bob@evoria.net said:
"Note: The DAC module is designed specifically for audio applications and is
not recommended for control type applications."
I had hoped that it wouldn't be a problem for driving an OCXO, but my
mistake. The datasheet also notes that the DAC has 16-bit resolution but
only 14-bit accuracy. It didn't seem to have even that at DC. The PWM
version doesn't have any escape clauses. You set "x" parameters and it's
supposed to be 16-bits wide. Maybe "audio" means within the human auditory
passband?
In the old days, the specs for DACs and ADCs were easy to understand, at
least after you figured things out, and all the major vendors had app-notes
explaining what the parameters meant. There was INL, DNL and a few buzzwords
like no-missing-codes and monotonic.
Ballpark of 20 years ago, things got much more complicated. A new generation
of chips came out targeted at DSP applications. FFT plots started appearing
in data sheets. Parameters like ENOB (effective number of bits) became the
important ones.
On top of that, if you are interested in audio or radar, temperature
stability is not an important parameter.
These are my opinions. I hate spam.
