Hi,
I am playing with an Austron 1250B and I'd like to add a fine frequency
adjust.
The data sheet I have on the 1150 oscillator inside indicates that the
EFC input is an option.
Anyone have a schematic for the 1250B that shows how the 1150 is wired
in.
If no EFC on this unit I'll be getting rid of it.
Thanks,
Corby Dawson
Click to make millions by owning your own franchise.
http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3m6iSRbslUuv6eYSqQX4VKjWuK9N7IRHgjWc9Dfez5DWUmBr/
Hi Corby, my 1250a has an EFC connection on the rear panel (a bnc connector)
I have some circuitry but not sure at present what "suffix" letter it refers
to My 1250as have a 5MHz OCXO.
Alan G3NYK
----- Original Message -----
To: time-nuts@febo.com
Sent: Saturday, August 30, 2008 10:50 PM
Subject: Re: [time-nuts] Austron 1250B
Hi,
adjust.
in.
Thanks,
Corby Dawson
Hi Corby and Nigel. I think I have a data sheet for the 1150 oscillator
somewhere as well. I have an "orphan" 1MHz unit. The "a" definitely has the
EFC on the rear and I recollect seeing a spec for the swing per volt. I seen
to think it is quite fine and would be useful for GPS steering.
Alan G3NYK
Hi,
adjust.
in.
Thanks,
Corby Dawson
corby d dawson wrote:
Hi,
adjust.
in.
Thanks,
Corby Dawson
My 1250A manual shows the EFC being brought out to the rear panel, The
front panel EFC
is "over powered" by the voltage put on the rear panel connection. My
manual has two
interconnection diagrams for the wiring. They both show the BNC
connector on the rear.
The external EFC is spec.d at + or - 5 Volts
Good luck on the B model
Bill K7NOM
