After much searching I
I wonder what the cost would be to build-it-yourself- small engine, large alternator, and the various bits and pieces, all bolted to a homemade base. Everything needed is generic and readily available. After all, from what I've been told, it is cold and snowy in many places with nothing else to do.
Rudy and Jill
Jacksonville, Fl
Briney Bug- a 34 foot sail-assisted trawler
850-832-7748
I've had the same idea. I have the parts for one all collected, just need time to bolt together.
If you have the on-deck locker space, consider a Honda OHV gasoline engine driving a large-frame alternator. Smart regulator not needed, just a fixed 14.4v will do nicely. The engine can be had for around $300, and they're reliable and quieter than most small diesels. If you carry a spare alternator, try that for size and see how it goes.
Mark Richter
Mark's Mobile Marine
Ortona, FL
Sent from my iPhone
Rudy and Jill
Jacksonville, Fl
Hi all.
The trouble with a home built rig is that it is home built. For a belt
driven unit to work properly the alignment needs to be very good or the
belt will be chewed up. Beyond that some provision needs to be made for
tightening the belt which will inevitably go slack.
I have a 6KW generator with a Direct drive Subaru ($400) start every time
engine. Enough power to run a table saw etc. and with the addition of a
cheap battery charger, not a expensive charger/inverter, can charge the
batteries. I'd have to see a decibel rating to believe that a small gas
engine is quieter than a small air cooled diesel. A muffler upgrade would
help either.
I remounted my set up on a simple oak base which eliminated a lot of the
bulk. I kept it covered on deck.
Battery chargers are cheap, inverters are expensive and always die sooner
or later and represent an upside down situation where every amp of AC
requires 10 A of DC. As an experiment try running a table saw on an
inverter. Stand back and watch the feed wires glow with current sufficient
to weld.
That having been said I'm sure that in the hands of an expert like Mark the
Briggs & Stratton route would work. I tried it on a small SNUBA/hookah and
even though I had a Brownie rig I could never keep the belt tightened long
enough for a couple of dives.BTW All the new Brownie units are direct drive.
Peter Denton
On Tue, Jan 6, 2015 at 10:40 AM, Mark Richter via Trawlers-and-Trawlering <
Mark Richter
Ortona, FL
Sent from my iPhone
to do.
Rudy and Jill
Jacksonville, Fl
http://lists.trawlering.com/mailman/listinfo/trawlers_lists.trawlering.com
To unsubscribe or modify your subscription options (get password, change
email address, etc) go to:
Trawlers & Trawlering and T&T are trademarks of Water World
Productions. Unauthorized use is prohibited.
