Hi Paul,
yes, it's a promotional tool, we did not put it on the website yet. We did
put the GPSOCXO/GPSTCXO page on there though, and the GPSTCXO is used on
that eval kit. Even though it is "only" a very high-end TCXO, it's
performance is quite good, especially when encased in a small plastic bag etc to keep
airflow away from it.
TVB has done some measurements on this board, and I think he may have a
page with the results on his website somewhere.
Here is the GPSTCXO eval board photo, the user manual is too big to be
posted to this list, let me know if you want me to send it off-list to you.
The eval board has a 10MHz LVCMOS output on the BNC connector, supports a
USB connection for power, NMEA, SCPI, and 1PPS interface, and has a solder
point for the LVCMOS 1PPS output. It also has a connector for optional
exernal 4V to 8V power supplies, and comes with an antenna, a USB cable, a CD
with software an manuals, and a quick-start instruction sheet.
Hope that helps,
Said
In a message dated 10/2/2012 12:24:29 Pacific Daylight Time,
paulswedb@gmail.com writes:
Said
I was looking and did not see the eval kit on the sight???
Thanks
Paul
WB8TSL
On Tue, Oct 2, 2012 at 12:29 PM, Bob Camp lists@rtty.us wrote:
Hi
The rated temperature stability of the OCXO is not "super good". You will
see more frequency shift on it than say the TBolt OCXO, far more than a
DOCXO.
That's not at all saying it's a bad part. For Time Nut duty, I would try
to
keep it in a fairly benign ambient situation.
Bob
-----Original Message-----
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On
Behalf Of Jim Lux
Sent: Tuesday, October 02, 2012 9:04 AM
To: time-nuts@febo.com
Subject: Re: [time-nuts] RFX GPSDO - Anybody played with one of these?
On 10/2/12 5:08 AM, Azelio Boriani wrote:
Yes, I agree.
On Tue, Oct 2, 2012 at 1:29 PM, Bob Camp lists@rtty.us wrote:
Hi
The OCXO probably isn't going to do very well with the outdoor
temperature
swings.
Bob
Why not.. granted it's easier with large mass and large insulation, but
ultimately, it's all about the closed loop gain of the temperature
control loop. With small mass, the time lag effects will be small, at
least.
To unsubscribe, go to
Said
I have to say I was looking through the list of modules that are available.
I guess a couple of things really jump out.
The low power consumption and what you get in terms of behaviors. It is
pretty amazing actually. Though I have my power sucking Tbolt and 3801.
But I could easily see for a Amateur radio operator just getting into time
nuttery that these might be a nice way to go. I guess that would open an
interesting debate. Getting the used RBs at Hamfest of questionable quality
for $200 or far less. Or something modern and simply works.
Regards
Paul.
On Tue, Oct 2, 2012 at 3:34 PM, SAIDJACK@aol.com wrote:
Hi Paul,
etc to keep
you.
a CD
Hope that helps,
Thanks
Paul
WB8TSL
Hi
will
DOCXO.
to
Bob
Behalf Of Jim Lux
Yes, I agree.
Hi
temperature
swings.
Bob
least.
I went with something modern that haut works (fury). But bitten by time buttery and now trying to discipline a very good OCXO with a fury board. Quite challenging actually. Having to balance noise etc.
Sent from mobile
Regards
Paul.
Hi Paul,
etc to keep
you.
a CD
Hope that helps,
Thanks
Paul
WB8TSL
Hi
will
DOCXO.
to
Bob
Behalf Of Jim Lux
Yes, I agree.
Hi
temperature
swings.
Bob
least.
