Hi Scott -
You are not alone!
Not long after I began cruising Seahorse I began having problems with the
Balmar 165A alternator. The LP668D was then 2 years old (2004). I kept getting
dusting, even on a near-new serp belt and began to check for the reason.
With a new belt, the tensioner had only minimal travel left before it hit the
stop, and that occurred soon after the belt was broken-in. That left the belt
too-loose and so it slipped heated the pulley. That heating eventually burned
up the front alternator bearing. When I discovered this I queried Alaska
Diesel about the belt, which was a 123464. The parts guy and I decided that the
shorter belt, 123463, must be right and I bought one, only to discover it was
so short it wouldn't fit at all. Then another round of discussions with ADE,
which uncovered the fact that they "never" supplied Balmar alternators and
that a L-N machine was installed when it left ADE. The yard that sold and
installed the engine had replaced the L-N with the Balmar - evidently the pulley
was a bit smaller but they didn't bother to check - and now the factory belt
was too long. I'm not sure how the PO got away without problems - maybe
that's why he had a surplus of belts aboard. The fix, of course, was to get a belt
that would allow a 180-degree wrap on the alternator pulley and put the
tensioner mid-travel when new. Since ADE didn't have anything that would fit, I
determined the correct belt length and ordered one from Michigan Industrial
Belting for about 1/3 the price of a Lugger belt. It fit correctly and I
haven't had any problems since.
By the way, Scott, you might want to check your spares for a "engine low
temp switch." This switch, used exclusively on the LP668D engine. When the
engine is first started, the injection timing is advanced 10 degrees - when the
water temp hits 140 the switch opens and retards the timing back to normal.
You can ID the switch (on the thermostat housing) because it has a 2-pole
connector on 2" leads. If this switch is bad, the timing will be advanced all the
time, which will lower the EGT 50 degrees and make the engine noisier (you
can hear the difference). A dead give-away of switch failure will be that if
the switch fails (closed) the current draw on the positive wire to the PH
engine panel will be about 22 amps. That will show up as low voltage (due to
excessive drop) on the engine panel voltmeter and the red and purple wires on the
key switch will be overly warm, as will the black Merc connector.
Regards,
John
"Seahorse"
Today I went to consult my spares list and guess what? The number on the
belt was R-123463 and my spare was R-123464. My first thought was I had
made a mistake transcribing the number. I found the original spares list
that Nordhavn provided (an excel spreadsheet probably from another boat) and
sure enough it specified R-123464, the belt I had as spare. So now I'm
thinking I have definitely written the wrong number down. So I call Barb
the parts goddess at Hatton in Seattle (206)283-5501 and she tells me if I
can get her the serial number of my engine, she can tell me exactly what
belt was put on the motor when it shipped to China. Well I get her the
number and she confirms the mechanic was spot on, R-123463, not 464. So I
figure, one is a replacement for the other, not true says Barb, a 463 is
1,613 mm long and a 464 is 1,635mm long. The different size belts
accommodate different alternators, so between my boat and someone else's
they changed alternators, resulting in a different belt.
************************************** See what's new at http://www.aol.com
