Changing USRP -UHD- frequency
JD
Juan Daniel Fernandez Martinez
Mon, Mar 4, 2013 4:53 PM
Hi everyone,
I need to choose one of this options and I would really appreciate your help.
I need to scan a range of the spectrum that is bigger than the USRP capacity. In order to solve this, I will scan chunks of the spectrum that cover the same spectrum range using several steps.
I have thought in two approaches:
1: use gr.bin_statistics just to change the USRP frequency
2: Build a block to manipulate the variables used by the UHD block
Which one would be better? (easier, efficient)
Thanks
Este documento puede contener información privilegiada o confidencial. Por tanto, usar esta información y sus anexos para propósitos ajenos a los de la Universidad Icesi, divulgarla a personas a las cuales no se encuentre destinado este correo o reproducirla total o parcialmente, se encuentra prohibido en virtud de la legislación vigente. La universidad no asumirá responsabilidad sobre información, opiniones o criterios contenidos en este correo que no estén directamente relacionados con la Icesi. Si usted no es el destinatario autorizado o por error recibe este mensaje, por favor informe al remitente y posteriormente bórrelo de su sistema sin conservar copia del mismo.
Hi everyone, I need to choose one of this options and I would really appreciate your help. I need to scan a range of the spectrum that is bigger than the USRP capacity. In order to solve this, I will scan chunks of the spectrum that cover the same spectrum range using several steps. I have thought in two approaches: 1: use gr.bin_statistics just to change the USRP frequency 2: Build a block to manipulate the variables used by the UHD block Which one would be better? (easier, efficient) Thanks ________________________________ Este documento puede contener información privilegiada o confidencial. Por tanto, usar esta información y sus anexos para propósitos ajenos a los de la Universidad Icesi, divulgarla a personas a las cuales no se encuentre destinado este correo o reproducirla total o parcialmente, se encuentra prohibido en virtud de la legislación vigente. La universidad no asumirá responsabilidad sobre información, opiniones o criterios contenidos en este correo que no estén directamente relacionados con la Icesi. Si usted no es el destinatario autorizado o por error recibe este mensaje, por favor informe al remitente y posteriormente bórrelo de su sistema sin conservar copia del mismo.
