Allowing the prop to freewheel will reduce drag, but I'd
be interested to know if the savings is significant or not
I'm not sure if hydrodynamic drag is the same as aerodynamic, but a
freewheeling prop on an aircraft has drag equivalent to a disc the size
of the prop arc! A critical step to dealing with engine failure in a
multi-engine aircraft is to feather the prop to avoid unacceptable drag.
