Cruising America's Great Loop and other inland routes
View all threadsHi -
I lived for 50 years on the eastern shore of L. Champlain and Penny and I
still summer there aboard Seahorse at Essex Marina on the New York side. It
seems that there is much speculation and too little fact on this subject -
perhaps I can help.
Whose literature says you can't discharge gray water? Probably that of some
environmental group frustrated because they couldn't get their law passed. Or
some municipality, wishfully thinking. Please quote laws - not a vague
opinion of others.
The thru-hull must be sealed - yes - put a plug in it - it's sealed. Don't
believe everything you hear. Most cops will accept a reasonable arrangement
for "sealing;" the letter of the law need not be met in most cases if you show
reasonable intent to comply. In our vented loop I cut the hose and installed
2 ABS unions. The low point on the pump side is fitted with a drain back to
the tank. Open the drain, remove the loop and screw on two plugged union
halves in place of the loop. Store the loop in a big ziplock. Meets: "Plugged
discharge" and "section of hose removed" in one 2-minute operation. Passes with
flying colors.
Regarding Charles' comment, how many marinas did you check? In our
experience pumpouts are no less expensive in most New York marinas than in VT. As I
have posted here before, Point Bay Marina on the VT side offers free pumpouts.
All the people at Essex go to Point Bay to pump for free.
Please get the facts straight!
Regards,
John
"Seahorse"
Also, there
was literature in every Vermont marina which stated that "gray water"
from sinks and showers must be holding tank contained (not true)! We
also understand that some Vermonters are trying to extend the no
discharge of oil statute to include washing of dishes (salad oils and
grease) and also shower water to wash off body oils and sun tan
lotions ???
The Vermont law states ".... the discharge openings sealed shut and
any discharge lines, pipes or hoses shall be removed". That means
that you must seal the through hull fitting and remove all discharge
lines / hoses. Another GL poster claimed that you can leave the Y-
valve in the system for a quick hook-up when needed - but isn't a Y-
valve part of the discharge lines /hoses ??? The word "sealed" with
regard to the through hull fitting doesn't specifically say that it
must be fiberglased and gellcoated, just "capped" or "plugged" -- at
least that is what the "potty police" at one marina told us.
**************Ideas to please picky eaters. Watch video on AOL Living.
(http://living.aol.com/video/how-to-please-your-picky-eater/rachel-campos-duffy/
2050827?NCID=aolcmp00300000002598)
I
As I have posted here before, Point Bay Marina on the VT side offers free
pumpouts. All the people at Essex go to Point Bay to pump for free.
Regards,
John
"Seahorse"
John,
THREE marinas to be exact.
That was last season so it is as current info as I can post. Note this is my
EXPERIENCE.
As always YMMV.
CCC
CHARLES C., JR. & PAT CULOTTA
SUPPORT OUR TROOPS
M/V CCRIDER
PATTERSON, LA.
http://geocities.com/charlesculotta
