View all threadsI have been trying to figure out an issue with my block for a while, and it dawned on me that I might be barking up the wrong tree.
I would like to send a lot of data for my test (say 5000+ samples). I noticed that things seem to get hosed after 496 samples. It might be an issue with my block, but I am wondering if maybe it had something to do with the way the testbenches work.
I tried splitting up the data into two testbenches of roughly 300 samples, but it still seems to die on the second test bench when it hits the 496th sample (my block that is).
Are there any examples of a testbench where a LOT of samples are sent through (in real life, my block stops after a certain number of samples, so I wanted to replicate it in my testbench)?
Hey Jason,
You could try testing with noc_block_skeleton. It only does a loopback and
has a self checking testbench.
Jonathon
On Mon, Aug 20, 2018, 11:48 PM Jason Matusiak via USRP-users <
USRP-users mailing list
USRP-users@lists.ettus.com
Howdy Jon,
My problem with skeleton's test bench is that it only sends one packet of data out (SPP). I would need to send many (which works for a little while, then seems to stop).
--------- Original Message --------- Subject: Re: [USRP-users] packet size for RFNOC testbenches
Date: 8/20/18 10:58 am
To: "Jason Matusiak" jason@gardettoengineering.com
Cc: "USRP-users@lists.ettus.com" usrp-users@lists.ettus.com
Hey Jason,
You could try testing with noc_block_skeleton. It only does a loopback and has a self checking testbench.
Jonathon
On Mon, Aug 20, 2018, 11:48 PM Jason Matusiak via USRP-users usrp-users@lists.ettus.com wrote:
