From the Groco website:
MODELS: IBV, FBV, FV and TWV
GROCO's design for the imported valves series shown above specified a
high-grade stainless steel valve stem. We have discovered that the stem
material used in some of the valves manufactured between 2004 and 2006 may
not have complied with our specifications. Valves with out-of-spec stems
may not be suitable for salt-water use. Since the non-compliant silver
color stems may fail when the valve is actuated we wish to have all such
valves removed from service. GROCO will supply replacement valves at no charge.
If you go to their website at:
http://www.groco.net/
Then choose:
<svc-bltn/cat-svc-bltn-2-08.htm>IBV-FBV
Service Bulletin
on the front page.
Frank Burrows Destiny 1979 43' Viking MY
Piney Narrows Chesapeake Bay
Then choose:
Service Bulletin
on the front page.
