trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
5 Bladed Prop
JP
John Pounder
Tue, Jan 4, 2005 3:30 PM
Hi all,
I'm still debating what to do about my prop problem, excessive noise in the aft stateroom, sounds like water slapping the hull. I'm currently running 1800 RPM through a 3.83:1 gearbox to a 40x30 four blade prop. At this shaft speed, all of the prop shops that I've talked to do not believe the noise is cavitation.
Several shops have recommeded a five blade prop, my question is does anyone on the list run five blades? and what are your observations as far as noise and performance?
Thanks,
John Pounder
"OuttaHere"
Do you Yahoo!?
Take Yahoo! Mail with you! Get it on your mobile phone.
Hi all, I'm still debating what to do about my prop problem, excessive noise in the aft stateroom, sounds like water slapping the hull. I'm currently running 1800 RPM through a 3.83:1 gearbox to a 40x30 four blade prop. At this shaft speed, all of the prop shops that I've talked to do not believe the noise is cavitation. Several shops have recommeded a five blade prop, my question is does anyone on the list run five blades? and what are your observations as far as noise and performance? Thanks, John Pounder "OuttaHere" --------------------------------- Do you Yahoo!? Take Yahoo! Mail with you! Get it on your mobile phone.
PT
Paul Turner
Tue, Jan 4, 2005 4:00 PM
FYI, I have a 5-blade prop running on a single Cummins B6.  A couple of
years ago, I had occasion to help take a twin sister ship from Solomons
to Stuart equipped with the NT standard 4 -blade.  My subjective
observations:  The 5-blade has more initial torque (walks more), is
significantly quieter, loses a knot or so in upper range speed.
Starting from scratch, I'm not sure which I would choose but lean
slightly toward the 4-blade.
Paul Turner  Potomac, MD
NT37-35 "Manitou III"
On Jan 4, 2005, at 10:30 AM, John Pounder wrote:
Hi all,
Thanks,
John Pounder
"OuttaHere"
Do you Yahoo!?
http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering
To unsubscribe send email to
trawlers-and-trawlering-request@lists.samurai.com with the word
UNSUBSCRIBE and nothing else in the subject or body of the message.
Trawlers and Trawlering, T and T, Trawlers & Trawlering, and T&T are
trademarks of Water World International. Unauthorized use is
prohibited.
FYI, I have a 5-blade prop running on a single Cummins B6. A couple of years ago, I had occasion to help take a twin sister ship from Solomons to Stuart equipped with the NT standard 4 -blade. My subjective observations: The 5-blade has more initial torque (walks more), is significantly quieter, loses a knot or so in upper range speed. Starting from scratch, I'm not sure which I would choose but lean slightly toward the 4-blade. Paul Turner Potomac, MD NT37-35 "Manitou III" On Jan 4, 2005, at 10:30 AM, John Pounder wrote: > Hi all, > > I'm still debating what to do about my prop problem, excessive noise > in the aft stateroom, sounds like water slapping the hull. I'm > currently running 1800 RPM through a 3.83:1 gearbox to a 40x30 four > blade prop. At this shaft speed, all of the prop shops that I've > talked to do not believe the noise is cavitation. > > Several shops have recommeded a five blade prop, my question is does > anyone on the list run five blades? and what are your observations as > far as noise and performance? > > Thanks, > > John Pounder > "OuttaHere" > > > --------------------------------- > Do you Yahoo!? > Take Yahoo! Mail with you! Get it on your mobile phone. > _______________________________________________ > http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering > > To unsubscribe send email to > trawlers-and-trawlering-request@lists.samurai.com with the word > UNSUBSCRIBE and nothing else in the subject or body of the message. > > Trawlers and Trawlering, T and T, Trawlers & Trawlering, and T&T are > trademarks of Water World International. Unauthorized use is > prohibited. >
