Plain old clear vinyl tubing as is used for drinking water -- available at
marine stores or hardware stores. It will remain transparent enough for
about 3 years then must be replaced. If you are concerned about it being
damaged, make a shield for it out of wood or a metal tube with the side cut
away on a milling machine. Make certain a ball valve is used at the bottom
so replacement is easy but most importantly so it can be closed off all the
time except when you check the level. The top should go either into the tank
top or to a vent. This bottom connection is also a good place to put a drain
so you can strip out any water that may accumulate from condensation.
Hope this gives you some ideas ...
Regards,
Wayne Shosie
on board BLUE MAX, a 1981 Albin 43
presently lying Summerland Key, FL
I have the same setup. I also bought two cheap 6-foot tape measures and cut the
blades off just to the length of the tubing. I ran them down inside and I now
have a calibrated scale for measuring the fuel.
Russ
Regards,
Wayne Shosie
| Russ and Donna Sherwin |
| "Four Seasons" |
| 1981 Marine Trader DC44 |
| Sunnyvale, Ca 94087 |
