I think the real concern should be whether or not there is plywood in the
decks. The early trawlers had glassed-over plywood on the main deck, the
boat deck, and the bridge. When teak is screwed into the plywood and, for
whatever reason, water gets into the plywood, the plywood rots and you have
a big problem and a big expense.
However, the better quality trawlers quit doing that some time back. Around
1982 the DeFever 49 built at the CTF yard went to solid fiberglass decks.
The teak overlay is screwed into solid fiberglass, there is no plywood to
rot. The Krogen 42 eliminated plywood decks around 1986. Some of the
cheaper trawlers may still be putting plywood in their decks, I don't know.
If--a big if--you don't have plywood in your decks, I highly recommend teak
decks. They are easy on the feet, much less slippery than fiberglass, look
great, and are easy to take care of as long as you don't put oil or other
finishes on them.
Ron Jones
m/v Bilbo Baggins
DeFever 49 PH
St. Pete, Fla.
<<I'm one of the newbie's here. I just came across the "list" and have found
the topics of
conversation to be just great....>>
<<I don't have a boat, but I'm one of those guys who has been looking for
the "trawler of
my dreams" for the past two years. A decent and dry MT 34 DC or SE, or an
early Willard
30 Voyager, etc would fill the dream. Good ones are very hard to find via
the normal
route and if they are there, they seem to be in CA, OR or WA and not here on
the East
Coast, BUT with this thought in mind, a question.>>
<<As I walk the marinas in MD from Harve de Grace to the Solomons and across
the Bay
Bridge and discuss the available trawlers with either the owners or the
brokers, one of
the topics of conversation which surfaces is "teak decks" and the saying,
"buyer be
careful".>>
<<>From what I understand when the vessel was first purchased there were of
course many
options. One of those was whether to include the teak decks. Many new owners
opted to
include that option at the time of purchase.>>
<<The teak is laid on top of the fiberglass deck, correct? The deck was at
that point in
time sound and solid. What causes the deck, with time, to eventually start
to leak? I'm
sure it doesn't happen in all cases, but I've heard the comment so many
times I'm
becoming deck-shy when I see a teak deck. Is it stress? If so, would the
stress problem
not have developed if the teak had not been involved?>>
