Ron - In addition to standard power tools, I also have
a small Porter Cable laminate router (laminate
trimmers are quite small, easily handled with one
hand, with a small base plate). I bought it several
years ago when I installed Corian counter tops on my
Willard 36. While I only use it occasionally, the
small size makes it easy to store and it squeezes into
tight spots much better than a full size router. The
small bit aperature makes it better for fine-edge work
where a standard router tends to roll-over and dig the
bit into the wood. Of course, it cannot take the full
compliment of bits a full-size router can, but it
takes more than enough for small boat projects like
reproducing trim, making bookshelves, building
fiddles, etc.
I also carry a Makita electric die-grinder. I use
small metal cutting wheels and buffing wheels for
de-burring. Like the laminate trimmer, it's only
occasionally used but handy when called upon.
Peter
www.SeaSkills.com
Good point and a powerful and versatile replacement for the Roto-Zip. I
purchased an Hitachi laminate router because it came with all the
attachments for which others charge extra. Used it with carbide bit to trim
mahogany that was slap up against window glass.
Ron Rogers
----- Original Message -----
| Willard 36.
