trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
TWL: Twin Disc Operators Manual Online
A
Albin43Tr@aol.com
Wed, Jul 31, 2002 1:50 AM
'Lo All,
For those of you with Twin Disc Transmissions, but no operator's manual,
there is a rather unique operator's manual on the TD website. It is a manual
that covers all the TD transmissions, with pertinent tables for each
transmission. It is in Adobe format (PDF), so you have to have that program
to access it. Go to the following website and click on "Marine Operator
Manual". It was interesting to see that for most applications, they recommend
oil changes every 1000 hours.
http://www.twindisc.com/plma_ld.html
Wayne
M/V Celestial
Albin 43 Sundeck
'Lo All, For those of you with Twin Disc Transmissions, but no operator's manual, there is a rather unique operator's manual on the TD website. It is a manual that covers all the TD transmissions, with pertinent tables for each transmission. It is in Adobe format (PDF), so you have to have that program to access it. Go to the following website and click on "Marine Operator Manual". It was interesting to see that for most applications, they recommend oil changes every 1000 hours. http://www.twindisc.com/plma_ld.html Wayne M/V Celestial Albin 43 Sundeck
RF
Ross Fleming
Wed, Aug 7, 2002 9:36 PM
On Tue, 30 Jul 2002 21:50:31 EDT, Albin43Tr@aol.com wrote:
'Lo All,
transmission. http://www.twindisc.com/plma_ld.html
Twin Disk transmissions have a very important feature that owners
should be aware of, a "get home" feature.  If the clutch plates fail
it is possible to unscrew a couple of plugs and bolt the clutch plates
together.  While you loose neutral and reverse forward only is a
better option than sitting dead in the water.  Hopefully this
information is available aboard in case you loose your clutch plates.
Ross Fleming        rossflem@serv.net
Seattle, WA
On Tue, 30 Jul 2002 21:50:31 EDT, Albin43Tr@aol.com wrote: >'Lo All, > >For those of you with Twin Disc Transmissions, but no operator's manual, >there is a rather unique operator's manual on the TD website. It is a manual >that covers all the TD transmissions, with pertinent tables for each >transmission. http://www.twindisc.com/plma_ld.html Twin Disk transmissions have a very important feature that owners should be aware of, a "get home" feature. If the clutch plates fail it is possible to unscrew a couple of plugs and bolt the clutch plates together. While you loose neutral and reverse forward only is a better option than sitting dead in the water. Hopefully this information is available aboard in case you loose your clutch plates. ___________________________________________________ Ross Fleming rossflem@serv.net Seattle, WA
FB
Frank Burrows
Wed, Aug 7, 2002 10:10 PM
About two years ago I wanted a manual but the only choice was to buy one
from the Twin Disc Dealer. The cost was $38.00 and it is about the size of
a TV Guide with a whole lot less pages.
This only applies to some of the Twin Disc models
Frank Burrows  79  43' Viking MY  Piney Narrows Marina  Chesapeake Bay
> >For those of you with Twin Disc Transmissions, but no operator's manual, > >there is a rather unique operator's manual on the TD website. It is a manual > >that covers all the TD transmissions, with pertinent tables for each > >transmission. http://www.twindisc.com/plma_ld.html About two years ago I wanted a manual but the only choice was to buy one from the Twin Disc Dealer. The cost was $38.00 and it is about the size of a TV Guide with a whole lot less pages. >Twin Disk transmissions have a very important feature that owners >should be aware of, a "get home" feature. If the clutch plates fail >it is possible to unscrew a couple of plugs and bolt the clutch plates >together. While you loose neutral and reverse forward only is a >better option than sitting dead in the water. Hopefully this >information is available aboard in case you loose your clutch plates. This only applies to some of the Twin Disc models Frank Burrows 79 43' Viking MY Piney Narrows Marina Chesapeake Bay
