time-nuts@lists.febo.com
Re: [time-nuts] 10 MHz -> 16 MHz clock multiplier
KU
kevin-usenet@horizon.com
Wed, Jan 2, 2013 9:36 PM
I wrote:
The on-board VCXO range is 80 to 230 MHz, so I'd multiply the 10 MHz
up to 160 MHz and then divide by 10.
In case it's not obvious, I meant to write "the on-chip VCO".
Obviously it's not a crystal oscillator; I just failed to
supervise my typing fingers carefully enough.
I wrote: > The on-board VCXO range is 80 to 230 MHz, so I'd multiply the 10 MHz > up to 160 MHz and then divide by 10. In case it's not obvious, I meant to write "the on-chip VCO". Obviously it's *not* a crystal oscillator; I just failed to supervise my typing fingers carefully enough.
