time-nuts@lists.febo.com
Re: [time-nuts] GPS lock of the FE5680. Current experiment and question
HM
Hal Murray
Sat, Feb 11, 2012 2:30 AM
Why 24 bits because it was pretty easy using 74hc596 8 bit counters with
latch and tristate outputs. Unfortunately the schematics are on paper at the
moment scribbles. But the cntrs are stacked on top each other as a unit and
soldered together. Only a few pins are not such as clock output enable and
such its quite simple. The 8 bits feed a port on the micro so I can get the
bytes. As for smaller countes indeed at this point its clear it could have
been even 1.
I can't quite figure out what you are planning...
Someplace, you have to consider metastability.
Since you can't read all 3 chips in the counter at the same time, you also
have to consider the carry from one chip to the next.  I assume you are
familiar with the classic trick of reading high, low, high, and trying again
if the high samples are not the same.  (That's for a 2 byte counter.)
You can probably use the same ideas to avoid metastability by reading the low
byte twice.  If you get X, X or X, X+1, you probably have a valid reading.
You still have the problem of reading both counters in sync.  I'd probably
try something like read: high-1, mid-1, low-1, low-1, mid-1, high-1, high-2,
mid-2, low-2, low-2, mid-2, high-2 and then try again if any of the pairs
didn't match.  (Where "match" allows the low byte to advance by 1.)
The key idea is that the counters will be read with an offset but the offset
will be a constant which won't cause any problems.
These are my opinions, not necessarily my employer's.  I hate spam.
paulswedb@gmail.com said: > Why 24 bits because it was pretty easy using 74hc596 8 bit counters with > latch and tristate outputs. Unfortunately the schematics are on paper at the > moment scribbles. But the cntrs are stacked on top each other as a unit and > soldered together. Only a few pins are not such as clock output enable and > such its quite simple. The 8 bits feed a port on the micro so I can get the > bytes. As for smaller countes indeed at this point its clear it could have > been even 1. I can't quite figure out what you are planning... Someplace, you have to consider metastability. Since you can't read all 3 chips in the counter at the same time, you also have to consider the carry from one chip to the next. I assume you are familiar with the classic trick of reading high, low, high, and trying again if the high samples are not the same. (That's for a 2 byte counter.) You can probably use the same ideas to avoid metastability by reading the low byte twice. If you get X, X or X, X+1, you probably have a valid reading. You still have the problem of reading both counters in sync. I'd probably try something like read: high-1, mid-1, low-1, low-1, mid-1, high-1, high-2, mid-2, low-2, low-2, mid-2, high-2 and then try again if any of the pairs didn't match. (Where "match" allows the low byte to advance by 1.) The key idea is that the counters will be read with an offset but the offset will be a constant which won't cause any problems. -- These are my opinions, not necessarily my employer's. I hate spam.
