Hello All,
I need to remove the old name from the boat to make room for the new name.
Black paint on white fiberglass gelcote. It seems to me that I read some
where that using Easy Off oven cleaner works best, but it needs to be
unscented variety. Do I have the facts straight, and is there anything
special I should know about, about doing this project. Any & all suggestions
will be greatly appreciated.
Ken Tucknott
Trista Gray
plain Easy Off indeed works well... wet, spray, let it sit a minute,
scrub, rinse, repeat if needed. do a section at a time.
works for paint on gelcoat as well as paint on Imron/algrip
wear gloves!
pascal
----- Original Message -----
To: "Trawlers Trawlering" trawlers-and-trawlering@lists.samurai.com
Sent: Thursday, April 16, 2009 5:31 PM
Subject: T&T: Boat Name Removal
Hello All,
suggestions
Ken Tucknott
Trista Gray
http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering
To unsubscribe or modify your subscription options (get password, change
email address, etc) go to:
http://lists.samurai.com/mailman/options/trawlers-and-trawlering
Trawlers & Trawlering and T&T are trademarks of Water World
Productions. Unauthorized use is prohibited.
08:12:00
Easy Off works...but be careful. I used it to remove a painted name from
Awlgrip and it left a white ghosting and halo that required me to repaint
that area. On white gelcoat probably not a problem but I would advise,
doing a small area and testing.
-----Original Message-----
From: trawlers-and-trawlering-bounces@lists.samurai.com
[mailto:trawlers-and-trawlering-bounces@lists.samurai.com] On Behalf Of
Pascal Gademer
Sent: Thursday, April 16, 2009 7:11 PM
To: Trawlers Trawlering
Subject: Re: T&T: Boat Name Removal
wear gloves!
pascal
Yep, you got it right. Not sure if it requires unscented or not. I used
this method on the transom of my old boat. The name bubbled up and
sloughed off fairly easily. Requires a good compounding and rewax due to
a ghost image left on the fiberglass, which faded after a couple of year
or two.
Alec
GB 49 Alaskan
LI NY
Ken Tucknott
Sent: Thursday, April 16, 2009 5:32 PM
Hello All,
name.
some where that using Easy Off oven cleaner works best, but it needs to
be unscented variety. Do I have the facts straight, and is there
anything special I should know about, about doing this project. Any &
all suggestions will be greatly appreciated.
Ken Tucknott
Trista Gray
Trawlers & Trawlering and T&T are trademarks of Water World Productions.
