Hello
some time ago i noticed someone adding helper objects to his drawings that
disappear in the compilation, can't now remember where i saw this, but it
occurred to me this was a neat feature....
so i have now an object that clips to a 3030 alu profile, and i want to see
the profile only in fast drawing but not when i compile the object...
i have seen it done, but i can't find the info in the docu?
how can this be achieved?
thanks in advance
ciao
Bruno
http://nohkumado.eu/, http://bboett.free.frhttp://aikido.nohkumado.eu/,
http://aikido.zorn.free.fr
drawings that disappear in the compilation
That should be the "background modifier":
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Modifier_Characters#Background_Modifier
ciao,
Torsten.
There is the %background modifier
Ignore this subtree for the normal rendering process and draw it in
transparent gray (all transformations are still applied to the nodes in
this tree).
Because the marked subtree is completely ignored, it might have unexpected
effects in case it's used, for example, with the first object in a
difference(). In that case this object is rendered in transparent gray, but
it is not used as the base for the difference()!
And there is $preview
$preview is true, when in OpenCSG preview (F5). $preview is false, when in
render (F6).
This can, for example, be used to reduce detail during preview to save
time, without losing detail in the final rendered result:
On Mon, 13 Apr 2020 at 17:44, Bruno Boettcher bboett@gmail.com wrote:
Hello
see the profile only in fast drawing but not when i compile the object...
thanks in advance
ciao
Bruno
OpenSCAD mailing list
Discuss@lists.openscad.org
http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
