great-loop@lists.trawlering.com
Cruising America's Great Loop and other inland routes
Re: GL: Boating with Washer and Dryer
S
Seasalt007@aol.com
Fri, Dec 19, 2008 1:39 AM
Many years I had a Kenmore stackable on my Californian 45 with  the dryer
wired to 220 and it worked great.
In a message dated 12/18/2008 8:25:20 P.M. Eastern Standard Time,
Ralph@AlphaCompServices.com writes:
I have a  close friend who works at Viking yachts, who some of you might know
is a  top quality and expense sport fishing boat manufacturer. In a tour of
their  factory once, I notice they were using Kenmore washer and dryers so I
asked  why would they choose a middle-quality washer dryer and not something
more  "top of the line". His answer was simple: Kenmore parts are  available
world-wide and hence become an excellent choice for their boats  that travel
all over the world.
Ken - I liked your explanation of  why the combo washer/dryer units do not
work as well as the seperate  dryer.
R,.
----- Original Message -----
To: "Phil Bolin"  pwbolin@verizon.net
Cc:  great-loop@lists.samurai.com
Sent: Thursday, December 18, 2008 8:08  PM
Subject: Re: GL: Boating with Washer and Dryer
Hello  Phil,
I believe that you will find that the standard stackable washer  and
dryer is vastly better than the combo non-vented type.  I  have this
setup, and my boating buddy has the other (an Italian made  system) on
his boat and it is next door to useless.  It  apparently relies on a
condensate system to remove water from the air  and hence the clothes,
but it seems to take forever to dry.  I  believe that it is simply the
venting as much as anything that makes  the standard so-called apartment
washer/dryer work better.  It is  certainly a lot less expensive as
well.  While the heat is of  course less than a 240 VAC system, the
tumbling and the air blown  through are good and contribute much to the
drying process.  My  boat has only an 8 kW Onan generator as well, and is
set up with two  "legs" of  120 VAC.  Essentially air-conditioning is on
one  leg (I have 4 units but can run only 3 at a time), and everything
else  on the other leg.  When I use the washer and dryer at the same
time, I can only run one air unit or the load is too great for the
generator.  I am OK at dock, as the boat is wired for 50 amp/240 VAC,  so
I have essentially two 50 amp legs there.  My units are simple  Kenmore
units put in by the PO, and they work very nicely.
Cheers,
Ken Bloomfield
MTOA 2062
50' MT  Tellico  Lady
  1. Is the 110 vented dryer with larger drum (2.6  to 3.5 cu. Feet) really
    better than the combo non vented  one?
  2. Do full time live aboards (anchor a lot) really need a w/d  that works
    well?
  3. Regular 3.6 cu ft dryers are 23.75  inches and my access to spaces that
    will hold same is 23.5  inches.  Has anyone had experience taking dryer
    apart
    to move around inside boat?  Is it easy?  Other  choice is taking framing
    off
    door.
http://lists.samurai.com/mailman/listinfo/great-loop
To modify  your Great-Loop subscription options (change email address,
unsubscribe, etc.) go to:
http://lists.samurai.com/mailman/options/great-loop
unsubscribe, etc.) go to:  http://lists.samurai.com/mailman/options/great-loop
**************One site keeps you connected to all your email: AOL Mail,
Gmail, and Yahoo Mail. Try it now.
(http://www.aol.com/?optin=new-dp&icid=aolcom40vanity&ncid=emlcntaolcom00000025)
Many years I had a Kenmore stackable on my Californian 45 with the dryer wired to 220 and it worked great. In a message dated 12/18/2008 8:25:20 P.M. Eastern Standard Time, Ralph@AlphaCompServices.com writes: I have a close friend who works at Viking yachts, who some of you might know is a top quality and expense sport fishing boat manufacturer. In a tour of their factory once, I notice they were using Kenmore washer and dryers so I asked why would they choose a middle-quality washer dryer and not something more "top of the line". His answer was simple: Kenmore parts are available world-wide and hence become an excellent choice for their boats that travel all over the world. Ken - I liked your explanation of why the combo washer/dryer units do not work as well as the seperate dryer. R,. ----- Original Message ----- From: "Ken Bloomfield" <khtb@bellsouth.net> To: "Phil Bolin" <pwbolin@verizon.net> Cc: <great-loop@lists.samurai.com> Sent: Thursday, December 18, 2008 8:08 PM Subject: Re: GL: Boating with Washer and Dryer > Hello Phil, > I believe that you will find that the standard stackable washer and > dryer is vastly better than the combo non-vented type. I have this > setup, and my boating buddy has the other (an Italian made system) on > his boat and it is next door to useless. It apparently relies on a > condensate system to remove water from the air and hence the clothes, > but it seems to take forever to dry. I believe that it is simply the > venting as much as anything that makes the standard so-called apartment > washer/dryer work better. It is certainly a lot less expensive as > well. While the heat is of course less than a 240 VAC system, the > tumbling and the air blown through are good and contribute much to the > drying process. My boat has only an 8 kW Onan generator as well, and is > set up with two "legs" of 120 VAC. Essentially air-conditioning is on > one leg (I have 4 units but can run only 3 at a time), and everything > else on the other leg. When I use the washer and dryer at the same > time, I can only run one air unit or the load is too great for the > generator. I am OK at dock, as the boat is wired for 50 amp/240 VAC, so > I have essentially two 50 amp legs there. My units are simple Kenmore > units put in by the PO, and they work very nicely. > Cheers, > Ken Bloomfield > MTOA 2062 > 50' MT Tellico Lady >> >> 1) Is the 110 vented dryer with larger drum (2.6 to 3.5 cu. Feet) really >> better than the combo non vented one? >> 2) Do full time live aboards (anchor a lot) really need a w/d that works >> well? >> 3) Regular 3.6 cu ft dryers are 23.75 inches and my access to spaces that >> will hold same is 23.5 inches. Has anyone had experience taking dryer >> apart >> to move around inside boat? Is it easy? Other choice is taking framing >> off >> door. > _______________________________________________ > http://lists.samurai.com/mailman/listinfo/great-loop > > To modify your Great-Loop subscription options (change email address, > unsubscribe, etc.) go to: > http://lists.samurai.com/mailman/options/great-loop _______________________________________________ http://lists.samurai.com/mailman/listinfo/great-loop To modify your Great-Loop subscription options (change email address, unsubscribe, etc.) go to: http://lists.samurai.com/mailman/options/great-loop **************One site keeps you connected to all your email: AOL Mail, Gmail, and Yahoo Mail. Try it now. (http://www.aol.com/?optin=new-dp&icid=aolcom40vanity&ncid=emlcntaolcom00000025)
