-----Original Message-----
Subject: Re: GPS & autopilots (Long)
I had the first model of the Micrologic GPS. During the Persian Gulf Crisis
Now I have an old Garmin and some questions. Why does Leica claim greater
accuracy for its GPS as opposed to WAAS GPSs? In fact, why do they charge
over $600 to add DGPS input to these "wonderful" Leicas?
Thanks in advance,
Ron Rogers
Arild replies:
One thing we tend to forget in these protracted discussions on GPS.
Most of us use cheap consumer product we can readily get, whereas the
military, Coast Guard and commercial airlines use models that cost thousands
of dollars more. Do you actually believe there is absolutely no difference
between a $200 Garmin sold at west Marine and the FAA certified Garmin
porducts sold for aircraft use?
The topic of filtering was mentioned. Some receivers can adjust the rate,
others cannot. Raw GPS data displayed at the fastest possible speed would
look like a jumble. Mask angle also plays a part. An aircraft at 40,000
feet is miles away from any interference and much of the atmospheric
disturbance that affects a receiver on the ground. Military grade
receivers use two discrete frequencies, consumer grade units use one. The
software for a high end commercial/industrial unit is much more
sophisticated than the cheap consumer grade products. Error detection and
self correction is a very high priority in such softeware.
There are numerous factors that differentiate our low end consumer products
from high end commercial/survey/military grade units.
Lastly, this thread began when someone asserted that the compass was an
anachronism and would soon be replaced with a purely GPS based device for
heading information. Any autopilot must have a positional reference which
is many times faster than what most consumer GPS displays can manage.
Furthermore, in the present world, all marine instruments are linked via a
NMEA data port; which operates at one sentence per second. Most if not all
data is filtered to give a rolling average which is many seconds long.
We are now seeing rate gyros in combination with fluxgate compasses
replace floating card compasses, BUT these are still not pure GPS data
sources.
These hybrid compasses have a data rate about ten times as fast as a normal
NMEA data protocol. While the display for human use can use a once
persecond update, the direct link to an autopilot is faster. GPS
compasses have been experimented with using survey grade GPS ( at $60,000
each ) and requires two antenna located 10 meters apart. The installation
cost on a vessel amounts to several thousands of dollars. This not practical
or even possible on small recreational vessels.
Nor are these suitable for driving an autopilot. They were used for
establishing offshore baselines during hydrographic surveys lasting many
days.
So; while all sorts of wonderful things are possible with GPS, ( no
restriction on cost ) the reality is, cheap consumer models are not
capable of doing much of it.
Comparing a $200 West Marine special with the latest MIL spec WAAS - GPS
used by commercial airlines or the military is utterly futile.
Cheers
Arild
GPS does not know where it is going and never will, even when it is
"going". It only knows where it was going and to know that it had to be
"going" somewhere. If it ain't going, then...
If ground speed is zero, GPS has NO direction. If you hit current strong
enough to neutralize your ground speed to zero... the GPS will not have a
direction!
But, the compass may not be usable someday, when the magnetic field drops
to zero. Which it might do before it switches polarity. The North Pole
becomes the South.
Remember what the the Joker (in Batman the movie) told Lt. Ekhart, "think
about the future". And then he put him out of his misery.
Capt. Mike Maurice
Near Portland Oregon.
Thanks in advance,
Ron Rogers
Leica makes a premium GPS. They use a combination of a good antenna, very
good rf, and some fast and interesting electronics to perhaps double the
accuracy of a $100. Garmin. For this they charge a kilobuck or so. So if
you want 40 cms instead of a meter or so go to Leica. Is this really
relevant in the recreational boating world?
Arild replies:
cost thousands
I certainly believe there is a difference. One unit is STCd and the other
is not. That alone is worth a grand or more. Does it improve performance?
Nahh Does it have better human factors? Nahh. But it is certified for
aircraft use and does have the liablility insurance that goes with such a
use.
To work the general question - Is the normal commercial gear better than the
consumer stuff? Sure it is. Is it better by a factor that reflects the
price multiplier? Not a chance. You can double the accuracy by paying 5 to
10 times as much.
the rate,
consumer products
This is getting a little far fetched. It is true that two frequencies are
better than one. As one gets to sub-meter accuracy two frequencies may
well be required. As this relevant to recreational boating? Virtually all
commercial units for non-military and non-surveying use single frequency
receivers. Fancy antennas can help a lot by avoiding multi-path. Better rf
can substantially improve performance. There are some games that can be
played with the processing electronics. All of this gets you from 4 or 5
meters down to less than one. A number of experimenters in this field use
certain Motorola units that have all of the bells and whistles for the
clever stuff and cost less than $250. Virtually all of these techniques can
be applied to consumer equipment and likely will be over the next years.
Error detection is pretty close to the simplest thing going with WAAS.
Available to even the cheapest consumer set. The question is whether or not
a boater would really care.
So you can get from 4 or 5 meters down to 1 with good commercial gear. Is
this relevant?
device for
reference which
linked via a
if not all
sources.
as a normal
not practical
days.
Boy Arild you really are shilling for the buggy whip manufacturers. Yup
them automobiles will never be as cheap or reliable as a good horse - and
the horse can find its way home if you pass out drunk.
The "someone" asserted that the magnetic compass will soon become an
anachronism and that children born in the present will have no knowledge of
the compass as a real tool. Let's see - how many years ago was it that 5
meter GPS was science fiction? In this case I think the art is easy - but
the market for accurate compasses is relatively small. I suspect they will
end up doing it in automobiles before boats.
GPS is presently too slow for the inner loop in an autopilot - a fact I have
repeatedly noted. There is however nothing inherent in GPS that makes this
true. Just wait a while.
Protocols are phased out as they reach the end of their usefulness - current
NEMA is about there. There really are a number of others that will suffice
for this application.
Cheers
Arild
Again Arild remember the buggy whips. I personally enjoyed the merry chase
when we went after core memory with semiconductors - there were a number of
experts who testified we could never reach the required reliability. I
remember the idiot who suggested that there was nothing useful we could do
with semiconductors with one million transistors - a level now exceeded by
household appliances. I remember trying to replace the mechanical copy
counter in a copier with an electronic one. Took 5 years as the powers that
be pointed out that there was no way an electronic counter could be as
reliable as the tried and true mechanical.
The outcome of all this is remarkably clear and certain. Only the time
scale is in doubt. The doubters may build and defend numereous
fortifications - it will have no impact on the outcome.
Jim
be
strong
have a
direction!
I agree completely, Mike. The problem here is that engineers and
navigators speak different languages. "Heading" is only loosely
correlated with "track angle" or "course over ground" in vehicles that
move in the air or on the water. Now, navigating a tank in the Iraqi
desert is a different matter - perhaps that is the application where
this confusion arose. Without a mag or gyro heading sensor and a log,
we could not use the GPS data to compute set and drift.
My magnetic compass is the last instrument I would dispense with, though
it is true that you could get from A to B with a GPS alone by hand
steering so as to maintain a constant bearing to waypoint B. But when
everything else fails, the old reliable compass will still work.
Tony Marshall
K39 "Growler"
Lying Hilton Head, SC
