O
Olo
Tue, Aug 13, 2024 2:36 PM
Dear Ettus Support Team,
I hope this message finds you well.
I am currently working with an X310 SDR equipped with two TwinRX daughterboards, and I am looking to receive data simultaneously across all four channels. My goal is to maximize the available bandwidth by configuring the system to receive on all channels in parallel.
Could you please advise on the best approach to achieve this? Specifically, I would like to know if it is necessary to use a specialized RFNoC graph for this setup, or if the uhd::multi_usrp class in the UHD library, along with a corresponding rx_streamer, would be sufficient to accomplish this task.
I appreciate any guidance or recommendations you can provide.
Thank you for your support.
Best regards,
Olo.
Best regards,
Olo.
MD
Marcus D. Leech
Tue, Aug 13, 2024 2:48 PM
Best regards,
Olo.
Assuming that all the streams terminate on your computer, then the
limiting factor is always going to be your computer. RFNoC
is only helpful if you want to do some of the computing on the
radio. But if the goal is to have 4 streams going to your computer,
at full rate, then RFNoC doesn't bring anything to the table--and in
fact, internally these days, an application that uses UHD
multi-usrp streamers actually sets up a standardized RFNoC flow on
the radio anyway.
This document can be helpful:
https://kb.ettus.com/USRP_Host_Performance_Tuning_Tips_and_Tricks
The ultimate question becomes "what do I want to do with those
streams?". That will determine whether your computer
can handle the aggregate data rates.
> Best regards,
> Olo.
the radio anyway.
O
Olo
Wed, Aug 14, 2024 6:57 AM
Dear Ettus Support,
Thank you for your prompt and detailed response. I appreciate the clarification regarding the use of RFNoC and UHD multi_usrp streamers.
To answer your question, my goal is to display the Power Spectral Density (PSD) from the four channels. I plan to use a window function, perform an FFT, and apply the log power block to calculate the PSD.
Could you please advise on the best way to combine all four channels into one for this purpose? Specifically, I'm interested in understanding how to properly aggregate the data streams so that I can calculate the PSD effectively.
Thank you again for your support.
Best regards,
Olo
On Tuesday, August 13th, 2024 at 16:48, Marcus D. Leech patchvonbraun@gmail.com wrote:
Best regards,
Olo.
Assuming that all the streams terminate on your computer, then the limiting factor is always going to be your computer. RFNoC
is only helpful if you want to do some of the computing on the radio. But if the goal is to have 4 streams going to your computer,
at full rate, then RFNoC doesn't bring anything to the table--and in fact, internally these days, an application that uses UHD
multi-usrp streamers actually sets up a standardized RFNoC flow on the radio anyway.
The ultimate question becomes "what do I want to do with those streams?". That will determine whether your computer
Dear Ettus Support,
Best regards,
Olo
On Tuesday, August 13th, 2024 at 16:48, Marcus D. Leech <patchvonbraun@gmail.com> wrote:
>> Best regards,
>> Olo.
MD
Marcus D. Leech
Wed, Aug 14, 2024 1:25 PM
On 14/08/2024 02:57, Olo via USRP-users wrote:
Dear Ettus Support,
clarification regarding the use of RFNoC and UHD multi_usrpstreamers.
Best regards,
Olo
That's probably a question for the discuss-gnuradio mailing list,
assuming you're using GNu Radio.
UHD isn't a signal-processing framework -- it's a driver interface to
the hardware. RFNoC augments this with
DSP blocks that can run on the hardware. I don't think that
there's enough resources on the X310 FPGA to run
FFTs on all 4 channels, but I could be wrong. Maybe there's someone
on here who has done this with RFNoC.
In terms of "spectral merging". If all 4 channels share a common phase
reference, then I think that you can
rotate-and-add prior to computing a single FFT over the aggregated
stream. But that's, again, a DSP question, and
the discuss-gnuradio mailing list might be a better venue for that
type of question.
parallel.
Best regards,
Olo.
the radio anyway.
> Dear Ettus Support,
> Best regards,
> Olo
DSP blocks that can run on the hardware. I don't *think* that
reference, then I *think* that you can
type of question.
>>> parallel.
>>> Best regards,
>>> Olo.
>> the radio anyway.
> _______________________________________________
> USRP-users mailing list --usrp-users@lists.ettus.com
> To unsubscribe send an email tousrp-users-leave@lists.ettus.com
O
Olo
Wed, Aug 14, 2024 2:16 PM
Thank you for your response and the helpful information.
I have a follow-up question regarding the common phase reference. I am using two TwinRX daughterboards, which should share a common local oscillator. Does this setup qualify as having a common phase reference across all four channels?
Additionally, my interest in RFNoC stems from the documentation, which states that the Channels parameter in uhd::stream_args_t is not used for RFNoC devices. Instead, to create a streamer with multiple channels, the API calls uhd::rfnoc::rfnoc_graph::create_tx_streamer() and uhd::rfnoc::rfnoc_graph::create_rx_streamer() include a num_ports argument.
Given this, is it possible to receive data from all four channels simultaneously, even if not at full bandwidth, by simply connecting each last block from the channels to create_rx_streamer()? Also, what should the final block be if I want to receive raw IQ data?
Finally, I am currently using the standard XG image for the X310 due to my dual 10GbE setup. Would this image be able to stream everything simultaneously, or would I need to create a custom one?
I appreciate your guidance on this matter.
On Wednesday, August 14th, 2024 at 15:25, Marcus D. Leech patchvonbraun@gmail.com wrote:
Dear Ettus Support,
Best regards,
Olo
That's probably a question for the discuss-gnuradio mailing list, assuming you're using GNu Radio.
UHD isn't a signal-processing framework -- it's a driver interface to the hardware. RFNoC augments this with
DSP blocks that can run on the hardware. I don't think that there's enough resources on the X310 FPGA to run
FFTs on all 4 channels, but I could be wrong. Maybe there's someone on here who has done this with RFNoC.
In terms of "spectral merging". If all 4 channels share a common phase reference, then I think that you can
rotate-and-add prior to computing a single FFT over the aggregated stream. But that's, again, a DSP question, and
the discuss-gnuradio mailing list might be a better venue for that type of question.
Best regards,
Olo.
On Wednesday, August 14th, 2024 at 15:25, Marcus D. Leech <patchvonbraun@gmail.com> wrote:
>> Dear Ettus Support,
>> Best regards,
>> Olo
> DSP blocks that can run on the hardware. I don't *think* that there's enough resources on the X310 FPGA to run
> In terms of "spectral merging". If all 4 channels share a common phase reference, then I *think* that you can
>> On Tuesday, August 13th, 2024 at 16:48, Marcus D. Leech [<patchvonbraun@gmail.com>](mailto:patchvonbraun@gmail.com) wrote:
>>>> Best regards,
>>>> Olo.
MD
Marcus D. Leech
Wed, Aug 14, 2024 2:22 PM
argument.
The standard images can stream from all 4 channels with a multi_usrp
object. I do this with Gnu Radio all the time, and the
'rx_multi_samples' example UHD code can also stream from multiple
channels.
If you're just streaming the I/Q, you don't need to explicitly do
anything with RFNoC, the multi_usrp UHD API is all you need.
You can configure the streams for any valid sample rate you want.
I'd encourage you to look at the 'rx_multi_samples' example code.
Dear Ettus Support,
the PSD.
Best regards,
Olo
type of question.
parallel.
Best regards,
Olo.
the radio anyway.
> argument.
channels.
>>> Dear Ettus Support,
>>> the PSD.
>>> Best regards,
>>> Olo
>> type of question.
>>>>> parallel.
>>>>> Best regards,
>>>>> Olo.
>>>> the radio anyway.
