trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Re: T&T: Really fast tidal currents
L
lrzeitlin@aol.com
Wed, Sep 21, 2011 3:50 AM
Arild writes:
"Tide range and current flow is highly dependent  on topography of
bottom,  Two extreme examples would be  Bay of Fundy facing the
atlantic  North of Maine and the Mediterranean facing  the opposite
side of the Atlantic just south of Spain with virtually no tide to
speak of.
One body of water is a wide funnel opening that compresses  the
incoming bulge of water because it keeps narrowing down until there is
a 50 foot high bulge at high tide.
The PNW has some of the fastest tide races you can imagine. due to the
convoluted  geography  found there..
You guys have it far too easy in east coast florida waters."
In the late 90s we lived for a couple of years in the Welsh town of
Menai Bridge on the island of Anglesey. If you look at a map of the UK,
Anglesey is right across the Irish Sea from Dublin. It is separated
from the Welsh mainland by the Menai Strait. The Menai Strait itself is
about 14 miles long, quite wide at each end, connecting Caernafon and
Conwy Bays, and narrowing down to a constricted channel of a few
hundred yards between Bangor and Menai Bridge. There is a regular 26
ft. tide in these parts. At the full and new moons the tide can swing
up to 30 ft. The different water levels between each end of the strait
force a swift current through the narrow portion that can reach almost
15 knots. The tidal currents are said to be the fiercest in the British
Isles.
Now that's a tidal current!
Larry Z
Arild writes: "Tide range and current flow is highly dependent on topography of bottom, Two extreme examples would be Bay of Fundy facing the atlantic North of Maine and the Mediterranean facing the opposite side of the Atlantic just south of Spain with virtually no tide to speak of. One body of water is a wide funnel opening that compresses the incoming bulge of water because it keeps narrowing down until there is a 50 foot high bulge at high tide. The PNW has some of the fastest tide races you can imagine. due to the convoluted geography found there.. You guys have it far too easy in east coast florida waters." -- - - - - In the late 90s we lived for a couple of years in the Welsh town of Menai Bridge on the island of Anglesey. If you look at a map of the UK, Anglesey is right across the Irish Sea from Dublin. It is separated from the Welsh mainland by the Menai Strait. The Menai Strait itself is about 14 miles long, quite wide at each end, connecting Caernafon and Conwy Bays, and narrowing down to a constricted channel of a few hundred yards between Bangor and Menai Bridge. There is a regular 26 ft. tide in these parts. At the full and new moons the tide can swing up to 30 ft. The different water levels between each end of the strait force a swift current through the narrow portion that can reach almost 15 knots. The tidal currents are said to be the fiercest in the British Isles. Now that's a tidal current! Larry Z
P
Paige
Wed, Sep 21, 2011 7:43 AM
That's the reason why, the every time I've cruised in that area I've
gone outside the island. The idea of doing 22+ knots over the ground in
a displacement boat, even for the short distance where the the current
peaks is novel and seductive  What puts me off every time is the memory
I have of seeing all those nasty rocks at low tide, many of which are
barely covered at high tide.  Twenty foot outside the channel and you
can be in a world chock full of problems.  That's not even to mention
the shifting sand bars at the Southern end.
P.
On 21/09/2011 04:50, lrzeitlin@aol.com wrote: > The Menai Strait itself is about 14 miles long, quite wide at each > end, connecting Caernafon and Conwy Bays, and narrowing down to a > constricted channel of a few hundred yards between Bangor and Menai Bridge That's the reason why, the every time I've cruised in that area I've gone outside the island. The idea of doing 22+ knots over the ground in a displacement boat, even for the short distance where the the current peaks is novel and seductive What puts me off every time is the memory I have of seeing all those nasty rocks at low tide, many of which are barely covered at high tide. Twenty foot outside the channel and you can be in a world chock full of problems. That's not even to mention the shifting sand bars at the Southern end. P.
P
Paige
Wed, Sep 21, 2011 7:51 AM
I forgot to mention the counter current eddies, whirlpools and standing
waves :-)
P.
I forgot to mention the counter current eddies, whirlpools and standing waves :-) P.
