time-nuts@lists.febo.com
Re: [time-nuts] AC cord or connector for 5061A
JL
J. L. Trantham
Sun, Jul 19, 2009 3:24 PM
As usual, the list has provided extremely helpful information.
The 'W', indeed defines the rotation of the insert.
Interestingly, I note on the picture from Tom's site exactly matches my
connector (I just need more) and it shows 'W', 'X', 'Y', and 'Z' around the
face of the insert with the 'W' aligned with the keying slot.
If this means that the rotation can be 'user selected' as you assemble the
connector, I am home free.  I have not tried to disassemble the connector
yet but will when I get back from work today.
Anyone know anything about that?  Is it 'user selected' on the mating
chassis connector as well?
Thanks,
Joe
-----Original Message-----
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On
Behalf Of Arnold Tibus
Sent: Sunday, July 19, 2009 10:01 AM
To: Discussion of precise time and frequency measurement
Subject: Re: [time-nuts] AC cord or connector for 5061A
MS3106A-18-22SW ?
that special type of connector will be very hard to get
(if you do not find the original cable for this unit)!
The insert is not standard:
"Not MSA/B insert arrangements and polarization"
This spec. is very old and even the US-Militaries did advice already decades
of years ago to not use them anymore in new design.
One problem with this old MIL-Spec. connectors is that these contain  a lot
of cadmium for protection against corrosion on their surface.
Cadmium is known to be very toxic and is today forbidden to be applied.
The cadmium is covered by a green chromate film, which is not very
resistant when the surface is being scratched with some force.
Technical details:
It is a MIL-C-5015 Power type connector with large contacts,
threaded coupling, straight plug and shell size 18,
But this contact arrangement18-22 is not on all manufacturers lists.
I guess that only some chinese manufacturer do still have them
in the productiong line for spares, if at all.
Attention to the 'W' in the type number which does mean that
the insert is turned by 70 deg. to avoid to be connected with std.
types used for other purposes...both mating part must have this marking!
some techn. infos under
http://www.in2connect.uk.com/c2/uploads/a5015%20ms1.pdf
www.amphenol-aerospace.com/pdf/knowconnectors.pdf
I would propose in this case to exchange the original parts with
modern types fitting in this position and being qualified to be used
for mains connection.
Good luck!
regards
Arnold
On Sun, 19 Jul 2009 07:25:03 -0400, John Ackermann N8UR wrote:
I got some from Digi-key a year or so ago.  Unfortunately, I don't
recall the DK part number, but I recall I had to do a cross-reference
from the Cannon part number to another manufacturer (I think AMP) and
that's what DK had.
John
J. L. Trantham said the following on 07/18/2009 11:58 PM:
I am aware of the connection issue but I can't find the connectors.
Are they still available or should I change both the chassis
connector and mating connector to something that I can find?
Thanks,
Joe
On Behalf Of Tom Van Baak
Sent: Saturday, July 18, 2009 10:45 PM
Does anyone know of a source for a power cord for the 5061A (or
5061B,
5065A, etc.)?  I am looking for 3 cords or the connector that mates
with AC connector on the back.
The AC Cord is HP part number 1251-2457 and the connector that mates
with the connector on the back is a Cannon MS3106A-18-22SW.
Thanks in advance.
Joe
See if this helps.
http://www.leapsecond.com/museum/hp5065a/conn.htm
Best to open the bottom to make sure your unit has pins
that match the schematic.
/tvb
To unsubscribe, go to
As usual, the list has provided extremely helpful information. The 'W', indeed defines the rotation of the insert. Interestingly, I note on the picture from Tom's site exactly matches my connector (I just need more) and it shows 'W', 'X', 'Y', and 'Z' around the face of the insert with the 'W' aligned with the keying slot. If this means that the rotation can be 'user selected' as you assemble the connector, I am home free. I have not tried to disassemble the connector yet but will when I get back from work today. Anyone know anything about that? Is it 'user selected' on the mating chassis connector as well? Thanks, Joe -----Original Message----- From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf Of Arnold Tibus Sent: Sunday, July 19, 2009 10:01 AM To: Discussion of precise time and frequency measurement Subject: Re: [time-nuts] AC cord or connector for 5061A MS3106A-18-22SW ? that special type of connector will be very hard to get (if you do not find the original cable for this unit)! The insert is not standard: "Not MSA/B insert arrangements and polarization" This spec. is very old and even the US-Militaries did advice already decades of years ago to not use them anymore in new design. One problem with this old MIL-Spec. connectors is that these contain a lot of cadmium for protection against corrosion on their surface. Cadmium is known to be very toxic and is today forbidden to be applied. The cadmium is covered by a green chromate film, which is not very resistant when the surface is being scratched with some force. Technical details: It is a MIL-C-5015 Power type connector with large contacts, threaded coupling, straight plug and shell size 18, But this contact arrangement18-22 is not on all manufacturers lists. I guess that only some chinese manufacturer do still have them in the productiong line for spares, if at all. Attention to the 'W' in the type number which does mean that the insert is turned by 70 deg. to avoid to be connected with std. types used for other purposes...both mating part must have this marking! some techn. infos under http://www.in2connect.uk.com/c2/uploads/a5015%20ms1.pdf www.amphenol-aerospace.com/pdf/knowconnectors.pdf I would propose in this case to exchange the original parts with modern types fitting in this position and being qualified to be used for mains connection. Good luck! regards Arnold On Sun, 19 Jul 2009 07:25:03 -0400, John Ackermann N8UR wrote: >I got some from Digi-key a year or so ago. Unfortunately, I don't >recall the DK part number, but I recall I had to do a cross-reference >from the Cannon part number to another manufacturer (I think AMP) and >that's what DK had. >John >---- >J. L. Trantham said the following on 07/18/2009 11:58 PM: >> I am aware of the connection issue but I can't find the connectors. >> Are they still available or should I change both the chassis >> connector and mating connector to something that I can find? >> >> Thanks, >> >> Joe >> >> -----Original Message----- >> From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] >> On Behalf Of Tom Van Baak >> Sent: Saturday, July 18, 2009 10:45 PM >> To: Discussion of precise time and frequency measurement >> Subject: Re: [time-nuts] AC cord or connector for 5061A >> >> >>> Does anyone know of a source for a power cord for the 5061A (or >>> 5061B, >>> 5065A, etc.)? I am looking for 3 cords or the connector that mates >>> with AC connector on the back. >>> >>> The AC Cord is HP part number 1251-2457 and the connector that mates >>> with the connector on the back is a Cannon MS3106A-18-22SW. >>> >>> Thanks in advance. >>> >>> Joe >> >> See if this helps. >> >> http://www.leapsecond.com/museum/hp5065a/conn.htm >> >> Best to open the bottom to make sure your unit has pins >> that match the schematic. >> >> /tvb >> >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@febo.com >> To unsubscribe, go to >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >> and follow the instructions there. >> >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@febo.com >> To unsubscribe, go to >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >> and follow the instructions there. >_______________________________________________ >time-nuts mailing list -- time-nuts@febo.com >To unsubscribe, go to >https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >and follow the instructions there. _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there.
RA
Robert Atkinson
Sun, Jul 19, 2009 4:07 PM
Hi Joe,
It depends on thestyle, make and possibly even factory / production run. The polarisation is not intended to be user selectable. Some connectors have a common metal shell and all key positions in the insulator. Some have a dedicated shell or insert for each polarisation. Even if the insert has all options, it does not follow that you can dissasemble the connector to change it. Many connectors are potted and are difficult to dissasemble. Most crimp type 5015's cannot be dissasembled. Many solder types are assembled with internal "C" clips. These are not intended to be removed, but often can be. In an emergency, I've dissasembled a connector, filed off the male key for the insert and epoxied the insert in place. I used the mating connector as a jig to get the keying correct. It is very much a judgment call if this is acceptable. Personally I would not do it on a connector used for mains.
Robert G8RPI.
To: "'Discussion of precise time and frequency measurement'" time-nuts@febo.com
Date: Sunday, 19 July, 2009, 4:24 PM
exactly matches my
and 'Z' around the
slot.
you assemble the
Thanks,
Joe
On
MS3106A-18-22SW ?
these contain  a lot
surface.
be applied.
not very
force.
Technical details:
contacts,
them
that
with std.
this marking!
with
to be used
Good luck!
regards
Arnold
cross-reference
think AMP) and
that's what DK had.
John
PM:
the chassis
can find?
Thanks,
Joe
measurement
5061A
for the 5061A (or
5061B,
MS3106A-18-22SW.
Thanks in advance.
Joe
See if this helps.
pins
/tvb
Hi Joe, It depends on thestyle, make and possibly even factory / production run. The polarisation is not intended to be user selectable. Some connectors have a common metal shell and all key positions in the insulator. Some have a dedicated shell or insert for each polarisation. Even if the insert has all options, it does not follow that you can dissasemble the connector to change it. Many connectors are potted and are difficult to dissasemble. Most crimp type 5015's cannot be dissasembled. Many solder types are assembled with internal "C" clips. These are not intended to be removed, but often can be. In an emergency, I've dissasembled a connector, filed off the male key for the insert and epoxied the insert in place. I used the mating connector as a jig to get the keying correct. It is very much a judgment call if this is acceptable. Personally I would not do it on a connector used for mains. Robert G8RPI. --- On Sun, 19/7/09, J. L. Trantham <jltran@worldnet.att.net> wrote: > From: J. L. Trantham <jltran@worldnet.att.net> > Subject: Re: [time-nuts] AC cord or connector for 5061A > To: "'Discussion of precise time and frequency measurement'" <time-nuts@febo.com> > Date: Sunday, 19 July, 2009, 4:24 PM > As usual, the list has provided > extremely helpful information. > > The 'W', indeed defines the rotation of the insert. > > Interestingly, I note on the picture from Tom's site > exactly matches my > connector (I just need more) and it shows 'W', 'X', 'Y', > and 'Z' around the > face of the insert with the 'W' aligned with the keying > slot.  > > If this means that the rotation can be 'user selected' as > you assemble the > connector, I am home free.  I have not tried to > disassemble the connector > yet but will when I get back from work today. > > Anyone know anything about that?  Is it 'user > selected' on the mating > chassis connector as well? > > Thanks, > > Joe > > -----Original Message----- > From: time-nuts-bounces@febo.com > [mailto:time-nuts-bounces@febo.com] > On > Behalf Of Arnold Tibus > Sent: Sunday, July 19, 2009 10:01 AM > To: Discussion of precise time and frequency measurement > Subject: Re: [time-nuts] AC cord or connector for 5061A > > > MS3106A-18-22SW ? > that special type of connector will be very hard to get > (if you do not find the original cable for this unit)! > > The insert is not standard: > "Not MSA/B insert arrangements and polarization" > > This spec. is very old and even the US-Militaries did > advice already decades > of years ago to not use them anymore in new design. > > One problem with this old MIL-Spec. connectors is that > these contain  a lot > of cadmium for protection against corrosion on their > surface. > Cadmium is known to be very toxic and is today forbidden to > be applied. > The cadmium is covered by a green chromate film, which is > not very > resistant when the surface is being scratched with some > force. > > Technical details: > It is a MIL-C-5015 Power type connector with large > contacts, > threaded coupling, straight plug and shell size 18, > But this contact arrangement18-22 is not on all > manufacturers lists. > I guess that only some chinese manufacturer do still have > them > in the productiong line for spares, if at all. > > Attention to the 'W' in the type number which does mean > that > the insert is turned by 70 deg. to avoid to be connected > with std. > types used for other purposes...both mating part must have > this marking! > > some techn. infos under > http://www.in2connect.uk.com/c2/uploads/a5015%20ms1.pdf > www.amphenol-aerospace.com/pdf/knowconnectors.pdf > > I would propose in this case to exchange the original parts > with > modern types fitting in this position and being qualified > to be used > for mains connection. > > Good luck! > > regards > Arnold > > > On Sun, 19 Jul 2009 07:25:03 -0400, John Ackermann N8UR > wrote: > > >I got some from Digi-key a year or so ago.  > Unfortunately, I don't > >recall the DK part number, but I recall I had to do a > cross-reference > >from the Cannon part number to another manufacturer (I > think AMP) and > >that's what DK had. > > >John > >---- > > >J. L. Trantham said the following on 07/18/2009 11:58 > PM: > >> I am aware of the connection issue but I can't > find the connectors.  > >> Are they still available or should I change both > the chassis > >> connector and mating connector to something that I > can find? > >> > >> Thanks, > >> > >> Joe > >> > >> -----Original Message----- > >> From: time-nuts-bounces@febo.com > [mailto:time-nuts-bounces@febo.com] > > >> On Behalf Of Tom Van Baak > >> Sent: Saturday, July 18, 2009 10:45 PM > >> To: Discussion of precise time and frequency > measurement > >> Subject: Re: [time-nuts] AC cord or connector for > 5061A > >> > >> > >>> Does anyone know of a source for a power cord > for the 5061A (or > >>> 5061B, > >>> 5065A, etc.)?  I am looking for 3 cords > or the connector that mates > >>> with AC connector on the back. > >>> > >>> The AC Cord is HP part number 1251-2457 and > the connector that mates > >>> with the connector on the back is a Cannon > MS3106A-18-22SW. > >>> > >>> Thanks in advance. > >>> > >>> Joe > >> > >> See if this helps. > >> > >> http://www.leapsecond.com/museum/hp5065a/conn.htm > >> > >> Best to open the bottom to make sure your unit has > pins > >> that match the schematic. > >> > >> /tvb > >> > >> > >> _______________________________________________ > >> time-nuts mailing list -- time-nuts@febo.com > >> To unsubscribe, go to > >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > >> and follow the instructions there. > >> > >> > >> _______________________________________________ > >> time-nuts mailing list -- time-nuts@febo.com > >> To unsubscribe, go to > >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > >> and follow the instructions there. > > >_______________________________________________ > >time-nuts mailing list -- time-nuts@febo.com > >To unsubscribe, go to > >https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > >and follow the instructions there. > > > > > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
DR
Dan Rae
Sun, Jul 19, 2009 4:11 PM
I bought one of these recently from Digikey for a 5065A (and for nearer
to $25 than the $15 that tvb quotes alas ), and yes, you can take it
apart and rotate the insert to the required orientation for the -hp-
units.
dr
J. L. Trantham wrote: > If this means that the rotation can be 'user selected' as you assemble the > connector, I am home free. I have not tried to disassemble the connector > yet but will when I get back from work today. > > I bought one of these recently from Digikey for a 5065A (and for nearer to $25 than the $15 that tvb quotes alas ), and yes, you can take it apart and rotate the insert to the required orientation for the -hp- units. dr
JF
J. Forster
Sun, Jul 19, 2009 6:12 PM
Yes. The keying can be user selected.
It takes a small file to open a gap in one of the alternate molded in
keying groves. You take the insert out by removing the retaining circlip,
file the slot, and reinsert and replace the clip. Total time, maybe 5
minutes.
-John
the
Thanks,
Joe
MS3106A-18-22SW ?
decades
lot
Technical details:
Good luck!
regards
Arnold
that's what DK had.
John
Thanks,
Joe
5061B,
Thanks in advance.
Joe
See if this helps.
/tvb
Yes. The keying can be user selected. It takes a small file to open a gap in one of the alternate molded in keying groves. You take the insert out by removing the retaining circlip, file the slot, and reinsert and replace the clip. Total time, maybe 5 minutes. -John ==================== > As usual, the list has provided extremely helpful information. > > The 'W', indeed defines the rotation of the insert. > > Interestingly, I note on the picture from Tom's site exactly matches my > connector (I just need more) and it shows 'W', 'X', 'Y', and 'Z' around > the > face of the insert with the 'W' aligned with the keying slot. > > If this means that the rotation can be 'user selected' as you assemble the > connector, I am home free. I have not tried to disassemble the connector > yet but will when I get back from work today. > > Anyone know anything about that? Is it 'user selected' on the mating > chassis connector as well? > > Thanks, > > Joe > > -----Original Message----- > From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On > Behalf Of Arnold Tibus > Sent: Sunday, July 19, 2009 10:01 AM > To: Discussion of precise time and frequency measurement > Subject: Re: [time-nuts] AC cord or connector for 5061A > > > MS3106A-18-22SW ? > that special type of connector will be very hard to get > (if you do not find the original cable for this unit)! > > The insert is not standard: > "Not MSA/B insert arrangements and polarization" > > This spec. is very old and even the US-Militaries did advice already > decades > of years ago to not use them anymore in new design. > > One problem with this old MIL-Spec. connectors is that these contain a > lot > of cadmium for protection against corrosion on their surface. > Cadmium is known to be very toxic and is today forbidden to be applied. > The cadmium is covered by a green chromate film, which is not very > resistant when the surface is being scratched with some force. > > Technical details: > It is a MIL-C-5015 Power type connector with large contacts, > threaded coupling, straight plug and shell size 18, > But this contact arrangement18-22 is not on all manufacturers lists. > I guess that only some chinese manufacturer do still have them > in the productiong line for spares, if at all. > > Attention to the 'W' in the type number which does mean that > the insert is turned by 70 deg. to avoid to be connected with std. > types used for other purposes...both mating part must have this marking! > > some techn. infos under > http://www.in2connect.uk.com/c2/uploads/a5015%20ms1.pdf > www.amphenol-aerospace.com/pdf/knowconnectors.pdf > > I would propose in this case to exchange the original parts with > modern types fitting in this position and being qualified to be used > for mains connection. > > Good luck! > > regards > Arnold > > > On Sun, 19 Jul 2009 07:25:03 -0400, John Ackermann N8UR wrote: > >>I got some from Digi-key a year or so ago. Unfortunately, I don't >>recall the DK part number, but I recall I had to do a cross-reference >>from the Cannon part number to another manufacturer (I think AMP) and >>that's what DK had. > >>John >>---- > >>J. L. Trantham said the following on 07/18/2009 11:58 PM: >>> I am aware of the connection issue but I can't find the connectors. >>> Are they still available or should I change both the chassis >>> connector and mating connector to something that I can find? >>> >>> Thanks, >>> >>> Joe >>> >>> -----Original Message----- >>> From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] >>> On Behalf Of Tom Van Baak >>> Sent: Saturday, July 18, 2009 10:45 PM >>> To: Discussion of precise time and frequency measurement >>> Subject: Re: [time-nuts] AC cord or connector for 5061A >>> >>> >>>> Does anyone know of a source for a power cord for the 5061A (or >>>> 5061B, >>>> 5065A, etc.)? I am looking for 3 cords or the connector that mates >>>> with AC connector on the back. >>>> >>>> The AC Cord is HP part number 1251-2457 and the connector that mates >>>> with the connector on the back is a Cannon MS3106A-18-22SW. >>>> >>>> Thanks in advance. >>>> >>>> Joe >>> >>> See if this helps. >>> >>> http://www.leapsecond.com/museum/hp5065a/conn.htm >>> >>> Best to open the bottom to make sure your unit has pins >>> that match the schematic. >>> >>> /tvb >>> >>> >>> _______________________________________________ >>> time-nuts mailing list -- time-nuts@febo.com >>> To unsubscribe, go to >>> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >>> and follow the instructions there. >>> >>> >>> _______________________________________________ >>> time-nuts mailing list -- time-nuts@febo.com >>> To unsubscribe, go to >>> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >>> and follow the instructions there. > >>_______________________________________________ >>time-nuts mailing list -- time-nuts@febo.com >>To unsubscribe, go to >>https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >>and follow the instructions there. > > > > > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > >
