error during x310 fpga build
SM
STEFANI, Maurizio (External)
Tue, Mar 15, 2022 8:41 AM
HI to all,
I have an ETTUS X310, I would like to build and load the original FPGA,
I loaded from repository the relevant file
The files are in:
/vhd/uhd-master/uhd-master/fpga/usrp3/top/x300
When I run make:
make
make -f Makefile.x300.inc bin NAME=X300_HG ARCH= PART_ID= BUILD_1G=1 BUILD_10G=1 SFP0_1GBE=1 SFP1_10GBE=1  X300=1 TOP_MODULE=x300 EXTRA_DEFS="BUILD_1G=1 BUILD_10G=1 SFP0_1GBE=1 SFP1_10GBE=1  X300=1" DEFAULT_RFNOC_IMAGE_CORE_FILE=x300_rfnoc_image_core.v DEFAULT_EDGE_FILE=/home/maurizio.stefani/prove/vhd/uhd-master/uhd-master/fpga/usrp3/top/x300/x300_static_router.hex
make[1]: Entering directory '/home/maurizio.stefani/prove/vhd/uhd-master/uhd-master/fpga/usrp3/top/x300'
BUILDER: Checking tools...
  • GNU bash, version 5.0.17(1)-release (x86_64-pc-linux-gnu)
  • Python 3.8.10
  • Vivado v2019.2 (64-bit)
BUILDER: Building IP ten_gig_eth_pcs_pma
/bin/sh: 1: export: format.: bad variable name
make[1]: *** [/home/maurizio.stefani/prove/vhd/uhd-master/uhd-master/fpga/usrp3/top/x300/ip/ten_gig_eth_pcs_pma/Makefile.inc:41: /home/maurizio.stefani/prove/vhd/uhd-master/uhd-master/fpga/usrp3/top/x300/build-ip/ten_gig_eth_pcs_pma/ten_gig_eth_pcs_pma.xci.out] Error 2
make[1]: Leaving directory '/home/maurizio.stefani/prove/vhd/uhd-master/uhd-master/fpga/usrp3/top/x300'
make: *** [Makefile:90: X300_HG] Error 2
I am working under Ubuntu:
release -a
No LSB modules are available.
Distributor ID:  Ubuntu
Description:      Ubuntu 20.04.3 LTS
Release:              20.04
Codename:        focal
Is here someone able to help me?
Thank you
Maurizio stefani
The information in this e-mail is confidential. The contents may not be disclosed or used by anyone other than the addressee. Access to this e-mail by anyone else is unauthorised.
If you are not the intended recipient, please notify Airbus immediately and delete this e-mail.
Airbus cannot accept any responsibility for the accuracy or completeness of this e-mail as it has been sent over public networks. If you have any concerns over the content of this message or its Accuracy or Integrity, please contact Airbus immediately.
All outgoing e-mails from Airbus are checked using regularly updated virus scanning software but you should take whatever measures you deem to be appropriate to ensure that this message and any attachments are virus free.
HI to all, I have an ETTUS X310, I would like to build and load the original FPGA, I loaded from repository the relevant file The files are in: /vhd/uhd-master/uhd-master/fpga/usrp3/top/x300 When I run make: make make -f Makefile.x300.inc bin NAME=X300_HG ARCH= PART_ID= BUILD_1G=1 BUILD_10G=1 SFP0_1GBE=1 SFP1_10GBE=1 X300=1 TOP_MODULE=x300 EXTRA_DEFS="BUILD_1G=1 BUILD_10G=1 SFP0_1GBE=1 SFP1_10GBE=1 X300=1" DEFAULT_RFNOC_IMAGE_CORE_FILE=x300_rfnoc_image_core.v DEFAULT_EDGE_FILE=/home/maurizio.stefani/prove/vhd/uhd-master/uhd-master/fpga/usrp3/top/x300/x300_static_router.hex make[1]: Entering directory '/home/maurizio.stefani/prove/vhd/uhd-master/uhd-master/fpga/usrp3/top/x300' BUILDER: Checking tools... * GNU bash, version 5.0.17(1)-release (x86_64-pc-linux-gnu) * Python 3.8.10 * Vivado v2019.2 (64-bit) ======================================================== BUILDER: Building IP ten_gig_eth_pcs_pma ======================================================== /bin/sh: 1: export: format.: bad variable name make[1]: *** [/home/maurizio.stefani/prove/vhd/uhd-master/uhd-master/fpga/usrp3/top/x300/ip/ten_gig_eth_pcs_pma/Makefile.inc:41: /home/maurizio.stefani/prove/vhd/uhd-master/uhd-master/fpga/usrp3/top/x300/build-ip/ten_gig_eth_pcs_pma/ten_gig_eth_pcs_pma.xci.out] Error 2 make[1]: Leaving directory '/home/maurizio.stefani/prove/vhd/uhd-master/uhd-master/fpga/usrp3/top/x300' make: *** [Makefile:90: X300_HG] Error 2 I am working under Ubuntu: release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 20.04.3 LTS Release: 20.04 Codename: focal Is here someone able to help me? Thank you Maurizio stefani The information in this e-mail is confidential. The contents may not be disclosed or used by anyone other than the addressee. Access to this e-mail by anyone else is unauthorised. If you are not the intended recipient, please notify Airbus immediately and delete this e-mail. Airbus cannot accept any responsibility for the accuracy or completeness of this e-mail as it has been sent over public networks. If you have any concerns over the content of this message or its Accuracy or Integrity, please contact Airbus immediately. All outgoing e-mails from Airbus are checked using regularly updated virus scanning software but you should take whatever measures you deem to be appropriate to ensure that this message and any attachments are virus free.
