time-nuts@lists.febo.com
Wenzel Associates 100 Mhz osc
N
n3izn@aol.com
Mon, Dec 1, 2008 9:59 PM
I stumbled across a 100 Mhz oscillator. It comes from a Harris Constellation RX/TX.
According to the website part number is proprietary. So I thought I would ask here or any info.
Here is what is printed on it from top to bottom.
500-06769D
ISSUE 02
PPD 786-020590-053
100 Mhz
+12 VDC
0105-0201SSRG
It has a SMA female or 100 Mhz out and 4 pins for power and AFC?
I stumbled across a 100 Mhz oscillator. It comes from a Harris Constellation RX/TX. According to the website part number is proprietary. So I thought I would ask here or any info. Here is what is printed on it from top to bottom. 500-06769D ISSUE 02 PPD 786-020590-053 100 Mhz +12 VDC 0105-0201SSRG It has a SMA female or 100 Mhz out and 4 pins for power and AFC?
P
Pete
Mon, Dec 1, 2008 10:18 PM
The 500-xxxx number is a Wenzel custom P/N.
If you give them a call they might tell you the
specs on that part.
Pete Rawson
The 500-xxxx number is a Wenzel custom P/N. If you give them a call they *might* tell you the specs on that part. Pete Rawson
LJ
Lux, James P
Mon, Dec 1, 2008 10:39 PM
Just send Wenzel an email and ask them.  Yes, the part # indicates it's a "custom", but they probably can tell you what performance it has.  Not all the pins might be connected (e.g. Wenzel uses a standard package for these things).
James Lux, P.E.
Task Manager, SOMD Software Defined Radios
Flight Communications Systems Section
Jet Propulsion Laboratory
4800 Oak Grove Drive, Mail Stop 161-213
Pasadena, CA, 91109
+1(818)354-2075 phone
+1(818)393-6875 fax
-----Original Message-----
[mailto:time-nuts-bounces@febo.com] On Behalf Of n3izn@aol.com
Sent: Monday, December 01, 2008 2:00 PM
To: time-nuts@febo.com
Subject: [time-nuts] Wenzel Associates 100 Mhz osc
500-06769D
ISSUE 02
PPD 786-020590-053
100 Mhz
+12 VDC
0105-0201SSRG
time-nuts mailing list -- time-nuts@febo.com To unsubscribe,
go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts
Just send Wenzel an email and ask them. Yes, the part # indicates it's a "custom", but they probably can tell you what performance it has. Not all the pins might be connected (e.g. Wenzel uses a standard package for these things). James Lux, P.E. Task Manager, SOMD Software Defined Radios Flight Communications Systems Section Jet Propulsion Laboratory 4800 Oak Grove Drive, Mail Stop 161-213 Pasadena, CA, 91109 +1(818)354-2075 phone +1(818)393-6875 fax > -----Original Message----- > From: time-nuts-bounces@febo.com > [mailto:time-nuts-bounces@febo.com] On Behalf Of n3izn@aol.com > Sent: Monday, December 01, 2008 2:00 PM > To: time-nuts@febo.com > Subject: [time-nuts] Wenzel Associates 100 Mhz osc > > I stumbled across a 100 Mhz oscillator. It comes from a > Harris Constellation RX/TX. > > According to the website part number is proprietary. So I > thought I would ask here or any info. > > Here is what is printed on it from top to bottom. > > 500-06769D > ISSUE 02 > PPD 786-020590-053 > 100 Mhz > +12 VDC > 0105-0201SSRG > > It has a SMA female or 100 Mhz out and 4 pins for power and AFC? > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com To unsubscribe, > go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
DR
Dan Rae
Mon, Dec 1, 2008 10:55 PM
James, they might answer you with your email address, but when I
e-mailed them, several times, to ask the price of one of the OCXOs they
advertised as being in stock, I never got an answer...  I suspect they
have anti individual time nut spam filters :^(
What I did when faced with one of their custom 10 MHz ovens, was to find
the stock model that it most resembled, and then a bit of Ohmmeter
measuring confirmed that it indeed had the same pin out.  This may not
be possible if it is an older one of course.
Good luck!
Dan
Lux, James P wrote: > Just send Wenzel an email and ask them. James, they might answer you with your email address, but when I e-mailed them, several times, to ask the price of one of the OCXOs they advertised as being in stock, I never got an answer... I suspect they have anti individual time nut spam filters :^( What I did when faced with one of their custom 10 MHz ovens, was to find the stock model that it most resembled, and then a bit of Ohmmeter measuring confirmed that it indeed had the same pin out. This may not be possible if it is an older one of course. Good luck! Dan
LJ
Lux, James P
Mon, Dec 1, 2008 11:24 PM
[mailto:time-nuts-bounces@febo.com] On Behalf Of Dan Rae
Sent: Monday, December 01, 2008 2:55 PM
To: Discussion of precise time and frequency measurement
Subject: Re: [time-nuts] Wenzel Associates 100 Mhz osc
spam filters :^(
More likely, since they're not a huge company, they get busy and forget.  Calling them on the phone is also a possibility.  Yes, they're in Texas, which is kind of like making a foreign phone call, but they're in Austin, and Austin is different. (At least so my Texan cousins tell me).
Jim
> -----Original Message----- > From: time-nuts-bounces@febo.com > [mailto:time-nuts-bounces@febo.com] On Behalf Of Dan Rae > Sent: Monday, December 01, 2008 2:55 PM > To: Discussion of precise time and frequency measurement > Subject: Re: [time-nuts] Wenzel Associates 100 Mhz osc > > Lux, James P wrote: > > Just send Wenzel an email and ask them. > James, they might answer you with your email address, but > when I e-mailed them, several times, to ask the price of one > of the OCXOs they advertised as being in stock, I never got > an answer... I suspect they have anti individual time nut > spam filters :^( > More likely, since they're not a huge company, they get busy and forget. Calling them on the phone is also a possibility. Yes, they're in Texas, which is kind of like making a foreign phone call, but they're in Austin, and Austin *is* different. (At least so my Texan cousins tell me). Jim
N
n3izn@aol.com
Wed, Dec 3, 2008 6:33 PM
I have some drive time so I might give Wenzel a call and see how it goes.
Meanwhile I looked around some more and found some with PTI oscillators. The pins are laid out in a square where as the Wenzel unit is in a straight row. The attached cable is the same with the same colors so I'm going to guess I can find the power and control leads. I'll make a test set up and start playing.
Got a few questions.
When it says 12 volts, most times 13.8~ 14 should be fine? These are labeled 12 volts.
Will that 12 volts need to be regulated?
Do the specs look?decent?
Here is a link to the PTI unit.?
http://www.mtronpti.com/pdf/xo5051_datasheet51607.pdf
Thanks
Chris
500-06769D
ISSUE 02
PPD 786-020590-053
100 Mhz
+12 VDC
0105-0201SSRG
I have some drive time so I might give Wenzel a call and see how it goes. Meanwhile I looked around some more and found some with PTI oscillators. The pins are laid out in a square where as the Wenzel unit is in a straight row. The attached cable is the same with the same colors so I'm going to guess I can find the power and control leads. I'll make a test set up and start playing. Got a few questions. When it says 12 volts, most times 13.8~ 14 should be fine? These are labeled 12 volts. Will that 12 volts need to be regulated? Do the specs look?decent? Here is a link to the PTI unit.? http://www.mtronpti.com/pdf/xo5051_datasheet51607.pdf Thanks Chris > -----Original Message----- > From: time-nuts-bounces@febo.com > [mailto:time-nuts-bounces@febo.com] On Behalf Of n3izn@aol.com > Sent: Monday, December 01, 2008 2:00 PM > To: time-nuts@febo.com > Subject: [time-nuts] Wenzel Associates 100 Mhz osc > > I stumbled across a 100 Mhz oscillator. It comes from a > Harris Constellation RX/TX. > > According to the website part number is proprietary. So I > thought I would ask here or any info. > > Here is what is printed on it from top to bottom. > > 500-06769D > ISSUE 02 > PPD 786-020590-053 > 100 Mhz > +12 VDC > 0105-0201SSRG > > It has a SMA female or 100 Mhz out and 4 pins for power and AFC? > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com To unsubscribe, > go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there.
LJ
Lux, James P
Wed, Dec 3, 2008 6:38 PM
Sent: Wednesday, December 03, 2008 10:34 AM
how it goes.
start playing.
Depends on what sort of internal regulation there is in the box. There's almost certainly some, but, on the other hand, you're looking for high performance, and there's inevitably going to be some effect from changes in the supply (noise, etc.)
> -----Original Message----- > From: time-nuts-bounces@febo.com > [mailto:time-nuts-bounces@febo.com] On Behalf Of n3izn@aol.com > Sent: Wednesday, December 03, 2008 10:34 AM > To: time-nuts@febo.com > Subject: Re: [time-nuts] Wenzel Associates 100 Mhz osc > > I have some drive time so I might give Wenzel a call and see > how it goes. > > Meanwhile I looked around some more and found some with PTI > oscillators. The pins are laid out in a square where as the > Wenzel unit is in a straight row. The attached cable is the > same with the same colors so I'm going to guess I can find > the power and control leads. I'll make a test set up and > start playing. > > Got a few questions. > > When it says 12 volts, most times 13.8~ 14 should be fine? > These are labeled 12 volts. > Will that 12 volts need to be regulated? Depends on what sort of internal regulation there is in the box. There's almost certainly some, but, on the other hand, you're looking for high performance, and there's inevitably going to be some effect from changes in the supply (noise, etc.)
JF
John Franke
Wed, Dec 3, 2008 6:46 PM
If labeled 12V, that means 12V, not 12V automobile.
----- Original Message -----
Sent: Wednesday, December 03, 2008 1:33 PM
labeled 12 volts.
Thanks
Chris
500-06769D
ISSUE 02
PPD 786-020590-053
100 Mhz
+12 VDC
0105-0201SSRG
If labeled 12V, that means 12V, not 12V automobile. ----- Original Message ----- From: <n3izn@aol.com> To: <time-nuts@febo.com> Sent: Wednesday, December 03, 2008 1:33 PM Subject: Re: [time-nuts] Wenzel Associates 100 Mhz osc >I have some drive time so I might give Wenzel a call and see how it goes. > > Meanwhile I looked around some more and found some with PTI oscillators. > The pins are laid out in a square where as the Wenzel unit is in a > straight row. The attached cable is the same with the same colors so I'm > going to guess I can find the power and control leads. I'll make a test > set up and start playing. > > Got a few questions. > > When it says 12 volts, most times 13.8~ 14 should be fine? These are > labeled 12 volts. > Will that 12 volts need to be regulated? > > Do the specs look?decent? > > Here is a link to the PTI unit.? > > http://www.mtronpti.com/pdf/xo5051_datasheet51607.pdf > > Thanks > Chris > > > > > >> -----Original Message----- >> From: time-nuts-bounces@febo.com >> [mailto:time-nuts-bounces@febo.com] On Behalf Of n3izn@aol.com >> Sent: Monday, December 01, 2008 2:00 PM >> To: time-nuts@febo.com >> Subject: [time-nuts] Wenzel Associates 100 Mhz osc >> >> I stumbled across a 100 Mhz oscillator. It comes from a >> Harris Constellation RX/TX. >> >> According to the website part number is proprietary. So I >> thought I would ask here or any info. >> >> Here is what is printed on it from top to bottom. >> >> 500-06769D >> ISSUE 02 >> PPD 786-020590-053 >> 100 Mhz >> +12 VDC >> 0105-0201SSRG >> >> It has a SMA female or 100 Mhz out and 4 pins for power and AFC? >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@febo.com To unsubscribe, >> go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >> and follow the instructions there. >> > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
