Support with downconverting a signal inside USRP
SK
Snehasish Kar
Wed, Sep 6, 2017 5:22 PM
Hello
I want to down convert a DCS 75MHz band to 20MHz or less, is it possible to do so, without changing the FPGA code. I am using NI USRP 2954R
BR
Snehasish
Hello I want to down convert a DCS 75MHz band to 20MHz or less, is it possible to do so, without changing the FPGA code. I am using NI USRP 2954R BR Snehasish
MD
Marcus D. Leech
Wed, Sep 6, 2017 5:37 PM
On 09/06/2017 01:22 PM, Snehasish Kar via USRP-users wrote:
Hello
2954R
BR
Snehasish
USRP-users mailing list
USRP-users@lists.ettus.com
You should be able to do this with RFNoC these days--just a simple
loopback between your RX and TX ports, with the TX port configured for
your desired frequency.  I know that RFNoC had issues with this type of
configuration, but I think recently those have been resolved.
Otherwise, you can do it on the software side--I'm guessing your
bandwidths aren't large.
On 09/06/2017 01:22 PM, Snehasish Kar via USRP-users wrote: > > Hello > > > I want to down convert a DCS 75MHz band to 20MHz or less, is it > possible to do so, without changing the FPGA code. I am using NI USRP > 2954R > > > BR > > Snehasish > > > > > > _______________________________________________ > USRP-users mailing list > USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com You should be able to do this with RFNoC these days--just a simple loopback between your RX and TX ports, with the TX port configured for your desired frequency. I know that RFNoC had issues with this type of configuration, but I think recently those have been resolved. Otherwise, you can do it on the software side--I'm guessing your bandwidths aren't large.
SK
Snehasish Kar
Wed, Sep 6, 2017 5:46 PM
Hello Marcus
Is there any article on how to do this?
BR
Snehasish
From: USRP-users usrp-users-bounces@lists.ettus.com on behalf of Marcus D. Leech via USRP-users usrp-users@lists.ettus.com
Sent: Wednesday, September 6, 2017 11:07:43 PM
To: usrp-users@lists.ettus.com
Subject: Re: [USRP-users] Support with downconverting a signal inside USRP
Hello
BR
Snehasish
USRP-users@lists.ettus.commailto:USRP-users@lists.ettus.com
Hello Marcus Is there any article on how to do this? BR Snehasish ________________________________ From: USRP-users <usrp-users-bounces@lists.ettus.com> on behalf of Marcus D. Leech via USRP-users <usrp-users@lists.ettus.com> Sent: Wednesday, September 6, 2017 11:07:43 PM To: usrp-users@lists.ettus.com Subject: Re: [USRP-users] Support with downconverting a signal inside USRP On 09/06/2017 01:22 PM, Snehasish Kar via USRP-users wrote: Hello I want to down convert a DCS 75MHz band to 20MHz or less, is it possible to do so, without changing the FPGA code. I am using NI USRP 2954R BR Snehasish _______________________________________________ USRP-users mailing list USRP-users@lists.ettus.com<mailto:USRP-users@lists.ettus.com> http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com You should be able to do this with RFNoC these days--just a simple loopback between your RX and TX ports, with the TX port configured for your desired frequency. I know that RFNoC had issues with this type of configuration, but I think recently those have been resolved. Otherwise, you can do it on the software side--I'm guessing your bandwidths aren't large.
MD
Marcus D. Leech
Wed, Sep 6, 2017 11:32 PM
On 09/06/2017 01:46 PM, Snehasish Kar wrote:
Hello Marcus
BR
Snehasish
There's an RFNoC starter page here:
https://kb.ettus.com/Getting_Started_with_RFNoC_Development
Is that what you're after?
inside USRP
Hello
2954R
BR
Snehasish
On 09/06/2017 01:46 PM, Snehasish Kar wrote: > > Hello Marcus > > > Is there any article on how to do this? > > > BR > > Snehasish > There's an RFNoC starter page here: https://kb.ettus.com/Getting_Started_with_RFNoC_Development Is that what you're after? > ------------------------------------------------------------------------ > *From:* USRP-users <usrp-users-bounces@lists.ettus.com> on behalf of > Marcus D. Leech via USRP-users <usrp-users@lists.ettus.com> > *Sent:* Wednesday, September 6, 2017 11:07:43 PM > *To:* usrp-users@lists.ettus.com > *Subject:* Re: [USRP-users] Support with downconverting a signal > inside USRP > On 09/06/2017 01:22 PM, Snehasish Kar via USRP-users wrote: >> >> Hello >> >> >> I want to down convert a DCS 75MHz band to 20MHz or less, is it >> possible to do so, without changing the FPGA code. I am using NI USRP >> 2954R >> >> >> BR >> >> Snehasish >> >> >> >> >> >> _______________________________________________ >> USRP-users mailing list >> USRP-users@lists.ettus.com >> http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com > You should be able to do this with RFNoC these days--just a simple > loopback between your RX and TX ports, with the TX port configured for > your desired frequency. I know that RFNoC had issues with this type > of configuration, but I think recently those have been resolved. > > Otherwise, you can do it on the software side--I'm guessing your > bandwidths aren't large. > >
