trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Any have a SEPAR Diesel Fuel Filtration System?
AH
Anyone Here
Wed, Jan 9, 2013 6:40 AM
Hi all,
I am working on a Mainship 400's fuel filter problem, which is pooling fuel on the top from, I suspect a leak out of the bleed screw.  The system is a Separ which I've not come across having dealt almost exclusively with Racor.
Does anyone have this system?  If yes, I would appreciate any info on where to find parts, ideally in Northern California.  And if anyone else has experienced a fuel leak which pools on top-via a faulty bleed screw/o ring/gasket and solved the problem please share.
Thanks!
Lori Wallerstein
ABYC  Certified Marine Technician
YourBoatDoctor
Roughwater '37
Alameda, CA
Hi all, I am working on a Mainship 400's fuel filter problem, which is pooling fuel on the top from, I suspect a leak out of the bleed screw.  The system is a Separ which I've not come across having dealt almost exclusively with Racor. Does anyone have this system?  If yes, I would appreciate any info on where to find parts, ideally in Northern California.  And if anyone else has experienced a fuel leak which pools on top-via a faulty bleed screw/o ring/gasket and solved the problem please share.  Thanks! Lori Wallerstein ABYC  Certified Marine Technician YourBoatDoctor Roughwater '37 Alameda, CA
