trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
TWL: Battery Power required for DD 671
J
jurban@netsecuritypro.com
Thu, Mar 28, 2002 12:51 PM
I am completing changing my battery banks on my Trawler.  House bank is
now Golf cart batteries charged by HO alternator from one engine.
The starting batteries are two Optima size 31 batteries ( see
http://www.optimabatteries.com/products/starter/technical.asp ) - they
are rated at 750 CCA - 0 deg, 980 MCA 32 deg and weight 37 pounds.  Being
sealed they do not need a battery box, , just strap them down.  I will
have them in parallel giving tons of starting power.  The will charge
from the OEM alternator on one engine and I have put in a small ( 15 amp
max ) smart charger to top them off from the gen or shore power if
necessary.
If you look into the Optima's, note that they make the same starting
battery in different terminal configurations, single terminal, reversed
terminals, side terminals and marine terminals.  Prices differ and
warranty terms differ, but the guts inside are the same.  I went with
the "red top" single terminal batter because its the lowest cost and I
did not need any special terminal configuration.  I then use the Mil-spec
type battery terminal that lets you easily add 1-4 cables to the terminal.
Joe Urban
Punches - Senator 35
Lancaster, VA
I am completing changing my battery banks on my Trawler. House bank is now Golf cart batteries charged by HO alternator from one engine. The starting batteries are two Optima size 31 batteries ( see http://www.optimabatteries.com/products/starter/technical.asp ) - they are rated at 750 CCA - 0 deg, 980 MCA 32 deg and weight 37 pounds. Being sealed they do not need a battery box, , just strap them down. I will have them in parallel giving tons of starting power. The will charge from the OEM alternator on one engine and I have put in a small ( 15 amp max ) smart charger to top them off from the gen or shore power if necessary. If you look into the Optima's, note that they make the same starting battery in different terminal configurations, single terminal, reversed terminals, side terminals and marine terminals. Prices differ and warranty terms differ, but the guts inside are the same. I went with the "red top" single terminal batter because its the lowest cost and I did not need any special terminal configuration. I then use the Mil-spec type battery terminal that lets you easily add 1-4 cables to the terminal. Joe Urban Punches - Senator 35 Lancaster, VA
R
rsf@charter.net
Thu, Mar 28, 2002 1:03 PM
One thing I would add is to always cover your batteries/terminals-that
dropped tool can short across the terminals resulting in a BIG spark.
Robb F
Wisc
----- Original Message -----
To: trawler-world-list@samurai.com
Sent: Thursday, March 28, 2002 6:51 AM
Subject: TWL: Battery Power required for DD 671
The starting batteries are two Optima size 31 batteries  Being
Joe Urban
Lancaster, VA
One thing I would add is to always cover your batteries/terminals-that dropped tool can short across the terminals resulting in a BIG spark. Robb F Wisc ----- Original Message ----- From: "Joe Urban" <jurban@netsecuritypro.com> To: <trawler-world-list@samurai.com> Sent: Thursday, March 28, 2002 6:51 AM Subject: TWL: Battery Power required for DD 671 > I am completing changing my battery banks on my Trawler. House bank is > now Golf cart batteries charged by HO alternator from one engine. > The starting batteries are two Optima size 31 batteries Being > sealed they do not need a battery box, , just strap them down. > > Joe Urban > Punches - Senator 35 > Lancaster, VA >
