View all threadsHello
I am using UHD source in gnu radio to capture data from usrp. I am then passing this data to throttle and then to file sink. My data sample is 64 bit (complex 32 bit) and I am capturing at the rate of 200 MSps. How to get correct 2 to 3 seconds of data without any data loss as I am seeing data loss after decoding if I just do as the way I am doing. I am seeing "oooooo" in the console as well while writing to the file. Please help. I am attaching the grc file to capture data and write to a file.
Regards,
Snehasish
Hi Snehasish,
You should not be using a Throttle block when you have any actual hardware within the flowgraph.
Note, in order to write 200 MS/s to disk, you'll most likely need a PCIe based SSD, or SSD Raid configuration. I've had success with an Intel 750 Series PCIe based SSD to write 200 MS/s to disk, until it was full. Another option is to use a RAM disk.
Regards,
Nate Temple
On Aug 27, 2017, at 11:49 PM, Snehasish Kar via USRP-users usrp-users@lists.ettus.com wrote:
Hello
Regards,
Snehasish
<usrp_test.grc>_______________________________________________
USRP-users mailing list
USRP-users@lists.ettus.com
Thanks Nate,
I will try that an let you know.
BR
Snehasish
Sent: Monday, August 28, 2017 1:25:58 PM
To: Snehasish Kar
Cc: usrp-users@lists.ettus.com
Subject: Re: [USRP-users] Support with handling data at 200MSPS from NI USRP 2954R
Hi Snehasish,
Regards,
Nate Temple
Hello
Regards,
Snehasish
