trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Canvas replacement
RK
Robert Kassal
Thu, Sep 2, 2004 3:38 AM
Sunbrella of almost any color will last a very long time in the sun. It is a
naturally UV resistant polymer, polyacrylonitrile. My bimini top has a vinyl
undercoat behind the Sunbrella. The top is now 13 years old. It has been up
every summer and winter except one. The past 3 winters were in Florida. The
vinyl undercoat helps maintain water repellency so long as you do not fold the
top. Folding introduces cracks.
I'd also recommend the new Gore-Tex thread which is said to outlast polyester
several fold. I've had to resew twice. The original lasted 7-8 years, the
first repair lasted only 4-5. The recent one was done with the Gore-Tex
thread.
The other weak link used to be the zippers. They were made of a non-UV
stabilized acetal. Great natural lubricity and strength, but very poor UV
resistance. In the past two or three years, both Lenzip and YKK have
introduced UV resistant grades of acetal zippers which ought to last several
times longer. Be sure to get the new materials.
The vinyl should do reasonably well so long as it is vertical. If sloped to
get the sun's rays more directly, it will last a shorter time. I have only had
to replace the aft drops from the arch which are at a 45 degree angle to the
horizon.
Disclaimer: In my previous life I was instrumental in getting both zipper
manufacturers to convert to better materials. No current affiliations etc.
Regards,
Bob
Sunbrella of almost any color will last a very long time in the sun. It is a naturally UV resistant polymer, polyacrylonitrile. My bimini top has a vinyl undercoat behind the Sunbrella. The top is now 13 years old. It has been up every summer and winter except one. The past 3 winters were in Florida. The vinyl undercoat helps maintain water repellency so long as you do not fold the top. Folding introduces cracks. I'd also recommend the new Gore-Tex thread which is said to outlast polyester several fold. I've had to resew twice. The original lasted 7-8 years, the first repair lasted only 4-5. The recent one was done with the Gore-Tex thread. The other weak link used to be the zippers. They were made of a non-UV stabilized acetal. Great natural lubricity and strength, but very poor UV resistance. In the past two or three years, both Lenzip and YKK have introduced UV resistant grades of acetal zippers which ought to last several times longer. Be sure to get the new materials. The vinyl should do reasonably well so long as it is vertical. If sloped to get the sun's rays more directly, it will last a shorter time. I have only had to replace the aft drops from the arch which are at a 45 degree angle to the horizon. Disclaimer: In my previous life I was instrumental in getting both zipper manufacturers to convert to better materials. No current affiliations etc. Regards, Bob
