----- Original Message -----
an engineer at
Mobil told me that Mobil Tri-Synthetic Motor Oils are very similar in test
results. He recommended Mobil Tri-Synthetic 15W-50 for my American Diesel
6N140. He said that I could safely double the oil change interval
suggested
by the engine manufacturer.
Hi Al,
I find the advice given you by the Mobil Engineer to be suspect. While the
Tri-Synthetic Mobil 1 may work just fine in a Lehman or American Diesel
engine it is apparent from reading the spec sheet that this oil is not
primarily intended for diesel service. Why is it apparent? This is a new
formulation and it meets the latest API "S" specs but it only meets API CF
which is several years old. Also, note that the proper name for this product
line is "Mobil 1 Tri-Synthetic series". "Mobil 1" has always been an
automotive oil not a "heavy duty" oil. Mobil's HD synthetic engine oil is
called "Delvac 1".
Further, unless he specifically addressed the single vs. multigrade issue
for Lehmans and American Diesels one must assume that he hasn't considered
those issues.
BTW: While at the Poulsbo WM Trawler Fest I had a brief chat with a guy from
Lugger about our recent questions around why Lehmans want single grade oil.
He felt that it was probably related to piston ring clearances and valve
guide clearances. That is, and engine with looser clearances would need a
heavier oil to make up for that looseness. I'm not sure that I buy that
argument but I pass it along as another data point.
Suspiciously yours,
Alex
