View all threadsHi Marcus,Thank you.1. Yes, I'm sending 100MS/s and there's no "U"s.2. I tried the command "rx_samples_to_file --rate 10e6 --duration 5 --file rx.dat", and the resulting file rx.dat is around 190MiB.3. I need to point out that "benchmark_rate --rx_rate 10e6" with one channel (--channels 0) is working right, but with two channels (--channels 0,1) results in the overflow state. And here's the benchmark ratesummary of two channels:Num received samples: 0Num dropped samples: 0Num overflows detected: 798Num transmitted samples: 0Num sequence errors: 0Num underflows detected: 0 Best Regards,Xinke Zhang > On 05/19/2015 03:10 AM, Marcus via USRP-users wrote:> Hello Xinke,
this is indeed interesting, on many levels:
You're successfully sending 100MS/s (no "U"s, right?), so your computer
doesn't seem to be underpowered; the very asymmetric way that 10MS/s RX
fails leads me to believe that there might be something wrong with
receiving at all.
Can you try
and see if the resulting file rx.dat has nonzero size (in an ideal
world, it would be 200,000,000B in size, around 190MiB).
Best regards,
Marcus
On 05/19/2015 08:33 AM, Xinke Zhang via USRP-users wrote:
Hi,
My goal is to test the 2 simultaneous rx of single usrp x310 with
intel adapter x520 (10 gigabit network). i used the benchmark_rate
function provided by uhd examples (benchmark_rate --rx_rate 10e6
--channels 0,1), but i got the overflow error. when i tried to
decreased the rx_rate, console ouptut was still overflow. Howerver,
when i tested 2 simultaneous tx of single usrp x310 with intel
adapter x520 (10 gigabit network) (benchmark_rate --tx_rate 10e6
--channels 0,1), it was successful. i even changed the tx_rate to
100e6, it was still successful.
Also, I tested the 2 simultaneous tx&rx of single usrp x310 with intel
adapter 82579LM (1 gigabit network), and both of them were successful.
So I want to know what caused the 2 simultaneous rx of single usrp
x310 with intel adapter x520 (10 gigabit network) into overflow state.
Pls give me some suggestions. Thank you in advance.
FYI,
the uhd version I have tested are 3.8.2 & 3.8.4. my host pc is with
intel i7 cpu and 16G memory.
Best Regards,
Xinke Zhang
