View all threadsHi folks!
I am wondering if it is possible to receive on all 4 inputs at the same
time on the E310/E312? I.e. is it possible to receive on TRX A, RX A, TRX
B, RX B all at the same time? I tried creating a GNU Radio flowchart with
this setup and got the following Runtime Error:
thread[thread-per-block[16]: <block rfnoc_radio (2)>]: RuntimeError: On
node 0/Radio_0, output port 0 is already connected.
I received the same error when trying to receive on three inputs instead,
and the program defaulted to receiving on RX A and RX B instead.
Thank you.
Kind regards,
Ronakraj
On 02/09/2018 11:01 PM, Ronakraj Gosalia via USRP-users wrote:
Hi folks!
same time on the E310/E312? I.e. is it possible to receive on TRX A,
RX A, TRX B, RX B all at the same time? I tried creating a GNU Radio
flowchart with this setup and got the following Runtime Error:
On node 0/Radio_0, output port 0 is already connected.
instead, and the program defaulted to receiving on RX A and RX B instead.
Thank you.
Kind regards,
Ronakraj
USRP-users mailing list
USRP-users@lists.ettus.com
NO.
There are only two receiver channels, and those channels can either be
connected (in the analog sense) to TRX or RX antenna connectors, but
there really
are only two receiver channels.
