View all threadsHi all,
I've recently checked out the rfnoc-devel branch of uhd-fpga (which is now
set to use Vivado 2017.4), SHA1 9c8c2ba...
A default build from scratch (make E310_RFNOC_sg3) seems to fail to place
all resources. Here's the tail of my console output:
[00:13:03] Current task: Placer +++ Current Phase: 1.2 IO Placement/ Clock
Placement/ Build Placer Device
[00:13:32] Current task: Placer +++ Current Phase: 1.3 Build Placer Netlist
Model
[00:13:33] Current task: Placer +++ Current Phase: 1.4 Constrain
Clocks/Macros
[00:14:48] Current task: Placer +++ Current Phase: 2 Global Placement
[00:14:48] Current task: Placer +++ Current Phase: 3 Detail Placement
[00:15:23] Current task: Placer +++ Current Phase: 3.1 Commit Multi Column
Macros
[00:15:24] Current task: Placer +++ Current Phase: 3.3 Area Swap
Optimization
[00:15:25] Current task: Placer +++ Current Phase: 3.4 Pipeline Register
Optimization
ERROR: [Place 30-487] The packing of instances into the device could not be
obeyed. There are a total of 13300 slices in the pblock, of which 9305
slices are available, however, the unplaced instances require 9329 slices.
Please analyze your design to determine if the number of LUTs, FFs, and/or
control sets can be reduced.
ERROR: [Place 30-99] Placer failed with error: 'Detail Placement failed
please check previous errors for details.'
ERROR: [Common 17-69] Command failed: Placer could not place all instances
[00:15:56] Current task: Placer +++ Current Phase: 3.5 Small Shape Detail
Placement
[00:15:56] Current task: Placer +++ Current Phase: Finished
[00:15:56] Process terminated. Status: Failure
Warnings: 656
Critical Warnings: 37
Errors: 3
Makefile.e300.inc:103: recipe for target 'bin' failed
make[1]: *** [bin] Error 1
make[1]: Leaving directory '/home/ejk/prefix/fpga-ettus/fpga/usrp3/top/e300'
Makefile:71: recipe for target 'E310_RFNOC_sg3' failed
make: *** [E310_RFNOC_sg3] Error 2
This seems a little odd because the post_synth_util.rpt suggests we should
have enough resources available after synthesis:
| Site Type | Used | Fixed | Available | Util% |
| Slice LUTs* | 42516 | 0 | 53200 | 79.92 |
| LUT as Logic | 33321 | 0 | 53200 | 62.63 |
| LUT as Memory | 9195 | 0 | 17400 | 52.84 |
| LUT as Distributed RAM | 3990 | 0 | | |
| LUT as Shift Register | 5205 | 0 | | |
| Slice Registers | 68993 | 12 | 106400 | 64.84 |
| Register as Flip Flop | 68993 | 12 | 106400 | 64.84 |
| Register as Latch | 0 | 0 | 106400 | 0.00 |
| F7 Muxes | 1407 | 0 | 26600 | 5.29 |
| F8 Muxes | 254 | 0 | 13300 | 1.91 |
| Block RAM Tile | 121 | 0 | 140 | 86.43 |
| RAMB36/FIFO* | 108 | 0 | 140 | 77.14 |
| RAMB36E1 only | 108 | | | |
| RAMB18 | 26 | 0 | 280 | 9.29 |
| RAMB18E1 only | 26 | | | |
| DSPs | 142 | 0 | 220 | 64.55 |
| DSP48E1 only | 142 | | | |
I'll try a build next with less "stuff" in the rfnoc_ce_auto_inst.v -- but
is this currently expected behavior?
Appreciate the help, thanks!
EJ
As a quick followup, it appears that resources requirements are just a tad
too high for the instantiations defined in rfnoc_ce_auto_inst_e310.v.
Editing the file to remove one of the two FIFOs builds successfully.
EJ
On Thu, Apr 19, 2018 at 10:19 AM, EJ Kreinar ejkreinar@gmail.com wrote:
Hi all,
Netlist Model
Clocks/Macros
Macros
Optimization
Optimization
be obeyed. There are a total of 13300 slices in the pblock, of which 9305
Placement
Warnings: 656
Errors: 3
EJ
EJ is correct,
and we've applied his patch that reduces the usage. However, we've
discovered a separate issue on current rfnoc-devel, which we're
currently investigating, and recommend everyone to simply locally edit
the local version of rfnoc_ce_auto_inst.
Thanks,
Martin
tad too high for the instantiations defined in rfnoc_ce_auto_inst_e310.v.
EJ
On Thu, Apr 19, 2018 at 10:19 AM, EJ Kreinar <ejkreinar@gmail.com
mailto:ejkreinar@gmail.com> wrote:
Hi all,
is now set to use Vivado 2017.4), SHA1 9c8c2ba...
place all resources. Here's the tail of my console output:
Clock Placement/ Build Placer Device
Netlist Model
Clocks/Macros
Column Macros
Optimization
Register Optimization
not be obeyed. There are a total of 13300 slices in the pblock, of
which 9305 slices are available, however, the unplaced instances
require 9329 slices. Please analyze your design to determine if the
number of LUTs, FFs, and/or control sets can be reduced.
failed please check previous errors for details.'
instances
Detail Placement
Warnings: 656
Errors: 3
should have enough resources available after synthesis:
-- but is this currently expected behavior?
EJ
USRP-users mailing list
USRP-users@lists.ettus.com
