Sunday, October 12, 2003, 9:59:44 AM, Vernogc wrote:
Thanks, this is what I thought but I'm a residential builder and
not too knowledgeable in marine electronics.
As a further thought on this - I'd put disconnect switches between
each battery and the common positive bar - this will allow you to
easily disconnect each battery, so you can test the batteries
individually. (Of course, if you do this, you may want to use the
isolater in the TC-40 to feed each battery individually, but then you
need more circuit breakers in the separate charger feeds. I wouldn't
bother with this if the batteries are normally used together, and the
disconnect switches are just used for testing.)
I have twice (on two different boats) had one of two paralleled
batteries die, so I like to be able to use the batteries one-at-a-time
occasionally, just to check on the state of things.
Peter Bennett, VE7CEI Vancouver, B.C., Canada
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver-webpages.com/van-ps
