Dear time nuts,
Who has experience using loop antennas on the front end of receivers for receipt of Loran C, and other time signals?
Kind regards,
John
On 6/7/23 13:25, JOHN HARTZELL via time-nuts wrote:
Dear time nuts,
I am using a DX Engineering RF-Pro loop for everything from 60kHz (WWVB)
to 20MHz. Works great.
https://www.dxengineering.com/parts/dxe-rf-pro-1b
*Brian Lloyd *
WB5BL - J79BL - NNA6BL
706 Flightline
Spring Branch, TX 78070
brian@heaviside-hf.com mailto://brian@heaviside-hf.com
+1.210.620.0011
JOHN HARTZELL via time-nuts writes:
Dear time nuts,
I do: I played a lot with VLF/SDR and LORAN-C, before people turned
all the transmitters off and installed lawn-mower robots in the
radio-spectrum.
The crucial trick is to /not/ make the loop resonant, ie: no parallel capacitor.
I made all my Loran-C/VLF experiments with this $20 home-brew antenna:
http://phk.freebsd.dk/loran-c/Antenna/
The mad ELF-VLF scientists at VLF.IT has plenty of other good
schematics, but this one worked a treat for me.
Today I would have built two loops, mounted at an right angle, and made my
ADC dual-channel as well.
First round of LORAN experiments:
Second round:
http://phk.freebsd.dk/AducLoran/
The two .gif animations are the only recordings I know of, showing "dance of the nightwave"
Enjoy: It is an incredibly satisfying thing to play with.
Poul-Henning
Poul-Henning Kamp | UNIX since Zilog Zeus 3.20
phk@FreeBSD.ORG | TCP/IP since RFC 956
FreeBSD committer | BSD since 4.3-tahoe
Never attribute to malice what can adequately be explained by incompetence.
Hi
There are a number of sites around the web that go through the details
of doing large-ish loop antennas for various LF signals. Are you trying to
do something small (fit in your pocket) or something fairly large (10 foot
diameter) ?
Bob
On Jun 7, 2023, at 2:25 PM, JOHN HARTZELL via time-nuts time-nuts@lists.febo.com wrote:
Dear time nuts,
Kind regards,
John
https://linkedin.com/in/john-h-6a131b12/
time-nuts mailing list -- time-nuts@lists.febo.com
To unsubscribe send an email to time-nuts-leave@lists.febo.com
For WWVB time signals, I use a resonant ferrite rod antenna, but depending
on the rod, the antenna bandwidth can be several hundred to several
thousand Hz. Resonant multi-turn loops are likely to be similar.
You will need a broad-band (non-resonant) loop for receiving Loran-C, due
to the much wider modulation bandwidth of the signal.
--- Graham
On Wed, Jun 7, 2023 at 3:46 PM Bob Camp via time-nuts <
time-nuts@lists.febo.com> wrote:
Hi
diameter) ?
Bob
On Jun 7, 2023, at 2:25 PM, JOHN HARTZELL via time-nuts <
Dear time nuts,
Kind regards,
John
Hi
The next layer to this is that some (but not all) WWVB receiver designs appear to rely
upon the “bandpass filter” of the antenna to provide reasonable rejection of “crud”.
Having any sort of resonant circuit out in the back yard has implications. As the resonance
shifts with temperature, so does the phase shift. At VLF phase is indeed a big deal. Just
how big a deal …..
As with a lot of things, you can indeed measure outside temperature and model this or that.
Lots of fun can be had.
Bob
On Jun 7, 2023, at 5:30 PM, Graham / KE9H ke9h.graham@gmail.com wrote:
For WWVB time signals, I use a resonant ferrite rod antenna, but depending on the rod, the antenna bandwidth can be several hundred to several thousand Hz. Resonant multi-turn loops are likely to be similar.
You will need a broad-band (non-resonant) loop for receiving Loran-C, due to the much wider modulation bandwidth of the signal.
--- Graham
On Wed, Jun 7, 2023 at 3:46 PM Bob Camp via time-nuts <time-nuts@lists.febo.com mailto:time-nuts@lists.febo.com> wrote:
Hi
diameter) ?
Bob
On Jun 7, 2023, at 2:25 PM, JOHN HARTZELL via time-nuts <time-nuts@lists.febo.com mailto:time-nuts@lists.febo.com> wrote:
Dear time nuts,
Kind regards,
John
time-nuts mailing list -- time-nuts@lists.febo.com mailto:time-nuts@lists.febo.com
To unsubscribe send an email to time-nuts-leave@lists.febo.com mailto:time-nuts-leave@lists.febo.com
Need and need...
For stationary timekeeping purposes, with minute-or-longer
integration time, less than three kHz bandwidth can work OK.
Lower than three kHz, figuring out what is the correct
zero-crossing gets too ambiguous.
But you get really big gains in both S/N and time stability
with a "HiFi" antenna which is flat from 90 to 110 kHz.
Note, that it should be "flat" in both amplitude and phase,
Loran-C, being spread-spectrum, gets really funky if you have
significant delay-distortion (aka. group-delay) across your
pass-band - however wide you decide it should be.
One advantage of going broadband, for instance 20-200kHz, is that
you can receive a lot of other signals at the same time, with the
same SDR implementation, for instance 40, 60 and 66⅔kHz timesignals.
Hi Bob,
that is my 60kHz remote receiver,
the remote tuning could be made relative simple, see the attached
circuit diagram; by changing the supply voltage -- right to corner --
between 15V and 20V the tuning voltage for the varicaps -- D8 and D9 --
will change between +1V and +10,5V, which causes 800pF capacitance
changing the coil L6 is approx 2,2mHy,
D6 an D7 prevent the damage Q25 gate, the op-amp circuit is matching the
high impedance of the C108 L7 tank circuit to 50 ohm cable impedance. At
the 20 long end of the cable -- with 50 termination -- I could see a p_p
voltage between 60mV and 500mV here in the Bay Area, in California,
behind the wall, inside of the house, outside I could get at least 6dB more.
I am using that antenna for a frequency reference -- a 10MHz PLL is
locked to that 60kHz -- only just to verify that the output of the GPS
is locked correct
73
KJ6UHN
Alex
On 6/7/2023 2:47 PM, Bob Camp via time-nuts wrote:
Hi
how big a deal …..
Bob
--- Graham
Hi
diameter) ?
Bob
Dear time nuts,
Kind regards,
John
John,
Details on the air-core loop antenna I use for WWVB reception can be found here: https://www.arrl.org/files/file/QEX_Next_Issue/2015/Nov-Dec_2015/Magliacane.pdf
The associated pre-amp employs an instrumentation amplifier front-end to effectively "shield" the loop from E-field response. The connection made to the center-tap of the loop as indicated in the schematic really isn't necessary for proper performance.
73 de John, KD2BD
Hello to the group.
If the solution is for LORAN C then a wider band antenna is needed. Exactly
as Poul states.
Then for narrow band signals such as wwvb narrow band.
My solution is as follows.
WWVB 10' X 10' square loop resonant at 60 KHz about 1Khz wide or so. It has
worked well for 10 years. Then a preamp.
eLORAN 4' X 4' square loop resonant at 100 KHz and broad banded to tp +/-
15 KHz. Preamp at the antenna.
Square loops are easy to build with plumbing parts. The eLORAN antenna can
be turned 180 degrees. Because currently the tests can come from any
direction. Though right this second they are west of me by 1800 miles.
I also have available simply by changing a connection a classical LORAN C
whip antenna.
I did build the eLORAN antenna just for the fun of it.
Reality is it depends on how far away you are and many other antennas can
work. Simple wire, whips and preamps etc.
Regards
Paul
WB8TSL
On Wed, Jun 7, 2023 at 9:29 PM Alex Pummer via time-nuts <
Hi Bob,
more.
is locked correct
73
KJ6UHN
Alex
Hi
appear to rely
a big deal. Just
how big a deal …..
model this or that.
--- Graham
Hi
trying to
foot
diameter) ?
Bob
Dear time nuts,
Kind regards,
John
time-nuts mailing list -- time-nuts@lists.febo.com <mailto:
