<<< Presumably with the advent of Cingulars GSM coverage exceeding
Verizon that will enable us to be in tune with the rest of the world? I
am hoping that their GSM phones will be transportable to Europe. Anyone
up to speed on this?>>>
Ron -
I just got back from Germany. I brought my US GSM phone. While there I
could make and receive calls on my US number with no problems. All I had
to do to place a call was enter a "+" the "1" then area code and number.
On my phone you get a "+" by holding the "0" down for a second.
International roaming cost me $0.98 per minute on these calls.
The most important thing to check into is the frequencies available on
the phone. I don't know if the phones ATT sells are multi band or not.
Phones that will be usable in Europe and the US need to be GSM
1900/1800/900 plus whatever ATT may require. These multiband phones are
called "world phones" by some vendors. Many GSM phones build for the US
market may not work in Europe. You need to be quite specific about
this. I know that T-Mobile does offer other "world Phone" capable phones
through there stores. I purchased mine direct from SonyEriccson.
Next you need to insure that your selected cell phone vendor supports
the international roaming. I know T-Mobile does. I used them, and it
worked flawlessly.
The phone I have is an "UNLOCKED" phone that allows me to put in
different SIM cards. My phone is a Sony Ericsson Z600 (over kill). The
advantage of an unlocked phone is that by swapping SIM cards, you can
change your phone carrier. Because I knew ahead of time that I would be
making a lot of local (in Germany) calls, I purchased a SIM card for the
e-plus phone network in Germany. Most cell phone companies in Germany
(all of Eurpoe?) do a lot of prepaid type sales rather than the longer
term contracts as we do here in the US. Prepay minute cards for e-plus
can be had at most gas stations, many stores, and from vending machines
throughout most cities. This worked out well because it eliminates the
roaming charge: The SIM card makes my phone a German phone. It turned
out that making a long distance call from Germany to the US was cheaper
than using the US Number and paying the roaming charge. The SIM card
cost $60, so there is obviously a break even calculation one needs to
do.
In summary, pick a "world phone" capable phone, a US vendor that will
support international roaming and it all works as advertised. My
experience with T-Mobile was good. I suspect that Cingular will do the
trick. ATT may work too although I seem to recall that they had some
other non standard frequency that would require a four band phone ---
you need to check that one out yourself.
Jerry
