Cruising America's Great Loop and other inland routes
View all threadsBill wrote: "Someone stated on this forum that the government is
selectively targeting
areas such as military bases, power plants, etc. and inducing GPS error
in
those zones only.
How is this accomplished? Do they send out jamming signals in a given
area?
I doubt that is possible. "
Keith
Eat well, stay fit, die anyway.
Keith, Sorry I'm still not convinced. If it's that easy to jam, DOD was
wasted a lot of time and money. After all the system wasn't built for
boaters and hikers.
I know that the signals my GPS receiver sees are very weak, BUT they are
very, very complicated. So the receiver is not easily fooled. In fact
because of the pseudo random code, one of the key factors that makes GPS
work, it's virtually impossible to induce an error only in a selected area.
That's key to the whole system.
Understand I'm not saying that errors can't be induced in the whole system
or even in one satellite, but when that is done it effects the whole range
covered by the system or the selected satellite(s). The system won't let me
choose an area, say a 10 mile radius around a power plant, within that range
to target that error.
Just think for a moment. WAAS works the same way as GPS. In fact it's a
refinement of GPS with additional satellites furnishing more data, therefore
more accuracy, at greater update rates. The FAA is developing WAAS to land
airplanes unmanned. If it is possible to jam as easily as stated, terrorist
will have a "ball".
Nope, somebody is going to have to have to explain to me how GPS is jammed
in a selected area. I don't believe simply tuning a transmitter to a certain
carrier frequency will do it. I think some real sophisticated modulation is
going to have to be done to that carrier before it fools my GPS into
thinking its in South America instead of Three Mile Island.
Bill Cooke
M/V All The Marbles
Roughwater 41
John Gill replied:
William and List,
I do not know how the military is doing the jamming, but I can tell you that
when we went down the ICW from the Chesapeake Bay this past Fall, our GPS
showed us going 40 knots one minute and 3 knots the next and at one point our
Lat / Lon indicated that we were in South America -- that was going past the
Norfolk Navy Base, about 3 miles before and until 3 miles past the base. We
had the same "problem" going by the Marine Base and by a Submarine Base. Pure
coincidence??? I doubt it. A friend of ours experienced the same "problem"
taking his boat to the New Jersey shore from the Chesapeake Bay, when he looked
around he noticed a Nuclear Power Plant nearby. Another coincidence.
In each of these cases, the "problem" cleared up within only a few miles past
the possible terrorist targets.
Remember that we had errors introduced for several years and all of a sudden no
need for errors -- even after 9/11???
If you don't think that the USA has superior equipment, then guess again.
John
boaters and hikers.
will have a "ball".
Bill Cooke
M/V All The Marbles
Roughwater 41
Trawler-world-great-loop mailing list
Trawler-world-great-loop@lists.samurai.com
http://lists.samurai.com/mailman/listinfo/trawler-world-great-loop
They jam by localizing the jamming signal to a specific area. This could be
done by hiding a transmitter in the area, or (I'm speculating) by directing
a narrow cone of RF interference from a high-altitude plane or a top-secret
military satellite using a directional beam antenna.
We don't need to confuse the GPS into thinking it's somewhere it isn't; just
need to confuse it enough that it can't lock into the real signal; in other
words jamming it.
David KoJen
http://www.bicnet.net/~scarabe/solisMaris
