time-nuts@lists.febo.com
Re: [time-nuts] Oncore question
G
GandalfG8@aol.com
Mon, Nov 24, 2008 8:47 AM
In a message dated 24/11/2008 05:43:49 GMT Standard Time, yuri@ostry.ru
writes:
I simply  put large rechargeable Lithium-Vanadium pentoxide coin cell
with  appropriate charging circuit to GPS carrier board and forgot about
this  question...
Another solution is to put CR123 battery holder to carrier  PCB, stuff
it with a good quality cell and it will probably last for 15+  years,
driving just clock and CMOS RAM during power  outages..
And if it's important that the whole system stays working for reasonable
length drop outs, lead acid gel batteries on a master 12, 24 or 48 volt
(nominal) power supply, again forgetting batteries at board level, are  still hard to
beat.
regards
Nigel
GM8PZR
In a message dated 24/11/2008 05:43:49 GMT Standard Time, yuri@ostry.ru writes: I simply put large rechargeable Lithium-Vanadium pentoxide coin cell with appropriate charging circuit to GPS carrier board and forgot about this question... Another solution is to put CR123 battery holder to carrier PCB, stuff it with a good quality cell and it will probably last for 15+ years, driving just clock and CMOS RAM during power outages.. ---------------- And if it's important that the whole system stays working for reasonable length drop outs, lead acid gel batteries on a master 12, 24 or 48 volt (nominal) power supply, again forgetting batteries at board level, are still hard to beat. regards Nigel GM8PZR
