JP
Jonathon Pendlum
Wed, Feb 15, 2017 9:37 AM
Hi,
Until you save the project file to disk, Vivado is running with the project
file "in memory". This mode prevents you from doing a lot of normal tasks
you would normally expect to be able to do in the GUI. You need to save the
project file via File->Save Project As.
Jonathon
On Wed, Feb 15, 2017 at 1:53 AM, DEBADRITA DAS debadritadas0@gmail.com
wrote:
Hi,
After the installation and build using make GUI=1 all, the vivado 2015.4
opens but i can't find any vivado project there. i can see the files but
when i try to close it asks me to save it as a project..isn't it a project?
Please help me with this.
BR
Debadrita.
On Mon, Feb 13, 2017 at 9:00 PM, Jonathon Pendlum <
jonathon.pendlum@ettus.com> wrote:
Hello,
Try running "make cleanall" then try again.
On Mon, Feb 13, 2017 at 3:38 AM, DEBADRITA DAS via USRP-users <
HI,
I've installed Vivado Design Suite-HLX Editions 2015.4 on Ubuntu 14.04
and succesfully setup the Ettus Xilinx build environment using
source setupenv.sh
But when i try to build binary bitstream using
make GUI=1 all
it ended up with the following errors
INFO: [IP_Flow 19-1686] Generating 'Instantiation Template' target for
IP 'ddr3_32bit'...
ERROR: [xilinx.com:ip:mig_7series:2.4-0] ddr3_32bit: Code generation
aborted: Can not read PRJ file: /home/debadrita/uhd/fpga-src/u
srp3/top/x300/build-ip/xc7k325tffg900-2/ddr3_32bit/mig_a.prj
CRITICAL WARNING: [IP_Flow 19-1747] Failed to deliver file
'/opt/Xilinx/Vivado/2015.4/data/ip/xilinx/mig_7series_v2_4/x
it/instantiation_template.xit':
ERROR: [IP_Flow 19-167] Failed to deliver one or more file(s).
ERROR: [IP_Flow 19-3505] IP Generation error: Failed to generate IP
'ddr3_32bit'. Failed to generate 'Verilog Instantiation Template' outputs:
ERROR: [IP_Flow 19-98] Generation of the IP CORE failed.
Failed to generate IP 'ddr3_32bit'. Failed to generate 'Verilog
INFO: [Common 17-206] Exiting Vivado at Mon Feb 13 14:41:40 2017...
BUILDER: Releasing IP location: /home/debadrita/uhd/fpga-src/u
make[1]: *** [/home/debadrita/uhd/fpga-src/
usrp3/top/x300/build-ip/xc7k325tffg900-2/ddr3_32bit/ddr3_32bit.xci]
Error 1
make[1]: Leaving directory `/home/debadrita/uhd/fpga-src/usrp3/top/x300'
make: *** [X300_HG] Error 2
root@debadrita:/home/debadrita/uhd/fpga-src/usrp3/top/x300#
root@debadrita:/home/debadrita/uhd/fpga-src/usrp3/top/x300# "make GUI=1
X310_RFNOC_HLS_HGS
please help me with this.
BR
Debadrita.
On Wed, Feb 8, 2017 at 11:48 AM, DEBADRITA DAS debadritadas0@gmail.com
wrote:
Hi,
I am not able to find any Vivado HLS Project under the path
ettus_uhd/uhd/fpga-src/usrp3/top/x300/ and sending you the screenshot
of the same
BR
Debadrita.
On Wed, Feb 8, 2017 at 1:34 AM, Nate Temple nate.temple@ettus.com
wrote:
Hi Debadrita,
You have Vivado Lab and Vivado HLS ( High Level Synthesis ) installed.
You need to have either Vivado Design Edition or System Edition in order to
build the FPGA images for the X300.
Regards,
Nate Temple
Hi,
I have tried that but it didn't help.
debadrita@vipl:~$ cd ettus_uhd/uhd/fpga-src/usrp3/top/x300
debadrita@vipl:~/ettus_uhd/uhd/fpga-src/usrp3/top/x300$ source
Setting up a 64-bit FPGA build environment for the USRP-X3x0...
- Vivado: Found (/opt/Xilinx/Vivado_Lab/2015.4/bin)
- Vivado HLS: Found (/opt/Xilinx/Vivado_HLS/2015.4/bin)
Environment successfully initialized.
debadrita@vipl:~/ettus_uhd/uhd/fpga-src/usrp3/top/x300$ make GUI=1
make -f Makefile.x300.inc bin NAME=X300_HG ARCH=kintex7
PART_ID=xc7k325t/ffg900/-2 BUILD_1G=1 BUILD_10G=1 SFP0_1GBE=1 SFP1_10GBE=1
X300=1 EXTRA_DEFS="BUILD_1G=1 BUILD_10G=1 SFP0_1GBE=1 SFP1_10GBE=1 X300=1"
make[1]: Entering directory `/home/debadrita/ettus_uhd/uhd
BUILDER: Checking tools...
- GNU bash, version 4.3.11(1)-release (x86_64-pc-linux-gnu)
- Python 2.7.6
- ERROR: Vivado not found in environment. Please run setupenv.sh
make[1]: *** [.check_tool] Error 1
make[1]: Leaving directory `/home/debadrita/ettus_uhd/uhd
BR
Debadrita
On Tue, Feb 7, 2017 at 12:14 PM, Nate Temple nate.temple@ettus.com
Hi Debadrita,
Note the error towards the end of the output: "* ERROR: Vivado not
found in environment. Please run setupenv.sh"
You need to source the setupenv.sh script which is located in the
fpga-src/usrp3/top/x300 directory before running the make command.
md_usrp3_build_instructions.html
Under the section: Build Instructions (Xilinx Vivado only) ->
On Feb 6, 2017, at 10:26 PM, DEBADRITA DAS via USRP-users <
Hi,
i'm using ettus USRP X300 in UBUNTU 14.04 64 bit and while
building Xilinx Vivado Design Suite HLX Editions 15.4, i am facing the
following error
- Python 2.7.6
debadrita@vipl:~/ettus_uhd/uhd/fpga-src/usrp3/top/x300$ sudo make
make -f Makefile.x300.inc bin NAME=X300_HG ARCH= PART_ID=
- Python 2.7.6
Hi,
Jonathon
On Wed, Feb 15, 2017 at 1:53 AM, DEBADRITA DAS <debadritadas0@gmail.com>
wrote:
> Hi,
> BR
> Debadrita.
>> Hello,
>> usrp-users@lists.ettus.com> wrote:
>>> HI,
>>> source setupenv.sh
>>> make GUI=1 all
>>> IP 'ddr3_32bit'...
>>> Error 1
>>> X310_RFNOC_HLS_HGS
>>> BR
>>> Debadrita.
>>> On Wed, Feb 8, 2017 at 11:48 AM, DEBADRITA DAS <debadritadas0@gmail.com>
>>> wrote:
>>>> Hi,
>>>> of the same
>>>> BR
>>>> Debadrita.
>>>> On Wed, Feb 8, 2017 at 1:34 AM, Nate Temple <nate.temple@ettus.com>
>>>> wrote:
>>>>> Hi Debadrita,
>>>>> Regards,
>>>>> Nate Temple
>>>>> > On Feb 6, 2017, at 11:03 PM, DEBADRITA DAS <debadritadas0@gmail.com>
>>>>> wrote:
>>>>> > Hi,
>>>>> setupenv.sh
>>>>> > * GNU bash, version 4.3.11(1)-release (x86_64-pc-linux-gnu)
>>>>> > * Python 2.7.6
>>>>> > * ERROR: Vivado not found in environment. Please run setupenv.sh
>>>>> > BR
>>>>> > Debadrita
>>>>> > On Tue, Feb 7, 2017 at 12:14 PM, Nate Temple <nate.temple@ettus.com>
>>>>> wrote:
>>>>> > Hi Debadrita,
>>>>> > Additional details are at this page: http://files.ettus.com/manual/
>>>>> Makefile based Builder
>>>>> > Regards,
>>>>> > Nate Temple
>>>>> > > Hi,
>>>>> following error
>>>>> > > * Python 2.7.6
>>>>> GUI=1
>>>>> > > * Python 2.7.6
>>>>> > > BR
>>>>> > > Debadrita.
>>>>> > > _______________________________________________
>>>>> > > USRP-users mailing list
>>>>> > > USRP-users@lists.ettus.com
>>>>> > > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
