Hi,
i'm using the latest svn version of pjsua to communicate between two parties.
I've set SRTP as mandatory for the media transport with the following parameters:
--use-srtp 2 --srtp-secure 0
Everything is fine but Wireshark keep telling me
"SRTP Payload with NULL encryption".
Is that correct?
Here is the snippet of the Offer SDP
a=crypto:1 AES_CM_128_HMAC_SHA1_80 inline:VLDONbsbGl2Puqy+0PV7w/uGfpSPKFevDpxGsxN3
a=crypto:2 AES_CM_128_HMAC_SHA1_32 inline:lp5JGr/jKVzCzLyORdEMJjUPszZmioZ3zubVizTX
and here is the encryption part of the Answer SDP
a=crypto:1 AES_CM_128_HMAC_SHA1_80 inline:y71cYd6MyNqA9ywtm0rS2KBRDByG6/7vuQnyeL8T
So my question, did pjsua used NULL encryption or AES_CM_128_HMAC_SHA1_80 as
suggested in the Answer-SDP?
Another question, when the caller uses (--use-srtp 1) and the callee has
(--use-srtp 2) the call is always unencrypted. Is there a way to change that
behavior in pjsua?
Thanks in advance for any help
Michael
Hi Michael,
On 1/31/08, Michael Bradley Jr mbradley.jr@gmail.com wrote:
Hi,
Is that correct?
I don't know how Wireshark can find out the cipher from RTP packets
(AFAIK you'd have to see the SDP negotiation), but I think it's wrong.
The RTP packets should be encrypted, and you can verify this by saving
the (G711) payload to a file and see the contents.
What Wireshark version are you using? Mine doesn't seem to even know about SRTP.
behavior in pjsua?
Somehow it did not happen here (I'm using r1761). The call is rejected
with 406/Not Acceptable.
cheers,
-benny
Michael
