Building UHD Examples
SC
Steven Clark
Thu, Nov 11, 2010 9:13 PM
Pardon the noobness, but how do you build the UHD examples?
I tried:
cd host
mkdir build
cd build
cmake ../examples
make
[ 12%] Building CXX object
CMakeFiles/benchmark_rx_rate.dir/benchmark_rx_rate.o
/home/steven/uhd/host/examples/benchmark_rx_rate.cpp:18:41: error:
uhd/utils/thread_priority.hpp: No such file or directory
/home/steven/uhd/host/examples/benchmark_rx_rate.cpp:19:35: error:
uhd/utils/safe_main.hpp: No such file or directory
/home/steven/uhd/host/examples/benchmark_rx_rate.cpp:20:36: error:
uhd/usrp/single_usrp.hpp: No such file or directory
/home/steven/uhd/host/examples/benchmark_rx_rate.cpp:30: error: variable or
field ‘test_device’ declared void
/home/steven/uhd/host/examples/benchmark_rx_rate.cpp:30: error: ‘uhd’ has
not been declared
/home/steven/uhd/host/examples/benchmark_rx_rate.cpp:31: error: expected
primary-expression before ‘double’
/home/steven/uhd/host/examples/benchmark_rx_rate.cpp:32: error: expected
make[2]: *** [CMakeFiles/benchmark_rx_rate.dir/benchmark_rx_rate.o] Error 1
make[1]: *** [CMakeFiles/benchmark_rx_rate.dir/all] Error 2
So clearly it's not picking up the include files... I tried switching to
things like
make --include-dir ../include/uhd/utils/
but, to no help. What's the correct syntax?
-Steven
Pardon the noobness, but how do you build the UHD examples? I tried: cd host mkdir build cd build cmake ../examples make -> [ 12%] Building CXX object CMakeFiles/benchmark_rx_rate.dir/benchmark_rx_rate.o /home/steven/uhd/host/examples/benchmark_rx_rate.cpp:18:41: error: uhd/utils/thread_priority.hpp: No such file or directory /home/steven/uhd/host/examples/benchmark_rx_rate.cpp:19:35: error: uhd/utils/safe_main.hpp: No such file or directory /home/steven/uhd/host/examples/benchmark_rx_rate.cpp:20:36: error: uhd/usrp/single_usrp.hpp: No such file or directory /home/steven/uhd/host/examples/benchmark_rx_rate.cpp:30: error: variable or field ‘test_device’ declared void /home/steven/uhd/host/examples/benchmark_rx_rate.cpp:30: error: ‘uhd’ has not been declared /home/steven/uhd/host/examples/benchmark_rx_rate.cpp:31: error: expected primary-expression before ‘double’ /home/steven/uhd/host/examples/benchmark_rx_rate.cpp:32: error: expected primary-expression before ‘double’ make[2]: *** [CMakeFiles/benchmark_rx_rate.dir/benchmark_rx_rate.o] Error 1 make[1]: *** [CMakeFiles/benchmark_rx_rate.dir/all] Error 2 So clearly it's not picking up the include files... I tried switching to things like make --include-dir ../include/uhd/utils/ but, to no help. What's the correct syntax? -Steven
JA
Jason Abele
Thu, Nov 11, 2010 9:27 PM
The examples are built into <BUILD_DIR>/examples ... but they are not
installed
Jason
On Thu, Nov 11, 2010 at 04:13:03PM -0500, Steven Clark wrote: > Pardon the noobness, but how do you build the UHD examples? The examples are built into <BUILD_DIR>/examples ... but they are not installed Jason
SC
Steven Clark
Thu, Nov 11, 2010 9:32 PM
installed
Jason
Ah. Thanks!
On Thu, Nov 11, 2010 at 4:27 PM, Jason Abele <jason@ettus.com> wrote: > On Thu, Nov 11, 2010 at 04:13:03PM -0500, Steven Clark wrote: > > Pardon the noobness, but how do you build the UHD examples? > > The examples are built into <BUILD_DIR>/examples ... but they are not > installed > > Jason > Ah. Thanks!
JB
Josh Blum
Thu, Nov 11, 2010 10:17 PM
The examples are built into<BUILD_DIR>/examples ... but they are not
installed
Jason
if you installed UHD its in <prefix>/share/uhd/examples
On 11/11/2010 01:32 PM, Steven Clark wrote: > On Thu, Nov 11, 2010 at 4:27 PM, Jason Abele<jason@ettus.com> wrote: > >> On Thu, Nov 11, 2010 at 04:13:03PM -0500, Steven Clark wrote: >>> Pardon the noobness, but how do you build the UHD examples? >> >> The examples are built into<BUILD_DIR>/examples ... but they are not >> installed >> >> Jason >> > if you installed UHD its in <prefix>/share/uhd/examples > > Ah. Thanks! > > > > > _______________________________________________ > USRP-users mailing list > USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
