time-nuts@lists.febo.com
MEMS oscillators
AG
Adrian Godwin
Tue, Oct 30, 2018 10:50 AM
How sensitive to atmospheric environment are MEMs oscillators ?
https://www.reddit.com/r/sysadmin/comments/9si6r9/postmortem_mri_disables_every_ios_device_in/
It gets closer to time-nuts territory in the earlier discussion - see
captaincool's contribution some way down :
https://www.reddit.com/r/sysadmin/comments/9mk2o7/mri_disabled_every_ios_device_in_facility/
How sensitive to atmospheric environment are MEMs oscillators ? https://www.reddit.com/r/sysadmin/comments/9si6r9/postmortem_mri_disables_every_ios_device_in/ It gets closer to time-nuts territory in the earlier discussion - see captaincool's contribution some way down : https://www.reddit.com/r/sysadmin/comments/9mk2o7/mri_disabled_every_ios_device_in_facility/
J
jimlux
Tue, Oct 30, 2018 12:44 PM
The helium leak sounds a bit sketchy, especially when you're talking
about a system that has large RF and magnetic fields.  Why would a MEMS
resonator care about what gas it is surrounded by.
That said, I recall someone telling me about problems with early MEMS RF
switches and needing some trace amount of water vapor to make them work
  • work fine on the bench, but them into thermal vacuum testing and after
    some amount of time they stop working, as the H2O diffuses out of the
    (non-hermetic) packages.
On 10/30/18 3:50 AM, Adrian Godwin wrote: > How sensitive to atmospheric environment are MEMs oscillators ? > > https://www.reddit.com/r/sysadmin/comments/9si6r9/postmortem_mri_disables_every_ios_device_in/ > > > It gets closer to time-nuts territory in the earlier discussion - see > captaincool's contribution some way down : > > https://www.reddit.com/r/sysadmin/comments/9mk2o7/mri_disabled_every_ios_device_in_facility/ > The helium leak sounds a bit sketchy, especially when you're talking about a system that has large RF and magnetic fields. Why would a MEMS resonator care about what gas it is surrounded by. That said, I recall someone telling me about problems with early MEMS RF switches and needing some trace amount of water vapor to make them work - work fine on the bench, but them into thermal vacuum testing and after some amount of time they stop working, as the H2O diffuses out of the (non-hermetic) packages.
BK
Bob kb8tq
Tue, Oct 30, 2018 1:53 PM
Hi
More than sketchy, it sounds a bit crazy.
MEMS are not a lot different than any IC in that you can get packaging issues. Put them
in a high pressure “bomb” test and you will see the same issues that you do on any IC.
The gotcha is that an IC is die coated and a MEMS oscillator  likely is not. They should
get packaged accordingly (= a low leakage package).
Getting anything into a package at normal atmospheric pressure … not so much.
Bob
time-nuts mailing list -- time-nuts@lists.febo.com
To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com
Hi More than sketchy, it sounds a bit crazy. MEMS are not a lot different than any IC in that you can get packaging issues. Put them in a high pressure “bomb” test and you will see the same issues that you do on any IC. The gotcha is that an IC is die coated and a MEMS oscillator likely is not. They should get packaged accordingly (= a low leakage package). Getting anything into a package at normal atmospheric pressure … not so much. Bob > On Oct 30, 2018, at 8:44 AM, jimlux <jimlux@earthlink.net> wrote: > > On 10/30/18 3:50 AM, Adrian Godwin wrote: >> How sensitive to atmospheric environment are MEMs oscillators ? >> https://www.reddit.com/r/sysadmin/comments/9si6r9/postmortem_mri_disables_every_ios_device_in/ >> It gets closer to time-nuts territory in the earlier discussion - see >> captaincool's contribution some way down : >> https://www.reddit.com/r/sysadmin/comments/9mk2o7/mri_disabled_every_ios_device_in_facility/ > > The helium leak sounds a bit sketchy, especially when you're talking about a system that has large RF and magnetic fields. Why would a MEMS resonator care about what gas it is surrounded by. > > That said, I recall someone telling me about problems with early MEMS RF switches and needing some trace amount of water vapor to make them work - work fine on the bench, but them into thermal vacuum testing and after some amount of time they stop working, as the H2O diffuses out of the (non-hermetic) packages. > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
PA
Paul Alfille
Tue, Oct 30, 2018 2:07 PM
Helium is lower density, a feature used to reduce turbulence in patients
with airway stenosis. Perhaps the lower density changes the resonant
frequency of the MEMS oscillators. (Though the penetration and
concentration are rather suspect in this description.)
Paul Alfille
On Tue, Oct 30, 2018 at 9:55 AM Bob kb8tq kb8tq@n1k.org wrote:
Hi
issues. Put them
do on any IC.
not. They should
much.
Bob
Helium is lower density, a feature used to reduce turbulence in patients with airway stenosis. Perhaps the lower density changes the resonant frequency of the MEMS oscillators. (Though the penetration and concentration are rather suspect in this description.) Paul Alfille On Tue, Oct 30, 2018 at 9:55 AM Bob kb8tq <kb8tq@n1k.org> wrote: > Hi > > More than sketchy, it sounds a bit crazy. > > MEMS are not a lot different than any IC in that you can get packaging > issues. Put them > in a high pressure “bomb” test and you will see the same issues that you > do on any IC. > The gotcha is that an IC is die coated and a MEMS oscillator likely is > not. They should > get packaged accordingly (= a low leakage package). > > Getting anything into a package at normal atmospheric pressure … not so > much. > > Bob > > > On Oct 30, 2018, at 8:44 AM, jimlux <jimlux@earthlink.net> wrote: > > > > On 10/30/18 3:50 AM, Adrian Godwin wrote: > >> How sensitive to atmospheric environment are MEMs oscillators ? > >> > https://www.reddit.com/r/sysadmin/comments/9si6r9/postmortem_mri_disables_every_ios_device_in/ > >> It gets closer to time-nuts territory in the earlier discussion - see > >> captaincool's contribution some way down : > >> > https://www.reddit.com/r/sysadmin/comments/9mk2o7/mri_disabled_every_ios_device_in_facility/ > > > > The helium leak sounds a bit sketchy, especially when you're talking > about a system that has large RF and magnetic fields. Why would a MEMS > resonator care about what gas it is surrounded by. > > > > That said, I recall someone telling me about problems with early MEMS RF > switches and needing some trace amount of water vapor to make them work - > work fine on the bench, but them into thermal vacuum testing and after some > amount of time they stop working, as the H2O diffuses out of the > (non-hermetic) packages. > > > > > > > > _______________________________________________ > > time-nuts mailing list -- time-nuts@lists.febo.com > > To unsubscribe, go to > http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > > and follow the instructions there. > > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to > http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there. >
