Return-path: PRINTMORE1@aol.com
Full-name: PRINTMORE1
Message-ID: 1da.392a852.2b8c32c6@aol.com
Date: Mon, 24 Feb 2003 21:45:26 EST
Subject: TWL: Fw: Lehman 120 Simms Injectors
To: Jerrysail@aol.com
MIME-Version: 1.0
Content-Type: text/plain; charset="us-ascii"
X-Mailer: 8.0 for Windows sub 4100
X-Converted-To-Plain-Text: from multipart/alternative by demime 1.01b
X-Converted-To-Plain-Text: Alternative section used was text/plain
Actually there are 3 plugs. One at top, one at bottom, the third one is in
the middle and is used as an overfill. To empty the pump remove the top plug
and then the bottom. Then replace the bottom plug and remove the middle plug.
When the new oil comes out of this plug the pump is normal filled. Replace
the middle plug and the top plug and you are done. Regards. Leonard Stern.
MTOA#893.
Return-path: <PRINTMORE1@aol.com>
Message-ID: <1da.392a852.2b8c32c6@aol.com>
MIME-Version: 1.0
MTOA#893.
