We are interested in purchasing a small sail boat for rowing, sailing and
motoring while cruising on our trawler. It would be stowed via snap davits
on a 12 ft. swim platform. We need stability due to tired knees. Speed and
racing are not of concern. Grateful for any and all info about type,
length, etc. any of you long time cruisers could recommend.
I bought a used 9 ft. Whaler sailing dinghy a couple of years ago and carry
it on my swim platform via snap davits. It is built like a battleship, but
that's about all the nice things I can say about it. It weighs a ton. I
have never weighed it, but I would guess it is around 150 lbs. The first
time I tried to pull the dinghy to a vertical position on the swim platform,
I couldn't do it. There wasn't enough leverage from the cockpit. I now go
up on the bridge, stretch the line as best I can and pull hard. It is very
hard for this 63 year old guy to pull up. A friend of mine lowered it to
the water recently and didn't realize how heavy it was. The dinghy after
about 20 degrees got away from him and he ended up with rope burns.
The sail is not easy to rig as the luff has to be slipped over the entire
mast. If there is any wind this makes it very ackward especially when you
now have to put the mast in the boat after the sail is on and raised. A
lateen rig similar to a sunfish would have been much better. It sails OK
but it is very hard to sit in comfortably. The stability of the dinghy is
not the best. A guest of mine turned it over at the swim platform with the
sail up just getting in. What a mess as the mast head got stuck in the
muddy bottom and I had to motor the boat forward to get it out even though
the sail supposedly has a floating head. One other good feature, though,
was that after the dinghy filled with water we took the mast off, righted
it, pulled out the drain plug and the water emptied. Whaler puts so much
flotation in the boat that even though it was filled with water, the dinghy
rode high enough for the drain to empty the boat. The snap davits, however
make it very stable when the dinghy is hooked on and in the water.
The dinghy rows very well. I have a 2 hp engine that moves it along nicely.
I would suggest that you row, sail and lift any dinghy you are considering
buying.
Herb Hoffman
My Tyme
Prairie 29
