext3_free_blocks_sb: bit already cleared for block 894480
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894481
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894482
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894483
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894484
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894485
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894486
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894487
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894488
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894489
ext3_free_blocks_sb: bit already cleared for block 894490
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894491
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894492
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894493
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894494
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894495
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894496
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894497
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894498
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894499
ext3_free_blocks_sb: bit already cleared for block 894500
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894501
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894502
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894503
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894504
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894505
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894506
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894507
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894508
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894509
ext3_free_blocks_sb: bit already cleared for block 894510
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894511
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894343
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216195
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899072
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899073
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899074
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899075
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899076
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899077
bit already cleared for block 899078
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899079
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899080
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899081
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899082
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899083
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899085
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899086
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899084
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216206
EXT3-fs error (device mmcblk0p2): htree_dirblock_to_tree: bad entry in
directory #216196: rec_len % 4 != 0 - offset=0, inode=1801675088, rec_len=26465, name_len=101
EXT3-fs (mmcblk0p2): warning: empty_dir: bad directory (dir #216196) - no .' or ..'
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888834
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216196
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888847
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216213
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888842
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216212
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888846
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216211
ext3_free_blocks_sb: bit already cleared for block 888845
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216209
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888844
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216208
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888843
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216207
EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888833
EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216064
mmcblk0: error -110 transferring data, sector 3823096, nr 536, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 3823097
end_request: I/O error, dev mmcblk0, sector 3823104
3823112
end_request: I/O error, dev mmcblk0, sector 3823120
end_request: I/O error, dev mmcblk0, sector 3823128
end_request: I/O error, dev mmcblk0, sector 3823136
end_request: I/O error, dev mmcblk0, sector 3823144
end_request: I/O error, dev mmcblk0, sector 3823152
end_request: I/O error, dev mmcblk0, sector 3823160
end_request: I/O error, dev mmcblk0, sector 3823168
end_request: I/O error, dev mmcblk0, sector 3823176
end_request: I/O error, dev mmcblk0, sector 3823184
end_request: I/O error, dev mmcblk0, sector 3823192
end_request: I/O error, dev mmcblk0, sector 3823200
end_request: I/O error, dev mmcblk0, sector 3823208
end_request: I/O error, dev mmcblk0, sector 3823216
end_request: I/O error, dev mmcblk0, sector 3823224
end_request: I/O error, dev mmcblk0, sector 3823232
end_request: I/O error, dev mmcblk0, sector 3823240
end_request: I/O error, dev mmcblk0, sector 3823248
end_request: I/O
error, dev mmcblk0, sector 3823256
end_request: I/O error, dev mmcblk0, sector 3823264
end_request: I/O error, dev mmcblk0, sector 3823272
end_request: I/O error, dev mmcblk0, sector 3823280
end_request: I/O error, dev mmcblk0, sector 3823288
end_request: I/O error, dev mmcblk0, sector 3823296
end_request: I/O error, dev mmcblk0, sector 3823304
end_request: I/O error, dev mmcblk0, sector 3823312
end_request: I/O error, dev mmcblk0, sector 3823320
end_request: I/O error, dev mmcblk0, sector 3823328
end_request: I/O error, dev mmcblk0, sector 3823336
end_request: I/O error, dev mmcblk0, sector 3823344
end_request: I/O error, dev mmcblk0, sector 3823352
end_request: I/O error, dev mmcblk0, sector 3823360
end_request: I/O error, dev mmcblk0, sector 3823368
end_request: I/O error, dev mmcblk0, sector 3823376
end_request: I/O error, dev mmcblk0, sector 3823384
3823392
end_request: I/O error, dev mmcblk0, sector 3823400
end_request: I/O error, dev mmcblk0, sector 3823408
end_request: I/O error, dev mmcblk0, sector 3823416
end_request: I/O error, dev mmcblk0, sector 3823424
end_request: I/O error, dev mmcblk0, sector 3823432
end_request: I/O error, dev mmcblk0, sector 3823440
end_request: I/O error, dev mmcblk0, sector 3823448
end_request: I/O error, dev mmcblk0, sector 3823456
end_request: I/O error, dev mmcblk0, sector 3823464
end_request: I/O error, dev mmcblk0, sector 3823472
end_request: I/O error, dev mmcblk0, sector 3823480
end_request: I/O error, dev mmcblk0, sector 3823488
end_request: I/O error, dev mmcblk0, sector 3823496
end_request: I/O error, dev mmcblk0, sector 3823504
end_request: I/O error, dev mmcblk0, sector 3823512
end_request: I/O error, dev mmcblk0, sector 3823520
end_request: I/O error, dev mmcblk0, sector 3823528
end_request: I/O
error, dev mmcblk0, sector 3823536
end_request: I/O error, dev mmcblk0, sector 3823544
end_request: I/O error, dev mmcblk0, sector 3823552
end_request: I/O error, dev mmcblk0, sector 3823560
end_request: I/O error, dev mmcblk0, sector 3823568
end_request: I/O error, dev mmcblk0, sector 3823576
end_request: I/O error, dev mmcblk0, sector 3823584
end_request: I/O error, dev mmcblk0, sector 3823592
end_request: I/O error, dev mmcblk0, sector 3823600
end_request: I/O error, dev mmcblk0, sector 3823608
end_request: I/O error, dev mmcblk0, sector 3823616
end_request: I/O error, dev mmcblk0, sector 3823624
mmcblk0: error -110 transferring data, sector 3805104, nr 8, card status 0xc00
end_request: I/O error, dev mmcblk0, sector 3805105
Buffer I/O error on device mmcblk0p2, logical block 459254
JBD: I/O error detected when
updating journal superblock for mmcblk0p2.
WARNING: at fs/ext3/inode.c:1645 ext3_writeback_writepage+0x50/0x150()
[<c0060654>] (warn_slowpath_common+0x4c/0x64) from [<c0060684>] (warn_slowpath_null+0x18/0x1c)
[<c0060684>] (warn_slowpath_null+0x18/0x1c) from [<c01120f4>] (ext3_writeback_writepage+0x50/0x150)
[<c01120f4>] (ext3_writeback_writepage+0x50/0x150) from [<c00a37e8>] (__writepage+0x14/0x5c)
[<c00a37e8>] (__writepage+0x14/0x5c) from [<c00a3da4>] (write_cache_pages+0x204/0x300)
[<c00a3da4>] (write_cache_pages+0x204/0x300) from [<c00a3ee0>]
(generic_writepages+0x40/0x5c)
[<c00a3ee0>] (generic_writepages+0x40/0x5c) from [<c00def6c>] (writeback_single_inode+0xa0/0x1ac)
[<c00def6c>] (writeback_single_inode+0xa0/0x1ac) from [<c00df594>] (writeback_sb_inodes+0x8c/0xfc)
[<c00df594>] (writeback_sb_inodes+0x8c/0xfc) from [<c00dfa94>] (writeback_inodes_wb+0x114/0x130)
[<c00dfa94>] (writeback_inodes_wb+0x114/0x130) from [<c00dfcb0>] (wb_writeback+0x200/0x280)
[<c00dfcb0>] (wb_writeback+0x200/0x280) from [<c00dfe50>] (wb_do_writeback+0x120/0x1b4)
[<c00dfe50>] (wb_do_writeback+0x120/0x1b4) from [<c00dff4c>] (bdi_writeback_thread+0x68/0x158)
[<c00dff4c>] (bdi_writeback_thread+0x68/0x158) from [<c00758d8>] (kthread+0x7c/0x84)
[<c00758d8>] (kthread+0x7c/0x84) from [<c003cd14>] (kernel_thread_exit+0x0/0x8)
---[ end trace 53e65c8e2ab3e15a ]---
root@usrp-e1xx:~#
To: Joel Parker joelparker27@yahoo.com
Cc: "usrp-users@lists.ettus.com" usrp-users@lists.ettus.com
Sent: Friday, May 11, 2012 10:29 AM
On 05/11/2012 11:22 AM, Joel Parker wrote:
I am trying to compile OpenBTS on the E100 and am having issues downloading the code because it complains about a read-only file system. Where is a read / write area that I can download and build the source ?
What version of the root file system are you using? It like you are
seeing the MMC timeout issue. Can you look at the boot messages and see
if you see mmc timeout messages?
This is a little odd, since you (I think) just managed to install
subversion, which would need a rw file system.
Philip
root@usrp-e1xx:~# svn co http://wush.net/svn/range/software/public
A    public/RRLP
A    public/RRLP/trunk
A    public/RRLP/trunk/MAP-CH-DataTypes.asn
A    public/RRLP/trunk/rrtest
A    public/RRLP/trunk/decode
A
public/RRLP/trunk/MAP-ExtensionDataTypes.asn
A    public/RRLP/trunk/rrlpserver.erl
A    public/RRLP/trunk/testall.erl
A    public/RRLP/trunk/setUpFiles.sh
A    public/RRLP/trunk/MAP-ER-DataTypes.asn
  public/RRLP/trunk/parseargs.escript
A    public/RRLP/trunk/sendrrlp.escript
A    public/RRLP/trunk/MAP-CommonDataTypes.asn
A    public/RRLP/trunk/MAP-OM-DataTypes.asn
A    public/RRLP/trunk/tests
A    public/RRLP/trunk/tests/additional_assitance_data.per
A    public/RRLP/trunk/tests/ms_based.per
A    public/RRLP/trunk/tests/temp.per
A    public/RRLP/trunk/tests/runtest.py
A    public/RRLP/trunk/tests/good_pos.per
A    public/RRLP/trunk/MAP-MS-DataTypes.asn
A
public/RRLP/trunk/MAP-SM-DataTypes.asn
A    public/RRLP/trunk/MAP-BS-Code.asn
A    public/RRLP/trunk/rrlpserver.cgi
A    public/RRLP/trunk/rrfake
A    public/RRLP/trunk/MAP-SS-DataTypes.asn
  public/RRLP/trunk/Makefile
A    public/RRLP/trunk/testall.sh
A    public/RRLP/trunk/RRLP-Components.asn
A    public/RRLP/trunk/send_many_rrlp.escript
A    public/RRLP/trunk/parseargsbody.erl
A    public/RRLP/trunk/xrrlp.erl
A    public/RRLP/trunk/MAP-SS-Code.asn
A    public/RRLP/trunk/sendrrlpbody.erl
A    public/RRLP/trunk/MAP-TS-Code.asn
A    public/RRLP/trunk/RRLP.set.asn
A    public/RRLP/trunk/MAP-Protocol.asn
A    public/RRLP/trunk/README
A
public/RRLP/trunk/util.erl
A    public/RRLP/trunk/log2per.py
A    public/RRLP/trunk/file2bin.escript
A    public/RRLP/trunk/RRLP-Messages.asn
A    public/RRLP/trunk/MAP-LCS-DataTypes.asn
svn: Can't change perms of file
  'public/RRLP/trunk/.svn/entries': Read-only file system
USRP-users mailing list
USRP-users@lists.ettus.com
Well I guess I spoke early. In the middle of the OpenBTS download it started complaining again. When I look at dmesg its mad about i/o blocks : mmcblk0: error -110 transferring data, sector 1179696, nr 8, card status 0xc00 end_request: I/O error, dev mmcblk0, sector 1179697 Buffer I/O error on device mmcblk0p2, logical block 131078 lost page write due to I/O error on mmcblk0p2 mmcblk0: error -110 transferring data, sector 3818504, nr 48, card status 0xc00 end_request: I/O error, dev mmcblk0, sector 3818505 end_request: I/O error, dev mmcblk0, sector 3818512 end_request: I/O error, dev mmcblk0, sector 3818520 end_request: I/O error, dev mmcblk0, sector 3818528 end_request: I/O error, dev mmcblk0, sector 3818536 end_request: I/O error, dev mmcblk0, sector 3818544 Aborting journal on device mmcblk0p2. EXT3-fs (mmcblk0p2): error in ext3_new_inode: Journal has aborted EXT3-fs (mmcblk0p2): error in ext3_create: Journal has aborted EXT3-fs (mmcblk0p2): error: ext3_journal_start_sb: Detected aborted journal EXT3-fs (mmcblk0p2): error: remounting filesystem read-only Do I need to do an fdsk or something equivalent or is this a know issue ? -- Joel Parker ________________________________ From: Joel Parker <joelparker27@yahoo.com> To: Philip Balister <philip@opensdr.com> Sent: Friday, May 11, 2012 11:00 AM Subject: Re: [USRP-users] Read Only File System ? I just rebooted from command line and it came up clean. Bizarre. -- Joel ________________________________ From: Joel Parker <joelparker27@yahoo.com> To: Philip Balister <philip@opensdr.com> Sent: Friday, May 11, 2012 10:36 AM Subject: Re: [USRP-users] Read Only File System ? Yeah, same thing I thought but svn also had errors when installing but seems to work ? root@usrp-e1xx:~# opkg install subversion Installing subversion (1.6.5-r1.9) to root... Downloading http://feeds.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a/base/subversion_1.6.5-r1.9_armv7a.ipk. Installing libaprutil-1-0 (1.3.10-r1.9) to root... Downloading http://feeds.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a/base/libaprutil-1-0_1.3.10-r1.9_armv7a.ipk. Installing libapr-1-0 (1.4.2-r0.9) to root... Downloading http://feeds.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a/base/libapr-1-0_1.4.2-r0.9_armv7a.ipk. Collected errors:  * opkg_prep_intercepts: Failed to make temp dir /var/lib/opkg/tmp/opkg-lK8a4R/opkg-intercept-2uyF1V: Invalid argument. I don't see timeout issues but do see many i/o errors with the mmc. This is the first time I ever powered this device up ... very strange. Here is the output from dmesg: Linux version 3.0.0 (balister@octopus) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #1 Tue Nov 15 14:07:23 EST 2011 CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: Gumstix Overo Reserving 12582912 bytes SDRAM for VRAM Memory policy: ECC disabled, Data cache writeback OMAP3630 ES1.2 (l2cache iva sgx neon isp 192mhz_clk ) SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x10000 On node 0 totalpages: 128000 free_area_init_node: node 0, pgdat c0599010, node_mem_map c05fe000   Normal zone: 1024 pages used for memmap   Normal zone: 0 pages reserved   Normal zone: 126976 pages, LIFO batch:31 Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz Reprogramming SDRC clock to 332000000 Hz pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 pcpu-alloc: [0] 0 Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 126976 Kernel command line: console=ttyO2,115200n8 mpurate=720 vram=12M omapfb.mode=dvi:1024x768MR-16@60 omapdss.def_disp=dvi root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory: 500MB = 500MB total Memory: 501328k/501328k available, 22960k reserved, 0K highmem Virtual kernel memory layout:     vector  : 0xffff0000 - 0xffff1000   (   4 kB)     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)     DMA     : 0xffc00000 - 0xffe00000   (   2 MB)     vmalloc : 0xe0800000 - 0xf8000000   ( 376 MB)     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)     modules : 0xbf000000 - 0xc0000000   (  16 MB)       .init : 0xc0008000 - 0xc0037000   ( 188 kB)       .text : 0xc0037000 - 0xc0554f94   (5240 kB)       .data : 0xc0556000 - 0xc05996c0   ( 270 kB)        .bss : 0xc05996e4 - 0xc05fd684   ( 400 kB) NR_IRQS:410 IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts Total of 96 interrupts on 1 active controller OMAP clockevent source: GPTIMER1 at 32768 Hz sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms Console: colour dummy device 80x30 Calibrating delay loop... 597.64 BogoMIPS (lpj=2334720) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok devtmpfs: initialized omap_hwmod: gpt12_fck: missing clockdomain for gpt12_fck. print_constraints: dummy: NET: Registered protocol family 16 GPMC revision 5.0 OMAP GPIO hardware version 2.5 OMAP GPIO hardware version 2.5 OMAP GPIO hardware version 2.5 OMAP GPIO hardware version 2.5 OMAP GPIO hardware version 2.5 OMAP GPIO hardware version 2.5 omap_mux_init: Add partition: #1: core, flags: 0 Found NAND on CS0 Registering NAND on CS0 Setup up gpmc timing. GPMC_CONFIG1 reg: 28001002 GPMC_CONFIG2 reg: 30600 GPMC_CONFIG3 reg: 20201 GPMC_CONFIG4 reg: 3000501 GPMC_CONFIG5 reg: 1030306 GPMC_CONFIG6 reg: 83030000 GPMC_CONFIG1 reg: 1000 GPMC_CONFIG2 reg: 141f00 GPMC_CONFIG3 reg: 20201 GPMC_CONFIG4 reg: 14001f00 GPMC_CONFIG5 reg: 11e151f GPMC_CONFIG6 reg: f030f80 hw-breakpoint: debug architecture 0x4 unsupported. omap_device: omap-mcbsp.2: alias fck already exists omap_device: omap-mcbsp.3: alias fck already exists Switched to new clocking rate (Crystal/Core/MPU): 26.0/332/720 MHz OMAP DMA hardware revision 5.0 bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600 kHz twl4030: PIH (irq 7) chaining IRQs 368..375 twl4030: power (irq 373) chaining IRQs 376..383 twl4030: gpio (irq 368) chaining IRQs 384..401 machine_constraints_voltage: VUSB1V5: override min_uV, 1 -> 1500000 machine_constraints_voltage: VUSB1V5: override max_uV, 2147483647 -> 1500000 print_constraints: VUSB1V5: 1500 mV normal standby machine_constraints_voltage: VUSB1V8: override min_uV, 1 -> 1800000 machine_constraints_voltage: VUSB1V8: override max_uV, 2147483647 -> 1800000 print_constraints: VUSB1V8: 1800 mV normal standby machine_constraints_voltage: VUSB3V1: override min_uV, 1 -> 3100000 machine_constraints_voltage: VUSB3V1: override max_uV, 2147483647 -> 3100000 print_constraints: VUSB3V1: 3100 mV normal standby twl4030_usb twl4030_usb: HW_CONDITIONS 0x10/16; link 0 twl4030_usb twl4030_usb: Initialized TWL4030 USB module print_constraints: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby print_constraints: VDAC: 1800 mV normal standby print_constraints: VDVI: 1800 mV normal standby omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz Advanced Linux Sound Architecture Driver Version 1.0.24. Bluetooth: Core ver 2.16 NET: Registered protocol family 31 Bluetooth: HCI device and connection manager initialized Bluetooth: HCI socket layer initialized Bluetooth: L2CAP socket layer initialized Bluetooth: SCO socket layer initialized Switching to clocksource 32k_counter Switched to NOHz mode on CPU #0 musb-hdrc: version 6.0, musb-dma, host twl4030_usb twl4030_usb: twl4030_phy_resume musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn) musb-hdrc: MHDRC RTL version 1.800 musb-hdrc: setup fifo_mode 4 musb-hdrc: 28/31 max ep, 16384/16384 memory musb-hdrc musb-hdrc: MUSB HDRC host driver drivers/usb/core/inode.c: creating file 'devices' drivers/usb/core/inode.c: creating file '001' musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 1 usb usb1: default language 0x0409 usb usb1: udev 1, busnum 1, minor = 0 usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: MUSB HDRC host driver usb usb1: Manufacturer: Linux 3.0.0 musb-hcd usb usb1: SerialNumber: musb-hdrc usb usb1: usb_probe_device usb usb1: configuration #1 chosen from 1 choice usb usb1: adding 1-0:1.0 (config #1, interface 0) hub 1-0:1.0: usb_probe_interface hub 1-0:1.0: usb_probe_interface - got id hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected hub 1-0:1.0: standalone hub hub 1-0:1.0: individual port power switching hub 1-0:1.0: no over-current protection hub 1-0:1.0: Single TT hub 1-0:1.0: TT requires at most 8 FS bit times (666 ns) hub 1-0:1.0: power on to power good time: 10ms hub 1-0:1.0: 100mA bus power budget for each child hub 1-0:1.0: local power source is good hub 1-0:1.0: enabling power on all ports drivers/usb/core/inode.c: creating file '001' musb-hdrc musb-hdrc: USB Host mode controller at fa0ab000 using DMA, IRQ 92 NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 4, 65536 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. VFS: Disk quotas dquot_6.5.2 Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Registering unionfs 2.5.9.2 (for 3.0.0-rc4) JFFS2 version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc. msgmni has been set to 979 Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) OMAP DSS rev 2.0 Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0 omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1 omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2 console [ttyO2] enabled hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000 omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a OMAP UART3 brd: module loaded loop: module loaded twl4030_usb twl4030_usb: HW_CONDITIONS 0x50/80; link 0 twl4030_usb twl4030_usb: twl4030_phy_suspend twl4030_usb twl4030_usb: HW_CONDITIONS 0x10/16; link 0 omap2-nand driver initializing ONFI flash detected NAND device: Manufacturer ID: 0x2c, Chip ID: 0xbc (Micron NAND 512MiB 1,8V 16-bit) Creating 5 MTD partitions on "omap2-nand.0": 0x000000000000-0x000000080000 : "xloader" 0x000000080000-0x000000240000 : "uboot" 0x000000240000-0x000000280000 : "uboot environment" 0x000000280000-0x000000680000 : "linux" 0x000000680000-0x000020000000 : "rootfs" smsc911x: Driver version 2008-10-21 smsc911x-mdio: probed smsc911x smsc911x.0: eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, irq=-1) smsc911x smsc911x.0: eth0: MAC Address: a0:36:fa:85:31:b7 usbcore: registered new interface driver asix usbcore: registered new interface driver cdc_ether cdc_ncm: 01-June-2011 usbcore: registered new interface driver cdc_ncm ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver ehci_hcd: block sizes: qh 60 qtd 96 itd 160 sitd 96 ehci-omap ehci-omap.0: failed to get ehci port1 regulator ehci-omap ehci-omap.0: phy reset operation timed out ehci-omap ehci-omap.0: reset hcs_params 0x1313 dbg=0 cc=1 pcc=3 ordered ports=3 ehci-omap ehci-omap.0: reset hcc_params 0016 thresh 1 uframes 256/512/1024 park ehci-omap ehci-omap.0: OMAP-EHCI Host Controller drivers/usb/core/inode.c: creating file '002' ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2 ehci-omap ehci-omap.0: park 0 ehci-omap ehci-omap.0: irq 77, io mem 0x48064800 ehci-omap ehci-omap.0: reset command 0080b02  park=3 ithresh=8 period=1024 Reset HALT ehci-omap ehci-omap.0: init command 0010005 (park)=0 ithresh=1 period=512 RUN ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00 usb usb2: default language 0x0409 usb usb2: udev 1, busnum 2, minor = 128 usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb2: Product: OMAP-EHCI Host Controller usb usb2: Manufacturer: Linux 3.0.0 ehci_hcd usb usb2: SerialNumber: ehci-omap.0 usb usb2: usb_probe_device usb usb2: configuration #1 chosen from 1 choice usb usb2: adding 2-0:1.0 (config #1, interface 0) hub 2-0:1.0: usb_probe_interface hub 2-0:1.0: usb_probe_interface - got id hub 2-0:1.0: USB hub found hub 2-0:1.0: 3 ports detected hub 2-0:1.0: standalone hub hub 2-0:1.0: individual port power switching hub 2-0:1.0: individual port over-current protection hub 2-0:1.0: power on to power good time: 20ms hub 2-0:1.0: local power source is good hub 2-0:1.0: enabling power on all ports drivers/usb/core/inode.c: creating file '001' ehci-omap ehci-omap.0: ...powerup ports... Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mousedev: PS/2 mouse device common for all mice twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0 twl_rtc twl_rtc: Power up reset detected. i2c /dev entries driver OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec Bluetooth: HCI UART driver ver 2.2 Bluetooth: HCI H4 protocol initialized Bluetooth: HCI BCSP protocol initialized Bluetooth: HCILL protocol initialized cpuidle: using governor ladder cpuidle: using governor menu Registered led device: overo:blue:COM usbcore: registered new interface driver usbhid usbhid: USB HID core driver usbcore: registered new interface driver snd-usb-audio overo SoC init hub 2-0:1.0: state 7 ports 3 chg 0000 evt 0000 asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok ALSA device list:   #0: overo oprofile: hardware counters not available oprofile: using timer interrupt. TCP cubic registered NET: Registered protocol family 17 NET: Registered protocol family 15 Bluetooth: RFCOMM TTY layer initialized Bluetooth: RFCOMM socket layer initialized Bluetooth: RFCOMM ver 1.11 Bluetooth: BNEP (Ethernet Emulation) ver 1.3 Bluetooth: BNEP filters: protocol multicast Bluetooth: HIDP (Human Interface Emulation) ver 1.2 Registering the dns_resolver key type VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 ThumbEE CPU extension supported. sr_init: No PMIC hook to init smartreflex smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized clock: disabling unused clocks to save power fbcvt: 1024x768@60: CVT Name - .786M3-R Console: switching to colour frame buffer device 128x48 regulator_init_complete: VDAC: incomplete constraints, leaving on twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:20 UTC (946684820) Waiting for root device /dev/mmcblk0p2... mmc0: host does not support reading read-only switch. assuming write-enable. mmc0: new SDHC card at address b368 mmcblk0: mmc0:b368 SDC   3.84 GiB  mmcblk0: p1 p2 EXT3-fs: barriers not enabled kjournald starting.  Commit interval 5 seconds EXT3-fs (mmcblk0p2): using internal journal EXT3-fs (mmcblk0p2): recovery complete EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode VFS: Mounted root (ext3 filesystem) on device 179:2. devtmpfs: mounted Freeing init memory: 188K NET: Registered protocol family 10 usrp_e entering driver initialization usrp_e data struct malloc'd. usrp_e Data initialized.. usrp_e major number : 249 Getting Chip Select Got CS4, address = 1000000 Got CS6, address = 2000000 usrp_e Driver Initialized. udevd[102]: starting version 171 smsc911x smsc911x.0: eth0: SMSC911x/921x identified at 0xe086a000, IRQ: 336 smsc911x smsc911x.0: eth0: SMSC911x/921x identified at 0xe086a000, IRQ: 336 eth0: no IPv6 routers present smsc911x smsc911x.0: eth0: SMSC911x/921x identified at 0xe086a000, IRQ: 336 usrp_e open called, use_count = 0 rx_dma->ch 4 tx_dma->ch 5 usrp: leaving open usrp_e release called Waiting for DMA to become inactive Freeing gpio irq's Freeing DMA channels usrp_e open called, use_count = 0 rx_dma->ch 5 tx_dma->ch 6 usrp: leaving open Size = 2105344, expected sixe = 2105344 usrp_e release called Waiting for DMA to become inactive Freeing gpio irq's Freeing DMA channels eth0: no IPv6 routers present mmcblk0: error -110 transferring data, sector 438648, nr 8, card status 0xc00 end_request: I/O error, dev mmcblk0, sector 438649 Buffer I/O error on device mmcblk0p2, logical block 38447 lost page write due to I/O error on mmcblk0p2 mmcblk0: error -110 transferring data, sector 779688, nr 8, card status 0xc00 end_request: I/O error, dev mmcblk0, sector 779689 Buffer I/O error on device mmcblk0p2, logical block 81077 lost page write due to I/O error on mmcblk0p2 mmcblk0: error -110 transferring data, sector 788864, nr 8, card status 0xc00 end_request: I/O error, dev mmcblk0, sector 788865 Buffer I/O error on device mmcblk0p2, logical block 82224 lost page write due to I/O error on mmcblk0p2 mmcblk0: error -110 transferring data, sector 1864744, nr 8, card status 0xc00 end_request: I/O error, dev mmcblk0, sector 1864745 Buffer I/O error on device mmcblk0p2, logical block 216709 lost page write due to I/O error on mmcblk0p2 mmcblk0: error -110 sending read/write command, response 0x900, card status 0xe00 mmcblk0: error -110 transferring data, sector 1874144, nr 8, card status 0xc00 end_request: I/O error, dev mmcblk0, sector 1874145 Buffer I/O error on device mmcblk0p2, logical block 217884 lost page write due to I/O error on mmcblk0p2 mmcblk0: error -110 transferring data, sector 1968272, nr 8, card status 0xc00 end_request: I/O error, dev mmcblk0, sector 1968273 Buffer I/O error on device mmcblk0p2, logical block 229650 lost page write due to I/O error on mmcblk0p2 mmcblk0: error -110 transferring data, sector 2293616, nr 8, card status 0xc00 end_request: I/O error, dev mmcblk0, sector 2293617 Buffer I/O error on device mmcblk0p2, logical block 270318 lost page write due to I/O error on mmcblk0p2 mmcblk0: error -110 transferring data, sector 5113152, nr 624, card status 0xc00 end_request: I/O error, dev mmcblk0, sector 5113153 Buffer I/O error on device mmcblk0p2, logical block 622760 lost page write due to I/O error on mmcblk0p2 end_request: I/O error, dev mmcblk0, sector 5113160 Buffer I/O error on device mmcblk0p2, logical block 622761 lost page write due to I/O error on mmcblk0p2 end_request: I/O error, dev mmcblk0, sector 5113168 Buffer I/O error on device mmcblk0p2, logical block 622762 lost page write due to I/O error on mmcblk0p2 end_request: I/O error, dev mmcblk0, sector 5113176 Buffer I/O error on device mmcblk0p2, logical block 622763 lost page write due to I/O error on mmcblk0p2 end_request: I/O error, dev mmcblk0, sector 5113184 Buffer I/O error on device mmcblk0p2, logical block 622764 lost page write due to I/O error on mmcblk0p2 end_request: I/O error, dev mmcblk0, sector 5113192 Buffer I/O error on device mmcblk0p2, logical block 622765 lost page write due to I/O error on mmcblk0p2 end_request: I/O error, dev mmcblk0, sector 5113200 Buffer I/O error on device mmcblk0p2, logical block 622766 lost page write due to I/O error on mmcblk0p2 end_request: I/O error, dev mmcblk0, sector 5113208 Buffer I/O error on device mmcblk0p2, logical block 622767 lost page write due to I/O error on mmcblk0p2 end_request: I/O error, dev mmcblk0, sector 5113216 Buffer I/O error on device mmcblk0p2, logical block 622768 lost page write due to I/O error on mmcblk0p2 end_request: I/O error, dev mmcblk0, sector 5113224 end_request: I/O error, dev mmcblk0, sector 5113232 end_request: I/O error, dev mmcblk0, sector 5113240 end_request: I/O error, dev mmcblk0, sector 5113248 end_request: I/O error, dev mmcblk0, sector 5113256 end_request: I/O error, dev mmcblk0, sector 5113264 end_request: I/O error, dev mmcblk0, sector 5113272 end_request: I/O error, dev mmcblk0, sector 5113280 end_request: I/O error, dev mmcblk0, sector 5113288 end_request: I/O error, dev mmcblk0, sector 5113296 end_request: I/O error, dev mmcblk0, sector 5113304 end_request: I/O error, dev mmcblk0, sector 5113312 end_request: I/O error, dev mmcblk0, sector 5113320 end_request: I/O error, dev mmcblk0, sector 5113328 end_request: I/O error, dev mmcblk0, sector 5113336 end_request: I/O error, dev mmcblk0, sector 5113344 end_request: I/O error, dev mmcblk0, sector 5113352 end_request: I/O error, dev mmcblk0, sector 5113360 end_request: I/O error, dev mmcblk0, sector 5113368 end_request: I/O error, dev mmcblk0, sector 5113376 end_request: I/O error, dev mmcblk0, sector 5113384 end_request: I/O error, dev mmcblk0, sector 5113392 end_request: I/O error, dev mmcblk0, sector 5113400 end_request: I/O error, dev mmcblk0, sector 5113408 end_request: I/O error, dev mmcblk0, sector 5113416 end_request: I/O error, dev mmcblk0, sector 5113424 end_request: I/O error, dev mmcblk0, sector 5113432 end_request: I/O error, dev mmcblk0, sector 5113440 end_request: I/O error, dev mmcblk0, sector 5113448 end_request: I/O error, dev mmcblk0, sector 5113456 end_request: I/O error, dev mmcblk0, sector 5113464 end_request: I/O error, dev mmcblk0, sector 5113472 end_request: I/O error, dev mmcblk0, sector 5113480 end_request: I/O error, dev mmcblk0, sector 5113488 end_request: I/O error, dev mmcblk0, sector 5113496 end_request: I/O error, dev mmcblk0, sector 5113504 end_request: I/O error, dev mmcblk0, sector 5113512 end_request: I/O error, dev mmcblk0, sector 5113520 end_request: I/O error, dev mmcblk0, sector 5113528 end_request: I/O error, dev mmcblk0, sector 5113536 end_request: I/O error, dev mmcblk0, sector 5113544 end_request: I/O error, dev mmcblk0, sector 5113552 end_request: I/O error, dev mmcblk0, sector 5113560 end_request: I/O error, dev mmcblk0, sector 5113568 end_request: I/O error, dev mmcblk0, sector 5113576 end_request: I/O error, dev mmcblk0, sector 5113584 end_request: I/O error, dev mmcblk0, sector 5113592 end_request: I/O error, dev mmcblk0, sector 5113600 end_request: I/O error, dev mmcblk0, sector 5113608 end_request: I/O error, dev mmcblk0, sector 5113616 end_request: I/O error, dev mmcblk0, sector 5113624 end_request: I/O error, dev mmcblk0, sector 5113632 end_request: I/O error, dev mmcblk0, sector 5113640 end_request: I/O error, dev mmcblk0, sector 5113648 end_request: I/O error, dev mmcblk0, sector 5113656 end_request: I/O error, dev mmcblk0, sector 5113664 end_request: I/O error, dev mmcblk0, sector 5113672 end_request: I/O error, dev mmcblk0, sector 5113680 end_request: I/O error, dev mmcblk0, sector 5113688 end_request: I/O error, dev mmcblk0, sector 5113696 end_request: I/O error, dev mmcblk0, sector 5113704 end_request: I/O error, dev mmcblk0, sector 5113712 end_request: I/O error, dev mmcblk0, sector 5113720 end_request: I/O error, dev mmcblk0, sector 5113728 end_request: I/O error, dev mmcblk0, sector 5113736 end_request: I/O error, dev mmcblk0, sector 5113744 end_request: I/O error, dev mmcblk0, sector 5113752 end_request: I/O error, dev mmcblk0, sector 5113760 end_request: I/O error, dev mmcblk0, sector 5113768 mmcblk0: error -110 transferring data, sector 5155920, nr 72, card status 0xc00 end_request: I/O error, dev mmcblk0, sector 5155921 end_request: I/O error, dev mmcblk0, sector 5155928 end_request: I/O error, dev mmcblk0, sector 5155936 end_request: I/O error, dev mmcblk0, sector 5155944 end_request: I/O error, dev mmcblk0, sector 5155952 end_request: I/O error, dev mmcblk0, sector 5155960 end_request: I/O error, dev mmcblk0, sector 5155968 end_request: I/O error, dev mmcblk0, sector 5155976 end_request: I/O error, dev mmcblk0, sector 5155984 mmcblk0: error -110 sending read/write command, response 0x900, card status 0xe00 mmcblk0: error -110 transferring data, sector 7210904, nr 16, card status 0xc00 end_request: I/O error, dev mmcblk0, sector 7210905 quiet_error: 78 callbacks suppressed Buffer I/O error on device mmcblk0p2, logical block 884979 lost page write due to I/O error on mmcblk0p2 end_request: I/O error, dev mmcblk0, sector 7210912 Buffer I/O error on device mmcblk0p2, logical block 884980 lost page write due to I/O error on mmcblk0p2 mmcblk0: error -110 transferring data, sector 7241736, nr 16, card status 0xc00 end_request: I/O error, dev mmcblk0, sector 7241737 Buffer I/O error on device mmcblk0p2, logical block 888833 lost page write due to I/O error on mmcblk0p2 end_request: I/O error, dev mmcblk0, sector 7241744 Buffer I/O error on device mmcblk0p2, logical block 888834 lost page write due to I/O error on mmcblk0p2 EXT3-fs error (device mmcblk0p2): ext3_find_entry: reading directory #216064 offset 0 ------------[ cut here ]------------ WARNING: at fs/inode.c:901 unlock_new_inode+0x20/0x40() Modules linked in: usrp_e ipv6 [<c0040c7c>] (unwind_backtrace+0x0/0xe0) from [<c0060654>] (warn_slowpath_common+0x4c/0x64) [<c0060654>] (warn_slowpath_common+0x4c/0x64) from [<c0060684>] (warn_slowpath_null+0x18/0x1c) [<c0060684>] (warn_slowpath_null+0x18/0x1c) from [<c00d6ac0>] (unlock_new_inode+0x20/0x40) [<c00d6ac0>] (unlock_new_inode+0x20/0x40) from [<c011138c>] (ext3_new_inode+0x868/0x89c) [<c011138c>] (ext3_new_inode+0x868/0x89c) from [<c0117a74>] (ext3_mkdir+0xa8/0x2d0) [<c0117a74>] (ext3_mkdir+0xa8/0x2d0) from [<c00cd6fc>] (vfs_mkdir+0x68/0x98) [<c00cd6fc>] (vfs_mkdir+0x68/0x98) from [<c00d02c0>] (sys_mkdirat+0x80/0xcc) [<c00d02c0>] (sys_mkdirat+0x80/0xcc) from [<c003c480>] (ret_fast_syscall+0x0/0x30) ---[ end trace 53e65c8e2ab3e159 ]--- mmcblk0: error -110 transferring data, sector 7258120, nr 16, card status 0xc00 end_request: I/O error, dev mmcblk0, sector 7258121 Buffer I/O error on device mmcblk0p2, logical block 890881 lost page write due to I/O error on mmcblk0p2 end_request: I/O error, dev mmcblk0, sector 7258128 Buffer I/O error on device mmcblk0p2, logical block 890882 lost page write due to I/O error on mmcblk0p2 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913496 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913497 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913498 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913499 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913502 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913592 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913593 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913596 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913620 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913871 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913878 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913879 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913881 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913882 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913883 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913884 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913885 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913886 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913887 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 913880 EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216210 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 892928 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 892929 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894333 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894334 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894335 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894336 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894337 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894338 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894339 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894340 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894341 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894342 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894344 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894345 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894346 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894347 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894348 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894349 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894350 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894351 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894352 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894353 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894354 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894355 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894356 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894357 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894358 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894359 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894360 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894361 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894362 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894363 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894364 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894365 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894366 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894367 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894368 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894369 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894370 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894371 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894372 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894373 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894374 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894375 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894376 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894377 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894378 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894379 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894380 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894381 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894382 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894383 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894384 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894385 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894386 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894387 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894388 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894389 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894390 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894391 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894392 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894393 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894394 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894395 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894396 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894397 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894398 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894399 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894400 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894401 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894402 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894403 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894404 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894405 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894406 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894407 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894408 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894409 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894410 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894411 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894412 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894413 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894414 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894415 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894416 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894417 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894418 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894419 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894420 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894421 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894422 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894423 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894424 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894425 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894426 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894427 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894428 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894429 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894430 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894431 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894432 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894433 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894434 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894435 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894436 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894437 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894438 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894439 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894440 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894441 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894442 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894443 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894444 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894445 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894446 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894447 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894448 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894449 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894450 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894451 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894452 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894453 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894454 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894455 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894456 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894457 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894458 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894459 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894460 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894461 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894462 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894463 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894464 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894465 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894466 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894467 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894468 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894469 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894470 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894471 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894472 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894473 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894474 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894475 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894476 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894477 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894478 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894479 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894480 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894481 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894482 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894483 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894484 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894485 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894486 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894487 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894488 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894489 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894490 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894491 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894492 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894493 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894494 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894495 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894496 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894497 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894498 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894499 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894500 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894501 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894502 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894503 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894504 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894505 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894506 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894507 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894508 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894509 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894510 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894511 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 894343 EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216195 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899072 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899073 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899074 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899075 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899076 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899077 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899078 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899079 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899080 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899081 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899082 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899083 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899085 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899086 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 899084 EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216206 EXT3-fs error (device mmcblk0p2): htree_dirblock_to_tree: bad entry in directory #216196: rec_len % 4 != 0 - offset=0, inode=1801675088, rec_len=26465, name_len=101 EXT3-fs (mmcblk0p2): warning: empty_dir: bad directory (dir #216196) - no `.' or `..' EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888834 EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216196 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888847 EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216213 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888842 EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216212 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888846 EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216211 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888845 EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216209 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888844 EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216208 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888843 EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216207 EXT3-fs error (device mmcblk0p2): ext3_free_blocks_sb: bit already cleared for block 888833 EXT3-fs error (device mmcblk0p2): ext3_free_inode: bit already cleared for inode 216064 mmcblk0: error -110 transferring data, sector 3823096, nr 536, card status 0xc00 end_request: I/O error, dev mmcblk0, sector 3823097 end_request: I/O error, dev mmcblk0, sector 3823104 end_request: I/O error, dev mmcblk0, sector 3823112 end_request: I/O error, dev mmcblk0, sector 3823120 end_request: I/O error, dev mmcblk0, sector 3823128 end_request: I/O error, dev mmcblk0, sector 3823136 end_request: I/O error, dev mmcblk0, sector 3823144 end_request: I/O error, dev mmcblk0, sector 3823152 end_request: I/O error, dev mmcblk0, sector 3823160 end_request: I/O error, dev mmcblk0, sector 3823168 end_request: I/O error, dev mmcblk0, sector 3823176 end_request: I/O error, dev mmcblk0, sector 3823184 end_request: I/O error, dev mmcblk0, sector 3823192 end_request: I/O error, dev mmcblk0, sector 3823200 end_request: I/O error, dev mmcblk0, sector 3823208 end_request: I/O error, dev mmcblk0, sector 3823216 end_request: I/O error, dev mmcblk0, sector 3823224 end_request: I/O error, dev mmcblk0, sector 3823232 end_request: I/O error, dev mmcblk0, sector 3823240 end_request: I/O error, dev mmcblk0, sector 3823248 end_request: I/O error, dev mmcblk0, sector 3823256 end_request: I/O error, dev mmcblk0, sector 3823264 end_request: I/O error, dev mmcblk0, sector 3823272 end_request: I/O error, dev mmcblk0, sector 3823280 end_request: I/O error, dev mmcblk0, sector 3823288 end_request: I/O error, dev mmcblk0, sector 3823296 end_request: I/O error, dev mmcblk0, sector 3823304 end_request: I/O error, dev mmcblk0, sector 3823312 end_request: I/O error, dev mmcblk0, sector 3823320 end_request: I/O error, dev mmcblk0, sector 3823328 end_request: I/O error, dev mmcblk0, sector 3823336 end_request: I/O error, dev mmcblk0, sector 3823344 end_request: I/O error, dev mmcblk0, sector 3823352 end_request: I/O error, dev mmcblk0, sector 3823360 end_request: I/O error, dev mmcblk0, sector 3823368 end_request: I/O error, dev mmcblk0, sector 3823376 end_request: I/O error, dev mmcblk0, sector 3823384 end_request: I/O error, dev mmcblk0, sector 3823392 end_request: I/O error, dev mmcblk0, sector 3823400 end_request: I/O error, dev mmcblk0, sector 3823408 end_request: I/O error, dev mmcblk0, sector 3823416 end_request: I/O error, dev mmcblk0, sector 3823424 end_request: I/O error, dev mmcblk0, sector 3823432 end_request: I/O error, dev mmcblk0, sector 3823440 end_request: I/O error, dev mmcblk0, sector 3823448 end_request: I/O error, dev mmcblk0, sector 3823456 end_request: I/O error, dev mmcblk0, sector 3823464 end_request: I/O error, dev mmcblk0, sector 3823472 end_request: I/O error, dev mmcblk0, sector 3823480 end_request: I/O error, dev mmcblk0, sector 3823488 end_request: I/O error, dev mmcblk0, sector 3823496 end_request: I/O error, dev mmcblk0, sector 3823504 end_request: I/O error, dev mmcblk0, sector 3823512 end_request: I/O error, dev mmcblk0, sector 3823520 end_request: I/O error, dev mmcblk0, sector 3823528 end_request: I/O error, dev mmcblk0, sector 3823536 end_request: I/O error, dev mmcblk0, sector 3823544 end_request: I/O error, dev mmcblk0, sector 3823552 end_request: I/O error, dev mmcblk0, sector 3823560 end_request: I/O error, dev mmcblk0, sector 3823568 end_request: I/O error, dev mmcblk0, sector 3823576 end_request: I/O error, dev mmcblk0, sector 3823584 end_request: I/O error, dev mmcblk0, sector 3823592 end_request: I/O error, dev mmcblk0, sector 3823600 end_request: I/O error, dev mmcblk0, sector 3823608 end_request: I/O error, dev mmcblk0, sector 3823616 end_request: I/O error, dev mmcblk0, sector 3823624 Aborting journal on device mmcblk0p2. mmcblk0: error -110 transferring data, sector 3805104, nr 8, card status 0xc00 end_request: I/O error, dev mmcblk0, sector 3805105 Buffer I/O error on device mmcblk0p2, logical block 459254 lost page write due to I/O error on mmcblk0p2 JBD: I/O error detected when updating journal superblock for mmcblk0p2. EXT3-fs (mmcblk0p2): error: ext3_journal_start_sb: Detected aborted journal EXT3-fs (mmcblk0p2): error: remounting filesystem read-only ------------[ cut here ]------------ WARNING: at fs/ext3/inode.c:1645 ext3_writeback_writepage+0x50/0x150() Modules linked in: usrp_e ipv6 [<c0040c7c>] (unwind_backtrace+0x0/0xe0) from [<c0060654>] (warn_slowpath_common+0x4c/0x64) [<c0060654>] (warn_slowpath_common+0x4c/0x64) from [<c0060684>] (warn_slowpath_null+0x18/0x1c) [<c0060684>] (warn_slowpath_null+0x18/0x1c) from [<c01120f4>] (ext3_writeback_writepage+0x50/0x150) [<c01120f4>] (ext3_writeback_writepage+0x50/0x150) from [<c00a37e8>] (__writepage+0x14/0x5c) [<c00a37e8>] (__writepage+0x14/0x5c) from [<c00a3da4>] (write_cache_pages+0x204/0x300) [<c00a3da4>] (write_cache_pages+0x204/0x300) from [<c00a3ee0>] (generic_writepages+0x40/0x5c) [<c00a3ee0>] (generic_writepages+0x40/0x5c) from [<c00def6c>] (writeback_single_inode+0xa0/0x1ac) [<c00def6c>] (writeback_single_inode+0xa0/0x1ac) from [<c00df594>] (writeback_sb_inodes+0x8c/0xfc) [<c00df594>] (writeback_sb_inodes+0x8c/0xfc) from [<c00dfa94>] (writeback_inodes_wb+0x114/0x130) [<c00dfa94>] (writeback_inodes_wb+0x114/0x130) from [<c00dfcb0>] (wb_writeback+0x200/0x280) [<c00dfcb0>] (wb_writeback+0x200/0x280) from [<c00dfe50>] (wb_do_writeback+0x120/0x1b4) [<c00dfe50>] (wb_do_writeback+0x120/0x1b4) from [<c00dff4c>] (bdi_writeback_thread+0x68/0x158) [<c00dff4c>] (bdi_writeback_thread+0x68/0x158) from [<c00758d8>] (kthread+0x7c/0x84) [<c00758d8>] (kthread+0x7c/0x84) from [<c003cd14>] (kernel_thread_exit+0x0/0x8) ---[ end trace 53e65c8e2ab3e15a ]--- root@usrp-e1xx:~# ________________________________ From: Philip Balister <philip@opensdr.com> To: Joel Parker <joelparker27@yahoo.com> Cc: "usrp-users@lists.ettus.com" <usrp-users@lists.ettus.com> Sent: Friday, May 11, 2012 10:29 AM Subject: Re: [USRP-users] Read Only File System ? On 05/11/2012 11:22 AM, Joel Parker wrote: > I am trying to compile OpenBTS on the E100 and am having issues downloading the code because it complains about a read-only file system. Where is a read / write area that I can download and build the source ? What version of the root file system are you using? It like you are seeing the MMC timeout issue. Can you look at the boot messages and see if you see mmc timeout messages? This is a little odd, since you (I think) just managed to install subversion, which would need a rw file system. Philip > > root@usrp-e1xx:~# svn co http://wush.net/svn/range/software/public > A    public/RRLP > A    public/RRLP/trunk > A    public/RRLP/trunk/MAP-CH-DataTypes.asn > A    public/RRLP/trunk/rrtest > A    public/RRLP/trunk/decode > A    public/RRLP/trunk/MAP-ExtensionDataTypes.asn > A    public/RRLP/trunk/rrlpserver.erl > A    public/RRLP/trunk/testall.erl > A    public/RRLP/trunk/setUpFiles.sh > A    public/RRLP/trunk/MAP-ER-DataTypes.asn > A  >  public/RRLP/trunk/parseargs.escript > A    public/RRLP/trunk/sendrrlp.escript > A    public/RRLP/trunk/MAP-CommonDataTypes.asn > A    public/RRLP/trunk/MAP-OM-DataTypes.asn > A    public/RRLP/trunk/tests > A    public/RRLP/trunk/tests/additional_assitance_data.per > A    public/RRLP/trunk/tests/ms_based.per > A    public/RRLP/trunk/tests/temp.per > A    public/RRLP/trunk/tests/runtest.py > A    public/RRLP/trunk/tests/good_pos.per > A    public/RRLP/trunk/MAP-MS-DataTypes.asn > A    public/RRLP/trunk/MAP-SM-DataTypes.asn > A    public/RRLP/trunk/MAP-BS-Code.asn > A    public/RRLP/trunk/rrlpserver.cgi > A    public/RRLP/trunk/rrfake > A    public/RRLP/trunk/MAP-SS-DataTypes.asn > A  >  public/RRLP/trunk/Makefile > A    public/RRLP/trunk/testall.sh > A    public/RRLP/trunk/RRLP-Components.asn > A    public/RRLP/trunk/send_many_rrlp.escript > A    public/RRLP/trunk/parseargsbody.erl > A    public/RRLP/trunk/xrrlp.erl > A    public/RRLP/trunk/MAP-SS-Code.asn > A    public/RRLP/trunk/sendrrlpbody.erl > A    public/RRLP/trunk/MAP-TS-Code.asn > A    public/RRLP/trunk/RRLP.set.asn > A    public/RRLP/trunk/MAP-Protocol.asn > A    public/RRLP/trunk/README > A    public/RRLP/trunk/util.erl > A    public/RRLP/trunk/log2per.py > A    public/RRLP/trunk/file2bin.escript > A    public/RRLP/trunk/RRLP-Messages.asn > A    public/RRLP/trunk/MAP-LCS-DataTypes.asn > svn: Can't change perms of file >  'public/RRLP/trunk/.svn/entries': Read-only file system > > > > _______________________________________________ > USRP-users mailing list > USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
