Unintended showers inside the boat at high speed.
Val Trent
Could the water have been coming in through the hull to deck seam which may
have not been sealed properly during manufacture? You mentioned that the hull
was running bow down and throwing up a lot of spray. The deck to hull seams
usually have the deck part overlapping on top of the hull part. This could act
like a scoop and with the water striking this area with some force, it finds
its way in side the hull. You wouldn't normally be looking at this area while
the boat was running from the outside. Try it again with someone inside the
boat probing around and looking at these locations where possible and see if
that could be the source of the water. The impact of the water into a slot
between the two parts can create quite a bit of pressure causing it to spray
around a bit.
Russ Hughes
Slo-N-Easy
Richland, Wa.
Val Trent
around a bit.
Russ Hughes
Slo-N-Easy
Richland, Wa.
